Author Topic: looking for a specific keyboard, gaming-related  (Read 5163 times)
Offline mTwTT1
« on: Mon, 28 October 2013, 17:37:26 »
hey everyone!
i play sc2 at a pretty high level, ive been using a das for close to a year now (due to sponsorship obligations at first) and the keyboard has really grown on me. one of the advantages it has is that the ctrl key is really low so when i lay my hand on my desk the bottom part of my pinky doesnt press down on it, which is an issue ive been having with alot of other keyboards (cm storm, filco, realforce etc.). ctrl is used to hotkey stuff so i keep misshotkeying buildings/units because my finger keeps pressing down on it (force of habit due to my setup/posture T.T)
anywho i really love the feel of my das but as everyone knows its a full size keyboard, which i dislike alot because i cant position my mouse the way i want. im looking for a red/brown switch TKL keyboard that has a similarly low ctrl key, any suggestions?
much appreciated <3
Offline divito
Re: looking for a specific keyboard, gaming-related
« Reply #1 on: Mon, 28 October 2013, 17:42:39 »
Ooo, it's TT1. I agree on the aspect of the Das, as you can see in my profile is my current daily keyboard. I'll let the more experienced members give you guidance though.
Good luck in your search.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline MKULTRA
  • telling it how it is
« Reply #2 on: Mon, 28 October 2013, 17:50:42 »
Idk if its cause the Das has a high bezel or what.  Maybe try some Cherry or DCS profile keycaps?  They are lower than OEM style.
Offline mTwTT1
« Reply #3 on: Mon, 28 October 2013, 17:52:59 »
dont think its keycap related, already tried switching them around but i had the same problem. das boards are just much flatter/lower than other boards
Offline mTwTT1
« Reply #4 on: Mon, 28 October 2013, 17:57:49 »
like right now i have my ring finger on 1, my pinky is on the side of caps lock and the bottom part of my pinky (inside my palm) is pressing down on ctrl, doesnt do that on my das
im currently using a cmstorm quickfire, i have the same issue w/ my realforce but to a lesser extent
« Last Edit: Mon, 28 October 2013, 17:59:27 by mTwTT1 »
Offline Polymer
« Reply #5 on: Mon, 28 October 2013, 18:13:54 »
Have you actually tried putting Cherry Profile keycaps on one of the other keyboards?  I think Das ones are still OEM profile (so a bit taller).  The lower cherry ones might help..
Or you can always take a CTRL key from a Cherry profile set and put it on there...it'll be a bit lower which may not work for you either but you can give it a shot..
Offline MKULTRA
« Reply #6 on: Mon, 28 October 2013, 19:20:32 »
If you put Cherry or DCS keycaps on those boards you will have an easier time.
« Reply #7 on: Mon, 28 October 2013, 19:23:18 »
Agree with MKULTRA, you can just grab caps with a lower profile and get a QFR. Alternatively, the Leopold FC700R has almost flat caps so maybe that might help if you wanted a keyboard that has decent stock keycaps so you wouldn't have to buy aftermarket caps.
Also I'm a huge ROOT and SC2 fan! Welcome to GeekHack ^__^
Offline mTwTT1
« Reply #8 on: Mon, 28 October 2013, 19:39:11 »
ty ^^, been on geekhack for a while. just dont post much :D
do u know where i can find a reasonably priced cherry profile tkl set or just even the ctrl key? elitekeyboards's shipping cost to canada is way too expensive
also is the leopold FC200RT/AB similar to the FC700R shape/keycap-wise?
« Last Edit: Mon, 28 October 2013, 20:09:20 by mTwTT1 »
« Reply #9 on: Mon, 28 October 2013, 20:04:36 »
do u know where i can find a reasonably priced ctrl cherry profile key? the one on elitekeyboards is like 8$ to ship :P, only looking for a ctrl key
Yeah they're pretty similar in shape+cap.
WASDkeyboards sells a 1.25x key, so I'd take a look at that.
