Author Topic: IBM Model M/F tools  (Read 1534 times)
IBM Model M/F tools
« on: Tue, 05 November 2013, 09:41:16 »
not necessarily a "great" find, but if you are modding Model M/Fs a nut driver is much nicer than a socket, if a bit more expensive.
both models need the 7/32" and the F has a couple of 9/32" as well.
and, of course, everybody needs a 1/4" for computer case screws!
http://www.ebay.com/itm/390599966693?var=660138736906&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
- Plato
Offline 1391406
Re: IBM Model M/F tools
« Reply #1 on: Tue, 05 November 2013, 15:05:20 »
Nice find and nice price.
Offline Hellmark
« Reply #2 on: Tue, 05 November 2013, 15:52:55 »
When I started working on my M, I picked up a set of nut drivers from a local hobby store. They're a brand I hadn't heard of before (Dynamite). Set I snagged was metric, 4mm, 5mm, 5.5mm, 7mm and 8mm, and was $15 for the set. They seem to be of decent construction.
Offline 1391406
« Reply #3 on: Tue, 05 November 2013, 16:10:38 »
The 7/32 nut drivers at clickykeyboards are selling for $10.
Offline Hellmark
« Reply #4 on: Tue, 05 November 2013, 16:39:45 »
The ones at clicky look identical to the ones in the set I have. Only difference is that mine have red highlights instead of blue. Shape, finish of the metal, etc are all the same otherwise. Definitely not worth it at those prices, since you can get them so much cheaper elsewhere.
