Author Topic: Need Help Painting My Ducky Shine 3 TKL!  (Read 3330 times)
Offline Abn
« on: Tue, 22 October 2013, 20:05:33 »
So my shine 3 should be here soon, and I would love to add a spray paint job to it. I have a few questions before I acutally do it and I would love your guys tips and pointers!
Paint I would like to use:
http://www.amazon.com/Rust-Oleum-254860-11-Ounce-Specialty-Galaxy/dp/B0058I2I5O/ref=sr_1_1?s=hi&ie=UTF8&qid=1382489308&sr=1-1&keywords=rustoleum+color+shift
1. Would I need to prime with a black primer ?
2. Would I need to use sand paper to get the exisiting paint off?
3. Can I just spray paint it with a quick wipe down of the keyboard?
4. Should I add a clear coat after the paint job?
Noppoo Choc Mini Reds | Ducky Shine 3 TKL Browns | Topre Realforce 87U 45gram
Offline redskull
Re: Need Help Painting My Ducky Shine 3 TKL!
« Reply #1 on: Tue, 22 October 2013, 23:07:42 »
try have a look here, super complete guide;
http://geekhack.org/index.php?topic=44191
