Author Topic: ghetto brown ?  (Read 2498 times)
Offline dvjz.gh
ghetto brown ?
« on: Mon, 04 November 2013, 14:47:20 »
Is it so stupid the idea to take a poker 2 with browns switches and put inside 80g springs?
I have a CM Stealth with blue switches and i'd like to have a quite smaller keyboard with a more solid feel .
Thank you
Dan
Offline esoomenona
  • Gnillort?
Re: ghetto brown ?
« Reply #1 on: Mon, 04 November 2013, 15:07:24 »
We could call those Ghetto Clears. They might feel linear though. But its not stupid if it works for you.
Re: ghetto brown ?
« Reply #2 on: Mon, 04 November 2013, 15:11:07 »
From my notes here, the heavier springs paired with Browns felt linear like you said moose. But I also agree, if you like the switch, use it.
Offline divito
Re: ghetto brown ?
« Reply #3 on: Mon, 04 November 2013, 15:22:24 »
I can echo the sentiment of wanting a "more solid feel," having played with my QFS with Greens over the past few days. Definitely not stupid to try something out to see if it will work for you.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline dvjz.gh
Re: ghetto brown ?
« Reply #4 on: Mon, 04 November 2013, 16:15:02 »
Great post ! That is what i was looking for .
So it's seem better getting a poker with black switches if brown feels almost linears.
Offline davkol
  •  Post Editing Timeout
Re: ghetto brown ?
« Reply #5 on: Sat, 09 November 2013, 10:24:39 »
It's called tactoblack and it's mentioned at DT's wiki.
Offline dvjz.gh
Re: ghetto brown ?
« Reply #6 on: Sat, 09 November 2013, 10:43:39 »
Thank you .
I've  found also this thread http://geekhack.org/index.php?topic=13046.msg253364#msg253364
"from blue to ghetto brown".
I've just a poker2 from qtan with Browns . Maybe i like simples browns :-)
Offline zoolzoo
Re: ghetto brown ?
« Reply #7 on: Sun, 10 November 2013, 05:32:09 »
I have clear springs for sale if you want to try it.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
Offline dvjz.gh
Re: ghetto brown ?
« Reply #8 on: Sun, 10 November 2013, 11:56:31 »
Thank you .I'll try plane browns . i didn't know that if caps are plate mounted you have to desolder them .
I think in the future i'll buy a pcb and spares switches to play with
