Author Topic: CM Storm Recon Scroll Wheel Problem  (Read 10729 times)
Offline PointyFox
« on: Thu, 31 October 2013, 21:45:19 »
I just got a new CM Storm Recon mouse and I noticed that:
1. There is a point on the wheel where it becomes harder to turn
2. Scrolling upward makes random clicking noises and is louder than scrolling down
3. The clear part of the wheel isn't uniform in thickness
Does anyone have similar problems?
Offline PointyFox
Re: CM Storm Recon Scroll Wheel Problem
« Reply #1 on: Sat, 02 November 2013, 03:11:48 »
Bump.  I'm going to get a replacement from CM.  No clue if the replacement will be the same.  I hope it's not a design problem like the Logitech G5 mice had with their scroll wheels.
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #2 on: Sat, 02 November 2013, 06:19:58 »
2. That happens with every single unit of the mouse, it's a common problem but doesn't really makes it bad.
Strangely, the CM Storm Spawn and Roccat Kone Pure use the same scroll wheel but neither are THAT loud.
Here's a vid I made about it:
But even with that problem, I'd still throw any Logitech mice against a damn wall if I were to choose between them and a Recon (though Spawn and Kone Pure are nice too).
« Last Edit: Sat, 02 November 2013, 06:24:00 by wetto »
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline ComradeSniper
  • HHKB Pro
« Reply #3 on: Sat, 02 November 2013, 18:58:19 »
I have a friend with a Recon who also has this issue.
Offline PointyFox
« Reply #4 on: Thu, 19 December 2013, 13:26:18 »
Update:  Got my replacement and it works perfectly.  I guess there was a problem with my old one.
Offline SmOgER
« Reply #5 on: Thu, 16 January 2014, 10:11:38 »
I bought this mouse today, and when I noticed this issue too I was sooo... pissed off.
I immediately took it apart (haven't even plugged it in lol) and fortunately enough a little piece of tape on (around) wheel's leg fixed the problem :)
The problem with these mouses is not the scrolling wheel itself, it's rather plastic mountings around it - there is too big of a cavity for scrolling wheel to properly fit in, it's just loose. Technically it's a very minor problem, but surely annoying as heck. IMO it's unacceptable how $60 mouse can behave like that, while most logitech budget mouses for $8 are perfectly silent.
The leg I'am refering to is the part of the wheel which goes on top of middle click switch.
PS.
I noticed that too. It's not big deal and not hugely noticeable, but I do prefer smoother/ligher scrolling design overall. In windows I had to increase scrolling lines per notch to 7 lines (was 5 lines using Gigabyte M6900) to make it more practical.
« Last Edit: Thu, 16 January 2014, 10:37:36 by SmOgER »
