Author Topic: Helpl with autohotkey  (Read 1549 times)
Offline Jixr
« on: Thu, 24 October 2013, 13:16:34 »
I'm looking for a way within autohot key to basically disable or turn my "num lock" key into something else.
But I still want num lock to be on so I can use the numbered keypad.
any ideas or anyone have a script?
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: Helpl with autohotkey
« Reply #1 on: Thu, 24 October 2013, 16:51:07 »
Convert num lock into the letter A:
NumLock::A
Convert num lock into left shift:
NumLock::LShift
The state of number lock doesn't depend on whether the key is still working; you just can't change the state with that key while the script is running.
Bore Awards
Offline ijprest
« Reply #2 on: Thu, 24 October 2013, 21:54:20 »
You can also put this at the very top of the file (in the "auto-execute" section).  It does exactly what it says.
Code: [Select]
SetNumLockState, AlwaysOn
return
Personally, I like to use Num Lock to show/hide an instance of the Calculator app.
Code: [Select]
WinToggle(Title,EXE) {
  DetectHiddenWindows, on
  If WinExist(Title) {
    If WinActive(Title) {
      WinMinimize
      WinHide
    } else {
      WinShow
      WinActivate
  } else {
    Run %EXE%
NumLock::WinToggle("Calculator","Calc")
Offline laffindude
« Reply #3 on: Thu, 24 October 2013, 23:29:56 »
You can also add "SetNumLockState, AlwaysOn" in the autoexec section to lock it on when you run the script.