« Reply #10 on: Mon, 28 October 2013, 20:06:10 »
Are you sure TacticalStache? I thought that the FC700R caps were different from the rest of the Leopold line.
Offline Polymer
« Reply #11 on: Mon, 28 October 2013, 20:26:41 »
They are..the 200 I'm pretty sure are OEM profile..the 700r are really close to Cherry profile..
Offline mTwTT1
« Reply #12 on: Mon, 28 October 2013, 20:31:41 »
does anyone even sell cherry profile sets? been having an insanely hard time finding any
edit: interesting find, http://www.ncix.com/products/?sku=75700 super low profile caps, but yea sadly its a full board tt
« Last Edit: Mon, 28 October 2013, 20:36:02 by mTwTT1 »
Offline goobus
  • HHKB Elite
« Reply #13 on: Mon, 28 October 2013, 20:42:11 »
I have a FC700R and the keycaps are high quality thick PBT. I believe they are OEM profile but I have to wait til I get home to compare. Can anyone else confirm this? The spacebar is a weird spacing though, but I don't think that would be an issue for you.
Offline goobus
  • HHKB Elite
« Reply #14 on: Mon, 28 October 2013, 20:43:41 »
If you think you'd like those caps you can always buy the full board, take the caps off and sell the guts to someone here on gh. I'm sure someone would have a use for it.
Offline mTwTT1
« Reply #15 on: Mon, 28 October 2013, 20:49:36 »
id rather just buy a set of cherry profile caps tbh, dont wanna go through the hassle of buying a board i wont need then selling it
but yea i cant find  any  fc700r's or cherry caps anywhere
Offline mTwTT1
« Reply #16 on: Mon, 28 October 2013, 20:52:17 »
and according to this fc700R caps are in between cherry and oem
http://geekhack.org/index.php?topic=40704.0
Offline divito
« Reply #17 on: Mon, 28 October 2013, 20:56:06 »
Best bet is to try the classifieds for someone getting rid of a Cherry set.
Offline goobus
  • HHKB Elite
« Reply #18 on: Mon, 28 October 2013, 20:59:43 »
Yeah. Feng also sells cherry profile thick PBTs on his eBay (on eBay: geek_feng) but they are kinda pricey
Offline mTwTT1
« Reply #19 on: Mon, 28 October 2013, 21:18:05 »
**** it ill just get the ek ctrl key, i wanna see if that'll fix my issue
thx for all your help <3
Offline goobus
  • HHKB Elite
« Reply #20 on: Mon, 28 October 2013, 21:25:45 »
Good luck dude! Sorry couldn't be of more help.
Offline mTwTT1
« Reply #21 on: Mon, 28 October 2013, 21:34:16 »
na u guys were plenty of help, now i know what ill get as my next keyboard~ : D
Offline Polymer
« Reply #22 on: Mon, 28 October 2013, 21:39:25 »
They're very close to Cherry profile..in between would suggest they're actually somewhere close to the middle ground between OEM and Cherry..which probably isn't right at all..they're slightly different in shape but very close to Cherry profile...as far as picking a lower profile keycap, they'll do exactly what you want...
Offline goobus
  • HHKB Elite
« Reply #23 on: Mon, 28 October 2013, 21:54:18 »
Yeah, only shipping would cost an arm and a leg to Canada.
Offline Linkbane
« Reply #24 on: Mon, 28 October 2013, 22:27:03 »
An idea is to get a board with OEM keycaps and then replace the bottom row with Cherry profile, that'll make a huge difference.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #25 on: Mon, 28 October 2013, 23:06:38 »
If you want cheap Cherry profile set, go for KC104
What you describe, being able to touch the control key with the hand... it's not even possible for me to do unless I purposely keep my wrist on the table and bend my hand at a weird sharp angle. My main keyboard is GH60 with Cherry keycap. Perhaps you should look into Poker/Pure as they are most similar for readily available.
« Last Edit: Mon, 28 October 2013, 23:12:25 by IvanIvanovich »
