Author Topic: [IC] A.87W TKL : PCB+Plate+Case : Full LED + Macro < GB Today !>  (Read 35128 times)
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
Re: [IC : Vote] A.87W TKL : PCB+Plate+Case : Full LED + HW Macro <Vote !>
« Reply #50 on: Sat, 02 November 2013, 09:19:11 »
당분간 한국내 공제계획은 없습니다.   긱핵을 통해  정식으로 관심도 조사에 응해주시면 됩니다 ~
감사합니다
« Last Edit: Sat, 02 November 2013, 09:24:17 by sprit »
Offline redskull
« Reply #51 on: Sat, 02 November 2013, 10:51:50 »
감사합니다
i don't understand korean sprit. whats up?
Offline justnits
« Reply #52 on: Sat, 02 November 2013, 10:54:19 »
감사합니다
[/quote
From Google Translate:
There are no plans for the time being deducted in Korea. Through gikhaek ones to respond to a formal investigation will be interest-
Thank you
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline redskull
« Reply #53 on: Sat, 02 November 2013, 10:59:16 »
감사합니다
[/quote
Thank you
can't even understand what the translation is about, captain.  :))
Offline sprit
« Reply #54 on: Sat, 02 November 2013, 14:59:11 »
My Fellow GH members!
I put a Note for Non GH Koreans to Join IC after the registration to GH.
Because I have no plan to open GB in Korea for now, maybe after GH GB, After I got relaxed. I may open a GB for domestic Koreans.
I Love You Guys.  Everything goes alright and Steady. !! :)
The GB will start On Monday, after I consult the proper procedure to the Modertors. You Know I want start a really good GB.
« Last Edit: Sat, 02 November 2013, 15:26:09 by sprit »
Offline sprit
« Reply #55 on: Sat, 02 November 2013, 15:06:11 »
[/quote
Thank you
Thx !!  Quite a good Translation!   Sorry for the Inconveniences!  !!
« Last Edit: Sat, 02 November 2013, 15:08:17 by sprit »
Offline BlueWhale
  • Nan[A]
Re: [IC : Vote] A.87W TKL : PCB+Plate+Case : Full LED + Macro <Full Ready for GB>
« Reply #56 on: Sun, 03 November 2013, 00:50:04 »
is there any dateline for this GB?
Current board : Leopold FC700R
Future board : Custom 60% or 87 board, PFU HHKB Pro 2 (soon)
Offline justnits
« Reply #57 on: Sun, 03 November 2013, 03:20:11 »
woo, the man has spoken, Monday will be less blue now...hopefully :D
Offline sprit
« Reply #58 on: Sun, 03 November 2013, 08:52:27 »
Yes right!   I need to consult to our Moderators for the details on the GB procedure.
I would like to  put  Two GB Topics.
1.   PCBs           :  60%,   75%,   87 TKL
2.   Cases + Plates   for :  60%,   75%,   87 TKL
Offline justnits
« Reply #59 on: Sun, 03 November 2013, 08:58:09 »
sprit, i'm new to building custom boards.
for this a87 board, what are the things we need to solder onto it?
for all i know, switches and LEDs are to be soldered by us, but what about diodes and resistors?
Offline redskull
« Reply #60 on: Sun, 03 November 2013, 09:02:13 »
diodes already soldered. need to solder resistors for switches that you put LEDs.
Offline sprit
« Reply #61 on: Sun, 03 November 2013, 09:08:34 »
Actually I am trying All parts Factory pre-soldered!!   Lets Forget the MOQ !   Just Make It better!
« Last Edit: Sun, 03 November 2013, 09:12:02 by sprit »
Offline sprit
Re: [IC] A.87W TKL : PCB+Plate+Case : Full LED + Macro <Full Ready for GB>
« Reply #62 on: Mon, 04 November 2013, 01:18:24 »
I mean All  !
The Controller, capacitors, resistors, diodes, Regulators, all SMD parts will be Factory pre-soldered.
Offline justnits
« Reply #63 on: Mon, 04 November 2013, 01:53:27 »
All?
which means all we need to solder is switch and LED? no need extra resistors for LED?
Offline sprit
« Reply #64 on: Mon, 04 November 2013, 03:34:39 »
All?
