Author Topic: Compact ALPS keyboards  (Read 4005 times)
Offline Chloe
  • Switch Kitten
« on: Mon, 29 December 2008, 04:11:18 »
I'm looking for alternatives to the SMK-85. Does anyone know of any other compact (not tenkeyless) keyboards with ALPS switches, preferably without Windows keys? So far I've found these:
Filco FKB-86E
Filco FKB-82PRO
SIIG Minitouch
Offline lowpoly
« Reply #1 on: Mon, 29 December 2008, 05:09:55 »
http://geekhack.org/showthread.php?t=617
White clicky. Don't know about real/simplified/fake Alps. I can open a switch if it's important.
Offline Chloe
  • Switch Kitten
« Reply #2 on: Mon, 29 December 2008, 05:13:34 »
Thanks lowpoly. Are the switches plate mounted in the first one?
Offline lowpoly
« Reply #3 on: Mon, 29 December 2008, 05:20:39 »
I have to check when I'm back in the office.
Offline Chloe
  • Switch Kitten
« Reply #4 on: Mon, 29 December 2008, 06:09:53 »
I found a Korean review of the newer KPT-84. The soldering does not look good and it sounds like there are issues with the switches:
http://translate.google.com/translate?sl=ko&hl=en&ie=UTF-8&u=http%3A%2F%2Fmusecine.textcube.com%2F48
lowpoly, do you know if the plate in the newer KPT-84 is metal or plastic?
Offline bigpook
« Reply #6 on: Mon, 29 December 2008, 06:54:18 »
Offline wellington1869
« Reply #7 on: Mon, 29 December 2008, 08:34:54 »
Quote from: bigpook;16359
# # Night is deep, shook the heart ..
That must be some keyboard : )
Lol. Or at least some night with the keyboard ;)
using: ms 7000/Das 3
Offline sandy55
« Reply #8 on: Mon, 29 December 2008, 08:40:12 »
2 Filco 'board has a sort of simplified sw.
SIIG is supposed to have real alps. it doesn't have win keys, it has an AT plug.,,
these are usually a good sign for real ALPS ( not always).  The seller is well know to k/b manias
as a guy who handles northgate omnikey and others with ALPS sw.
Seems like Miknitouch has real blue/click sw according to the review in Korean web site,
I often see  Motery international( FKD) 'board with SMK-ish switches.
The reason of Yellow keys at function key line is that function keys are smaller than main keys.
2/3 sized versions were available only in YLW/GRN linear( no space for additional leaf spring inside the sw housing ).
don't know reason of white( or are they cream ) keys below function keys ( =, BS and a key
without printing according to pic in repair com )
If the price is reasonable, I'll go for SIIG.
Offline lowpoly
« Reply #9 on: Mon, 29 December 2008, 10:18:57 »
Quote from: Chloe;16355
Both are plate mounted on plastic.
Offline Chloe
  • Switch Kitten
« Reply #10 on: Mon, 29 December 2008, 10:36:12 »
Thanks lowpoly. Do you think it makes a difference to the feel and sound?
Offline Chloe
  • Switch Kitten
« Reply #11 on: Mon, 29 December 2008, 10:43:14 »
Quote from: sandy55;16380
Thanks sandy. I am not sure I will like linear feeling Function keys, but I think this has a better layout compared to the SMK-85. IF I get the SMK-85 I will have to cut tracks on the PCB so I can get the layout I want.
Offline lowpoly
« Reply #12 on: Mon, 29 December 2008, 10:59:13 »
Quote from: Chloe;16396
Hard to say, the newer one does have resonances when typing. I was sure to find a metal plate but it was plastic.
