Author Topic: Keyboard and mouse locations  (Read 4008 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Tue, 05 November 2013, 11:31:41 »
Any of you folks have the mouse and keyboard on different levels on your desk?  The reason I am asking is I am trying it out on my desk.  I have a full sized Das (costar built), Razer Orbweaver (modded), and a Razer Naga.  The tray under the desk is barely wide enough to really game on.  So out of coursity I moved the keyboard up to the top of my desk and left the pair of Razer products on the keyboard tray.  I have to say after a couple weeks I am actually liking the layout.
With being able to move my hands closer together during gaming it is tons more comftorable.  Plus, when I am typing(more than omw at least) it forces me to sit up right instead of slouching in my chair because the keyboard is so much farther away from my mouse/gamepad.
Just wondering if anyone else has tried it.
Melvang
Offline frvrngn
Re: Keyboard and mouse locations
« Reply #1 on: Tue, 05 November 2013, 11:41:29 »
I used to have mine setup opposite that way since I type more so wanted my keyboard at the right level.  I had no room so put my mouse up above.  Got weird wrist pains and it was pain moving back and forth all the time.  I made a wider tray so even with a full size board I can fit both together!  With my TKL boards I have a ton of room now.
If you can do it and its comfy, no need to change.
Currently using: Cherry G80-1800 Ergo Clears, HHKB Pro 2, RF 87U Silent
Offline Melvang
« Reply #2 on: Tue, 05 November 2013, 11:45:38 »
I didn't feel I needed to but when I was in heavy raid boss fights in WoW my Orbweaver would slowly migrate toward my Das and the spacebar would actuate and not let up until I moved my Orbweaver.  This actually killed me a couple times and wiped the group once.  Plus it opened up TONS of room for mouse movements.
Offline vun
  • Just one more thing
« Reply #3 on: Tue, 05 November 2013, 12:59:05 »
I don't have  a tray, all my devices are just sitting around on my desk, but I used to move my keyboard out of the way when gaming as I have an Orbweaver as well, but ever since I started using a higher dpi that hasn't really been necessary. Although now I use an edox, so I just stack one half on top of the other if I need more room.
Offline davkol
  •  Post Editing Timeout
« Reply #4 on: Wed, 06 November 2013, 06:14:23 »
I keep the keyboard lower (to maintain angle > 90° @ elbows), at school even on my lap. On the other hand, I prefer to rest my hand on the desk/tray while using pointing devices, thus it has to be higher.
« Reply #5 on: Wed, 06 November 2013, 06:35:56 »
I do not game, and have a huge keyboard, but I use mice on both sides. Very handy.
Good thing I have a large desk.
- Oliver Willis 2026-08-01
« Reply #6 on: Thu, 07 November 2013, 04:09:36 »
I guess for gaming it would work, but when you do most other things you (right) hand needs to move between the mouse and keyboard, and I find that the closer together they are the easier that is.
I have transitioned to TKL (except my Model M - can't find a reasonably priced SSK) so the mouse is closer, that suffices for me.
Offline Willy
« Reply #7 on: Thu, 07 November 2013, 15:38:01 »
My tray has a little shelf for the mouse that slides out. It's about  2 inches lower than the keyboard tray. having the mouse down low does feel a lot more ergonomic than when I put it my desktop.
QFR - Blues
Offline SamirD
« Reply #8 on: Sat, 09 November 2013, 07:05:56 »
I try to keep my IBM M about a foot away from my hands.  This way, my elbows are actually resting on the desk and I can keep papers that I'm working on right in front of me.  I keep the trackball to the right, but try to pull it in closer than the keyboard to keep my shoulder and neck from straining.
Offline ctbear
« Reply #9 on: Sun, 10 November 2013, 21:57:54 »
I have them on the same level (same table top). Makes it slightly easier to move my right hand to the keyboard.
Offline Calcifar
« Reply #10 on: Wed, 13 November 2013, 16:07:42 »
quite even really. sometimes i move my keyboard to my lap.
