Author Topic: Sources of 70A thick and stuff o-rings?  (Read 2775 times)
Offline viowastaken
« on: Sun, 27 October 2013, 06:17:01 »
Hi yall,
About to order some o-rings. I prefer the stiffest possible with the most key-travel reduction.
I was able to find some on amazon, but the shipping cost was 34 dollars for the tiny packet. Insane.
Anyone know a good place to get them? I need them shipped to Norway for a reasonable rate.
thanks in advance.
Filco Majestouch Tenkeyless Cherry MX Brown with Ducky thick PBT white/grey
Re: Sources of 70A thick and stuff o-rings?
« Reply #1 on: Sun, 27 October 2013, 09:50:33 »
Perhaps get a proxy?
Offline viowastaken
« Reply #2 on: Sun, 27 October 2013, 10:17:49 »
Hi,
Yes I have considered getting a proxy of some sort, but I really think it will still end up costing an unnecessary amount of money. The packet is only $2, and shipping an item of that size definitely should not be more than $5.
« Last Edit: Sun, 27 October 2013, 10:24:11 by viowastaken »
« Reply #3 on: Sun, 27 October 2013, 10:21:23 »
If you want send me a pm with your shipping info and maybe we can figure something out.
Offline viowastaken
« Reply #4 on: Sun, 27 October 2013, 10:54:08 »
Pm sent!  :thumb:
Offline viowastaken
« Reply #5 on: Sat, 02 November 2013, 10:29:28 »
Bump I guess, never heard anything back unfortunately :\
« Reply #6 on: Sat, 02 November 2013, 10:32:46 »
Sorry forgot to get back with you
http://www.amazon.com/dp/B000FMWLR8/ref=biss_dp_t_asn
^^ that is what your after correct?
I will send them to you  :thumb:
« Last Edit: Sat, 02 November 2013, 10:45:18 by SpAmRaY »
