Author Topic: Help with noppoo chic mini  (Read 2385 times)
Offline Pythmere
« on: Wed, 23 October 2013, 20:56:11 »
Hello, I just got this keyboard today and am loving. However I cant for the life of me figure out how to switch the caps lock/ctrl keys. On the other versions of the keyboard you use fn + Switch lock however This version the delete keys function ability says insert. Any one have any idea how to do it?
Edit: Fn + F9 switchs caps lock and ctrl :)
« Last Edit: Thu, 24 October 2013, 00:14:21 by Pythmere »
Offline Rayne
  • For Science!
Re: Help with noppoo chic mini
« Reply #1 on: Wed, 23 October 2013, 21:38:00 »
interesting, some people in another thread were trying to figure out what fn + F12 did(because that used to be insert on the old choc mini), maybe its the caps/ctrl switch. try that and let us know if thats it.
Offline Pythmere
« Reply #2 on: Wed, 23 October 2013, 22:18:54 »
Using Fn + f12 opens up a windows app that checks for drivers. If you use it again it resets the keyboard. So that is not it. I am wondering if they might have removed the feature however the keys still have cap and ctrl on them and it was a major selling point of the keyboard.
Offline Pythmere
« Reply #3 on: Wed, 23 October 2013, 22:45:38 »
Update: So after playing around with the keyboard i got the caps and ctrl keys to switch. I think its something with the Fn key and hit the control and cap keys but I cant figure out how to get it to go back to cap key being cap...
Offline Tony
« Reply #4 on: Thu, 24 October 2013, 03:47:16 »
Easy. Press Switch Lock on the top right to switch between Cap and Ctrl.
Offline brialona
« Reply #5 on: Thu, 24 October 2013, 23:34:13 »
hows the quality of this board?
ozil
Offline Tony
« Reply #6 on: Fri, 25 October 2013, 21:19:12 »
Excellent, with POM keycaps on black case or PBT on white case. NKRO through USB by tricking Windows to believe that there is 3 keyboards attached at the same time, so 6KRO x 3 = 18KRO.
Offline Surnia
« Reply #7 on: Sat, 26 October 2013, 00:59:21 »
oh jebus, a new model with new Fn keys?
This thing changes so often...
Noppoo Choc Mini with MX Black | Filco 104 MJ2 Ninja with MX Black
Offline buni
« Reply #8 on: Wed, 06 November 2013, 18:19:13 »
I think it switches the ctrl and cap locks if you press Fn and F9.
Blue switches are my favorite... I've only tried blue switches...
