Author Topic: What should I do to my keyboard?  (Read 7386 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
« on: Sat, 02 November 2013, 23:07:29 »
I have some extra cash laying around and am sitting here ready to spend it on my keyboard. So what should I do, I already ordered o-rings and and palm rest.
Offline swill
  • builder & enabler
    • swillkb.com
Re: What should I do to my keyboard?
« Reply #1 on: Sat, 02 November 2013, 23:08:21 »
Put thick pbt caps on it...
« Reply #2 on: Sat, 02 November 2013, 23:09:43 »
Keycaps.
Offline C5Allroad
« Reply #3 on: Sat, 02 November 2013, 23:22:01 »
Are those keycaps backlight friendly?
How do they feel with o-rings?
Offline PointyFox
« Reply #4 on: Sat, 02 November 2013, 23:25:41 »
No, and the same as other keycaps.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #5 on: Sat, 02 November 2013, 23:38:59 »
It will hard to find backlit friendly keycaps.  You may want to get in on something like this: http://geekhack.org/index.php?topic=50292.0;topicseen
Offline C5Allroad
« Reply #6 on: Sat, 02 November 2013, 23:46:25 »
That seems like a waste of perfectly working keyboard.
[Edit] How long do the stems on keycaps take to dry. I cleaned them today and they still seem kind of wet. I don't want to put it on my keyboard until they are dry.
Offline esoomenona
  • Gnillort?
« Reply #7 on: Sat, 02 November 2013, 23:47:34 »
Buy some Clack Clarks.
Offline C5Allroad
« Reply #8 on: Sat, 02 November 2013, 23:49:12 »
Something that will help with my typing.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #9 on: Sat, 02 November 2013, 23:54:37 »
Mavis Beacon Teaches Typing
http://www.broderbund.com/c-33-mavis-beacon.aspx
LOLLL who remembers this from 3rd grade?
Offline C5Allroad
« Reply #10 on: Sat, 02 November 2013, 23:57:42 »
.......-_- Well was not expecting that.
I meant like make it feel nicer to type and such.
Offline Martyr
« Reply #11 on: Sun, 03 November 2013, 00:02:19 »
Change the switches/springs if you're into some soldering.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #12 on: Sun, 03 November 2013, 00:03:31 »
Nothings better than dousing it in Petrol and lighting the beggar up.  You want to stand there and inhale the smoke/fumes of that keyboard deeply because it's the only way to be a true Geekhack Goon, that's addicted to keyboards 24/7  :thumb: .
Always have a spare, so you can get a further hit later on........
« Reply #13 on: Sun, 03 November 2013, 00:14:23 »
Buy a Thorpe keyboard.  You know you want to.
Offline C5Allroad
« Reply #14 on: Sun, 03 November 2013, 00:20:12 »
$$$ I have $100… can't buy a topre. Buy you're right, I do want to try one.
Offline Pacifist
  • on hiatus
« Reply #15 on: Sun, 03 November 2013, 00:24:08 »
Either buy a new board or new caps
Offline C5Allroad
« Reply #16 on: Sun, 03 November 2013, 00:24:50 »
What kind of caps?
« Reply #17 on: Sun, 03 November 2013, 00:48:39 »
Use the money to bribe one of the admins to move this thread.
Offline ComradeSniper
  • HHKB Pro
« Reply #18 on: Sun, 03 November 2013, 01:03:47 »
« Reply #19 on: Sun, 03 November 2013, 02:27:42 »
All these fancy things are not primarily to help with typing.
Don't believe all the hype about mechanicals helping you type faster its a myth.
Improving my typing had never even crossed my mind.
If you have to get something get one if those custom USB cables with the autocorrect feature.
Offline baldgye
  • Will Smith Disciple
« Reply #20 on: Sun, 03 November 2013, 03:01:07 »
Buy rice, take off all the caps and then pour the rice on the keyboard, then replace the caps.
