Author Topic: Need help.  (Read 2889 times)
Offline acidtrip69
Need help.
« on: Tue, 29 October 2013, 00:41:30 »
I just bought two keys. A Panic and Oh **** key. I need to know if they are good or even if they are real ? and not a stupid sticker you put on your on key ? This is why I'm asking.
http://www.amazon.com/Novelty-Computer-Keys-pack-Button/dp/B00887UDAY
the 2 link is were i bought mine. thinking they are real keys that a bit of better quality. I want to know if i made a good choice or bad because i want to cancel before its too late.
http://www.pimpmykeyboard.com/marketplace.php
« Last Edit: Tue, 29 October 2013, 00:43:31 by acidtrip69 »
Offline Pacifist
  • on hiatus
Re: Need help.
« Reply #1 on: Tue, 29 October 2013, 00:48:39 »
The Fun Computer Key has a peel and stick backing so that it can be applied to just about anything!
Seems like its a sticker.
If these were caps, they would be designed for rubber domes, and rubber domes come in all sorts of sizes.
So most likely sticker
Offline acidtrip69
Re: Need help.
« Reply #2 on: Tue, 29 October 2013, 00:51:12 »
the ones from amazon a stickes i know that, but the ones i bought are from here. I need to know if they are real keycaps.
Re: Need help.
« Reply #3 on: Tue, 29 October 2013, 01:18:04 »
The ones from SP are real keycaps - you can use them on your Cherry MX-based keyboard.
Offline acidtrip69
Re: Need help.
« Reply #4 on: Tue, 29 October 2013, 01:21:02 »
So did i buy the right ones ? The good ones ?
Re: Need help.
« Reply #5 on: Tue, 29 October 2013, 04:41:43 »
The Amazon ones - no idea.
The Signature Plastics (SP) ones - yep!  I got one or two of those in my Crap Bag - they are fine.
BTW SP is who makes the keycaps for most of the group buys around here.
