Author Topic: Switch ID assistance  (Read 2028 times)
Offline 1391406
« on: Tue, 05 November 2013, 00:53:53 »
Anyone know what type of switch this is?
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
Re: Switch ID assistance
« Reply #1 on: Tue, 05 November 2013, 02:15:11 »
I have seen something similar in one of the electronic typewriters, looks similar to cherry, but the stems are slightly smaller & thinner. The backplate was rivetted and there was plastic/mylar underneath that. I assumed it was some sort of spring/dome underneath.
Does it feel clicky/tactile but not mushy? Then may be mechanical.
My 2 cents.
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
« Reply #2 on: Tue, 05 November 2013, 04:49:29 »
Ascaii has a keyboard from the same maker (Preh) with switches that look similar, but where the sliders are white.
It is slider over rubber dome.
Offline 1391406
« Reply #3 on: Tue, 05 November 2013, 08:02:17 »
Rubber dome. Disappointing.
Thanks, by the way.
« Reply #4 on: Tue, 05 November 2013, 17:05:07 »
MX compatible keycaps?
