Author Topic: R1 1x1 backlit keycap  (Read 5498 times)
Offline BakaPhoenix
« on: Sat, 26 October 2013, 13:54:38 »
Where i can find some of them? i want to replace the windows keycap on my cm storm quickfire tk, but the only 1x1 keycaps are for the esc or the function row :(
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: R1 1x1 backlit keycap
« Reply #1 on: Sat, 26 October 2013, 14:00:15 »
Offline BakaPhoenix
« Reply #2 on: Sat, 26 October 2013, 14:06:35 »
About that site, it says r1 for esc keys...
Wasen't esc key row 4?
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #3 on: Sat, 26 October 2013, 14:12:24 »
There's translucent keys if you scroll down. I'm not sure what you want. Does it have to have a windows symbol? Or can it just be a backlit key?
Offline BakaPhoenix
« Reply #4 on: Sat, 26 October 2013, 14:35:50 »
It must don't have a windows key xD
I'm finding a repalcement because i'll be using the keyboard on a mac and the windows logo kinda bother me XD
Offline Photoelectric
Offline BakaPhoenix
« Reply #6 on: Sat, 26 October 2013, 15:15:43 »
Here:
http://www.maxkeyboard.com/r1-1x1.25-cherry-mx-portal-keycap-set.html
Yes, that one is beautyful but the win key on the quickfire tk is only 1x1 not 1x1.25 :(
Thanks anyways
« Reply #7 on: Sat, 26 October 2013, 15:18:18 »
Oh sorry, missed the 1x requirement :(
Offline BakaPhoenix
« Reply #9 on: Sun, 27 October 2013, 13:10:48 »
http://www.qwerkeys.co.uk/shop/index.php?route=product/product&product_id=73
Are you telling me tu use teh arrow keys?
Sorry but i don't get what you are telling me :(
« Reply #10 on: Sun, 27 October 2013, 16:18:23 »
Yes.
You wanted R1 (bottom of the keyboard) 1x transparent keycap - the arrow keys would match those requirements.