Yes!   Mr.       All =  Alles!   SMDs
And I'd like to provide some more extra resistors for the further private custom!
« Last Edit: Mon, 04 November 2013, 03:37:33 by sprit »
Offline justnits
« Reply #65 on: Mon, 04 November 2013, 04:21:11 »
nice...looking forward to your groupbuy post :)
Offline Chemisery
« Reply #66 on: Mon, 04 November 2013, 07:43:58 »
2.    Carbon Case (Polycarbornate)  : Clear Only                            ~110 USD
A.87 PCB  + PolyAcryl   Cases
So does that mean that you won't be doing the frosted case like your friend's keyboard in the video?     :-\
Another qn, will the clear case be difficult to maintain?  It looks really good though..    :p
Filco MJ2 Ninja Brown TK + Iron Mask II + GMK Dolch
WTB:
Riptide MX
Cosmic Dusk V2 MX
Nebulus V2 MX
Interstellar Blue V2 MX
Offline sprit
« Reply #67 on: Mon, 04 November 2013, 08:56:09 »
Hello! If You are refer Frost as Clear(transparent) and frost-like finish  :  As I love that so much,  I have written like this ;
clear & rough finish = half shinny = half rough = sanding =  half frost finish = astel finish ... among Acryl Industry in Korea.
« Last Edit: Mon, 04 November 2013, 18:38:58 by sprit »
Offline Chemisery
« Reply #68 on: Mon, 04 November 2013, 09:09:41 »
Hello! If You are refer Frost as Clear(transparent) and forst-like finish  :  As I love that so much,  I have wrote like this ;
clear, rough finish = half shinny = half rough = sanding = frost finish = astel finish ... among Acryl Industry in Korea.
Yes, that's the one, half frosted and half transparent! I see, I am learning new things every time I come to this forum!  :))
Looking forward to your GB, I can see your effort in putting this up!  :thumb:
WTB:
Riptide MX
Cosmic Dusk V2 MX
Nebulus V2 MX
Offline sprit
« Reply #69 on: Tue, 05 November 2013, 01:14:31 »
Frosty  = Clear Half Rough = Half Shinny   Cherry 300 Mouse
42586-0
Offline justnits
« Reply #70 on: Tue, 05 November 2013, 01:54:43 »
[/quote
sprit and his picture tease :(
when is the A87 groupbuy going to start?
Offline redskull
« Reply #71 on: Tue, 05 November 2013, 03:44:50 »
sprit, where is sample pictures of metal casing?
Offline sprit
« Reply #72 on: Tue, 05 November 2013, 13:04:36 »
Sorry!  the Realease Candidate Metal Cases are delayed because the Factory busy last week.
May I start the PCBs and Acryl Cases first?   They are Full Ready!
« Last Edit: Tue, 05 November 2013, 13:06:37 by sprit »
Offline AKmalamute
  • HHKB Scrub
« Reply #73 on: Tue, 05 November 2013, 14:27:47 »
If you're talking days to get the metal cases, then my vote is yes, start the GB now. Only, warn people than "next week" you hope to have a separate GB for just the metal cases, that are intended for the PCBs you're selling now.
HHKB-lite2, Dvorak user
Offline redskull
« Reply #74 on: Tue, 05 November 2013, 20:55:24 »
so next week will be metal casing + pcb or metal casing only?
Offline sprit
Re: [IC] A.87W TKL : PCB+Plate+Case : Full LED + Macro <Go for GB>
« Reply #75 on: Wed, 06 November 2013, 02:53:19 »
It's Raining in Seoul Today.
I'd like to go on Spammimg Colors ..... From The Dark BackSpace  .....
http://www.youtube.com/watch?v=FTY8H7zjdtc
GB Starts From Today!
42778-0
42780-1
42782-2
42784-3
« Last Edit: Wed, 06 November 2013, 02:57:41 by sprit »
Offline sprit
Re: [IC] A.87W TKL : PCB+Plate+Case : Full LED + Macro < GB Today !>
« Reply #76 on: Wed, 06 November 2013, 03:05:13 »
< GB Today !    From 09:00 AST>
Offline justnits
« Reply #77 on: Wed, 06 November 2013, 03:13:17 »
thanks for updating this, now i shall let go of my F5 key...for the next 4 hours or less :P
Offline sprit