« Reply #21 on: Sun, 03 November 2013, 03:10:59 »
Or do this!
http://geekhack.org/index.php?topic=50410.msg1099921.msg#1099921
« Reply #22 on: Sun, 03 November 2013, 03:26:06 »
Lube and sticker your board, bro. Improve those soldering skills.
« Reply #23 on: Sun, 03 November 2013, 03:31:54 »
Thorpe makes me type faster.  Or it feels like it.
« Reply #24 on: Sun, 03 November 2013, 03:33:10 »
That's because you can't wait to feel it from keystroke to keystroke!
« Reply #25 on: Sun, 03 November 2013, 03:41:18 »
Seems legit!
Offline zoolzoo
« Reply #26 on: Sun, 03 November 2013, 12:28:08 »
You should buy a Poker II as a mod board and start tearing it apart. Build or buy some ergo clears or something and solder those on, solder on some led lights. The stock Poker II caps are really nice so you wont have to buy new caps for it right away.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline 1pq
  • Hipster Doofus
« Reply #27 on: Sun, 03 November 2013, 12:34:37 »
Thopre thime 4 u!!!11!
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
« Reply #28 on: Sun, 03 November 2013, 22:52:05 »
As with many things, "backlight frendliness" is a matter of subjectivity, and -judging my pointyfox's response here- much debate. I like imsto's thick PBT over backlighting, and think it looks superb. Sometimes I'll leave the green backlighting on and enjoy the effect.
o-ring compatability is mostly an issue with keycaps that have short stems (cherry F and J keys) and some SP keycaps. I think it's fine with imsto's PBT, but cannot confirm as I've yet to actually install my newly-rediscovered o-ring sampler pack.
I would suggest a keyboard without a plate to be a better mod board, as you can change switches, stems and springs more easily that. Try to get a non backlit pure and add your own LED's and "tune" your switches to your preference. The poker II keycaps don't let much light through, so your mileage may vary.
Offline keymaster
  • Topre Revolution Theorist
« Reply #29 on: Sun, 03 November 2013, 22:53:07 »
Wait for some cheap double-shot PBT from Vortex.
Offline tbc
« Reply #30 on: Sun, 03 November 2013, 23:13:12 »
I don't think that wait is very long...both massdrop and feng have groupbuys for them lol.
if someone could do a review of those DECK translucent doubleshot thick pbt keycaps, that would be awesome.  if they check out nice, i think a groupbuy for them would get alot of support.
« Last Edit: Sun, 03 November 2013, 23:14:59 by tbc »
Offline keymaster
« Reply #31 on: Sun, 03 November 2013, 23:17:58 »
Sorry, I was referring to the even newer DS PBT by Vortex posted on their Facebook. They're looking better and better.
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #32 on: Mon, 04 November 2013, 03:55:28 »
I wholehartedly agree on lubing one's keyboard, buy recommended lube and lube your keyboard up. It may most likely make your keys feel lighter to touch without having to go all out on getting a Topre keyboard.
I'm also suggesting this not purely because I want to rub in the goodness of having a Topre keyboard (as much as I would love to ...) but simply because I think there maybe are some beneficial factors if one is on a budget.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
Offline C5Allroad
« Reply #33 on: Mon, 04 November 2013, 14:41:58 »
How would those change the feel of the keyboard compared to the stock ABS caps?
Offline Linkbane
« Reply #34 on: Tue, 05 November 2013, 02:27:30 »
How about practicing?
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #35 on: Tue, 05 November 2013, 02:39:13 »
Is that your secret for speed! I need to know so I can type super fast.
Offline C5Allroad
« Reply #36 on: Tue, 05 November 2013, 13:30:39 »
Well yes that is one thing. But my current setup, my chair is too low and I am waiting on a new one so it's odd to type with my elbow drooping down so low with not support. Not neccearily help persay, but to make it feel nicer.
