Author Topic: Alcatel MFII Keyboard  (Read 7219 times)
Offline RimenX
« on: Mon, 04 November 2013, 12:41:40 »
Hi guys, what is your opinion on Alcatel MFII Keyboard? There is not much information about it on web, I found only that this keyboard is build on acer switches. If anyone know something about it post in this theard. Thanks for reply!
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
Re: Alcatel MFII Keyboard
« Reply #1 on: Mon, 04 November 2013, 15:59:39 »
Never used that specific keyboard, but the switches are ..... interesting.
The one thing about them that is really nice, is that—like with Fujitsu Peerless—they have a fairly delicate and unimposing click (at least, they do in the basic Acer 6311/6312 of which the MFII is a variant). They are the opposite end of the clicky scale from buckling spring and simplified Alps/Matias click switches.
On the other hand, it does take a fair amount of effort to force that gentle little click out — it's a switch for people with strong fingers.
Bore Awards
Offline genkidama
« Reply #2 on: Tue, 05 November 2013, 18:01:47 »
So what kind of switches are these acer switches? Like heavy blacks?
I only knew Alcatel as a cellphone company for low budget phones. So I'm curious about this keyboard as I never heard of something like this.
My finger training is over 9000!!!!
  • RIP
    • Boring twaddle
« Reply #3 on: Tue, 05 November 2013, 19:01:37 »
It's a clicky membrane switch.
Summary:
Alps-mount sliders. Alps-style click leaf, though a different shape.
Under the slider is a spring, which sits on a pivoting arm. The bottom of this arm has a nub that presses down on the membrane sheets.
If you pull a keycap, you see what looks like a switch (like Alps or Cherry), but it's just a support shell for the slider that snaps into the keyboard case itself. The shell is open at the bottom.
Somewhere there's probably a decent, comprehensive set of photos of one. My photos of the Acer boards are woefully incomplete — it's somewhere on my list to finish that off.
Bore Awards
Offline ComradeSniper
  • HHKB Pro
« Reply #4 on: Tue, 05 November 2013, 19:04:16 »
If there is interest I can pull mine apart.
« Reply #5 on: Tue, 05 November 2013, 22:14:35 »
I'm interested
  • HHKB Pro
« Reply #6 on: Tue, 05 November 2013, 23:43:53 »
Alright, here it is. Please excuse the dirtyness.
The sticker on the back
Upon removing a few screws and undoing some tabs along the sides of the case, it splits in half, revealing the plastic-plate mounted switches. The plate isn't held in by anything; it's just sitting there.
A close up of the controller -- looks generic to me, which is no surprise given that this is a membrane keyboard.
Removing the plate and flipping it over, we find the membrane sheets held in place by a steel plate which is screwed into the plastic plate.
After removing the steel backplate:
The switches push into the membrane sheet to actuate.
I couldn't figure out how to remove a switch from the plate or I would've taken pictures of that too. The Deskthority wiki has some pics of a disassembled Acer switch, though.
This was all I could think of, feel free to ask if there's something else you want pics of. I imagine the Alcatel board is very internally similar to this one.
« Last Edit: Tue, 05 November 2013, 23:46:45 by ComradeSniper »
  • RIP
    • Boring twaddle
« Reply #7 on: Wed, 06 November 2013, 02:32:50 »
It is a bit of a pain to get the "switches" out, yes. I think there's two or four tabs that have to be squeezed in from the top — it's been a while since I did this. Disassembling the switches is tricky too — IIRC, you have to carefully bend the click leaf around a small plastic protrusion somewhere.
It is a tad overengineered for what it does.
Bore Awards
Offline genkidama
« Reply #8 on: Wed, 06 November 2013, 05:38:32 »
Thanks for the pics ComradeSniper! Looks very neat, I wonder how the feel is.
This keyboard is not for sale anymore, is it?
  • RIP
    • Boring twaddle
« Reply #9 on: Wed, 06 November 2013, 14:19:21 »
Opinion varies, as with any switch. For me they're fairly comparable with stiff Alps clones (Xiang Min, Hua-Jie) — typing requires a fair amount of effort and you get missed keystrokes. Not a keyboard of choice for me.
Bore Awards
Offline osi
« Reply #10 on: Sat, 09 November 2013, 11:51:31 »
Always good to see different keyboards. Thanks for the pics
