Author Topic: Is it safe for switches to not have keycaps on?  (Read 3556 times)
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« on: Mon, 28 October 2013, 19:51:10 »
I got my first mechanical keyboard a few days ago and the capslock has been driving me up the wall. On membrane keyboards I always shave the cap down so its just the square peg that goes in the slot. Since I have cherry reds now i figured i could just pop off the caps. but now im thinking that will let dirt and such get in and ruin the switch.
Can any of you gurus give me any advice on this?
I currently have removed the caps from tab, capslock, and tilde. In case that matters. Tab is the only one im likely to ever use.
"Obviously, windows are central to Windows. But what is a window?"
Re: Is it safe for switches to not have keycaps on?
« Reply #1 on: Mon, 28 October 2013, 19:52:33 »
Would a stepped caps lock work for you? Or does it have to be removed?
« Reply #2 on: Mon, 28 October 2013, 20:01:39 »
Or just put a 1x keycap on there to stop dust dropping down into the switch.
    • Force Project X
« Reply #3 on: Mon, 28 October 2013, 20:16:30 »
I dont think stepped would help much. With the way I tend to dangle my pinky off to the side, I think I really need a full on gap.
The 1x might work if I can stiffen it up with a great big spring or something i guess.
« Reply #4 on: Mon, 28 October 2013, 20:20:35 »
SP has "key lockouts" which prevent a MX switch from being pressed (if you want to stop it from being pressed at all, and who uses Caps Lock these days anyway?).
http://www.keycapsdirect.com/marketplace.php
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Mon, 28 October 2013, 23:21:11 »
Or, like you could just disable key in the OS to do nothing which is super easy and free.
If you're on Windows:
Code: [Select]
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=hex:00,00,00,00,00,00,00,00,02,00,00,00,00,00,3a,00,00,00,00,00
Offline nullstring
« Reply #6 on: Mon, 28 October 2013, 23:36:03 »
I recommend using something like autohotkey to remap the key to something more useful.
It's in prime realestate afterall.
Makes a fantastic ESC key, imho.
Offline RaVNzCRoFT
  • * Commercial Vendor
« Reply #7 on: Tue, 29 October 2013, 00:07:58 »
Colemak layout changes caps lock to backspace.  Although I don't use Colemak, I've heard very good things particular aspect of it.
<<< Click to view
Offline Linkbane
« Reply #8 on: Tue, 29 October 2013, 11:01:53 »
Well, to be the brutally honest, if you're not going to ever use it, who cares if it gets dirty?
I mean, it might be aesthetically unpleasant, but better than accidentally caps-locking.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline MKULTRA
  • telling it how it is
« Reply #9 on: Tue, 29 October 2013, 11:40:29 »
To answer your question, no it is not a big deal.  A lot of pro gamers do it.  Not really a big deal.
    • Force Project X
« Reply #10 on: Tue, 29 October 2013, 21:26:33 »
thanks for your input guys! I decided I didnt want to totally lose the key - never know when I might come across a long macro\const name - and I was starting to really hate the look of the missing cap.
The lockout clip gave me a seemingly decent idea though. I found a random compression spring that fit well enough under the cap. I just hope now that this doesnt ruin the key from the constant upward force.
« Reply #11 on: Wed, 30 October 2013, 04:13:22 »
What keyboard is it that your using?
Offline terran5992
  • One With The Cup Rubber
« Reply #12 on: Wed, 30 October 2013, 05:31:29 »
I doubt anything will happen
    • Force Project X
« Reply #13 on: Wed, 30 October 2013, 07:15:27 »
corsair k95 (mx red)
