Author Topic: How does my website look?  (Read 13272 times)
Offline zwmalone
« on: Sun, 04 January 2009, 19:49:33 »
I just updated my website to a little more modern design.  What do you think?  It probably won't look good unless you have a resolution of 1280x1024 or higher.   Comments or suggestions?  Design tips?
Most of it was done in NotePad++ with some finishing touches done in Dreamweaver CS3.
link: http://zacherymaloney.exofire.net/  If it isn't working my webhost (I tried hosting on my home 768k/128k line, it doesn't work) is trying to foil me again.
Can't get enough of them ALPS
Offline sandy55
« Reply #1 on: Sun, 04 January 2009, 20:35:39 »
zwmalone, where did you get an image "ALPS.png" listed in download>geekhack?
Want to read the source page if it contains detailed information about ALPS Leaf spring switch.
Offline zwmalone
« Reply #2 on: Sun, 04 January 2009, 20:39:15 »
That is the patent image.  I believe I found it in the GeekHack tshirt thread so you may find a link there.
Offline D-EJ915
« Reply #3 on: Sun, 04 January 2009, 20:42:11 »
that diagonal stripe has to go or make it so it just borders the content like on here (like 10-15pixels or so)
Offline zwmalone
« Reply #4 on: Sun, 04 January 2009, 20:43:34 »
What should I replace it with?
Offline zwmalone
« Reply #5 on: Sun, 04 January 2009, 20:55:01 »
Quote from: sandy55;17062
This may be of some use:
http://www.patents.com/Click-type-push-button-switch-improved-leaf-spring/US5004880/en-US/
http://www.wikipatents.com/5004880.html
Offline iMav
  • geekhack creator/founder
« Reply #6 on: Sun, 04 January 2009, 21:35:14 »
You've got issues.
Check it.  Probably due to other *.exofire.net sites...I would ditch that webhost if I was you.
Offline zwmalone
« Reply #7 on: Sun, 04 January 2009, 21:36:24 »
Woa, I guess I'll be switching Web hosts.  Thanks iMav.
Now I just gotta find a decent free web host... Anybody know a good one?
Offline bhtooefr
    • bhtooefr.org
« Reply #8 on: Sun, 04 January 2009, 21:41:57 »
While it's technically not free... freeshell.org is good, IMO.
($1 to activate the account by mail, $5 to activate it by PayPal.)
Offline zwmalone
« Reply #9 on: Sun, 04 January 2009, 21:57:48 »
Thanks bhtooefr.  I just created an account.
I think I qualify for this:
Quote from: Freeshell.org join page
Allows an enrolled student at an accredited college or K-12 to be validated by a qualifying 'instructor'. The account provides a student with the 'USERS' benefits, as well as development tools of the 'ARPA' membership. The student retains this access join the 'ARPA' membership or are made 'USERS' after the semester.
Offline bhtooefr
    • bhtooefr.org
« Reply #10 on: Sun, 04 January 2009, 22:08:20 »
Sounds like it's not quite the full ARPA membership, and using it as a webhost, you won't get the ARPA benefits.
Offline sandy55
« Reply #11 on: Sun, 04 January 2009, 23:39:16 »
zwmalone, thanks for the large image.
Though the image is a white/click switch ( which is a variation of linear switch used in lowpoly's Toshiba T5200 board ) and is not the one for alps leaf spring switch in you page, the link you introduced is very useful. It even corrected my thought.
I think I'd better get an account of patent com to obtain full data.
Offline itlnstln
« Reply #12 on: Mon, 05 January 2009, 01:14:47 »
Quote from: zwmalone;17072
Geocities
Offline bhtooefr
    • bhtooefr.org
« Reply #13 on: Mon, 05 January 2009, 01:19:46 »
Just look up the patent number on Google Patents. :)
Offline lam47
« Reply #14 on: Mon, 05 January 2009, 03:58:34 »
Sorry I honestly couldn't look at it for too long the diagonal stripes are horrible.
Might be because I have a large screen I don't know but it physically hurt, sorry.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #15 on: Mon, 05 January 2009, 04:09:44 »
Ditto on the stripes. I damn near had to go on a killing spree after looking at your page for a minute. Good thing the pizza came.
Offline andb
« Reply #16 on: Mon, 05 January 2009, 04:34:49 »
Yeah, look for a more attractive, subtle background. At least reduce the contrast on these stripes, but either a solid or a less strong image is in order. Check out http://colourlovers.com/ for background images. You need to work on your box model. Padding + Border + Margins aren't set right. Example, the body text should have some space from the grey containing div.
BTW, dont use dreamweaver if you really want to be good at design. Make it in photoshop. Write the HTML, at first you should largely stick with known good templates, because interbrowser compatibility requires a lot of odd stuff. Then add in the CSS and cut up images from photoshop to get your end result.
Go step by step, don't try to learn it all at once. For example, take a PSD from a template site and try to make it into the html / css. Or make a PSD and ask for feedback if its good. After all, there really are two distinct phases of site creation, the creative impulse and the technical realization of the idea.
Offline zwmalone
« Reply #17 on: Thu, 08 January 2009, 22:27:14 »
Found new hosting:
A friend of mine is a reseller for Epik-Host so I got the business package for a one time flat fee of $7.50!!!
Offline djones
« Reply #18 on: Fri, 09 January 2009, 17:34:26 »
Quote from: iMav;17071
You've got issues.
:confused: What is that site? Who cares if some random site says your site is suspicious.
Offline iMav
« Reply #19 on: Fri, 09 January 2009, 18:10:55 »
Quote from: djones;17665
That's not just some random site.  That's TrustedSource, the most comprehensive Internet host reputation system in the world.  His hosting service is flagged as malicious because it has been identified to be hosting phishing sites and malware.
Offline bigpook
« Reply #20 on: Fri, 09 January 2009, 18:21:55 »
I think thats where the stripes come in...
Offline andb
« Reply #21 on: Mon, 12 January 2009, 04:39:26 »
The problem with budget hosting is just that - its cheap. Not only in the sense of price, but also in quality. The best thing to do is find a buddy who runs his own server and have him server your pages. Its not like you are getting slashdotted or anything.
With any professional service you get  what you pay for. Would you use a cheap heart surgeon? Of course setting up a VPS with slicehost (which is the lowest end of what I'd consider doing for webhosting) isn't for everyone. But do keep in mind - you get what you pay for.
Offline zwmalone
« Reply #22 on: Wed, 14 January 2009, 15:22:31 »
It lives!
ThinkServer (ThinkPad 600 w/o Keyboard, LCD, battery):
192MB of PC100 SODIMM RAM
300MHZ Intel Pentium II Mobile
12GB 2.5" IDE HD
RedHat Linux Server 5.2 w/ Apache, MySQL, ProFTP
45W Wall adapter
802.11g/b Wifi Adapter
Offline zwmalone
« Reply #23 on: Wed, 14 January 2009, 15:24:43 »
It lives!
ThinkServer (ThinkPad 600 w/o LCD, keyboard, battery):
12GB 2.5" IDE HD
45W Wall adapter
It's not set up yet though :p
Offline DMuk
« Reply #24 on: Thu, 15 January 2009, 15:21:10 »
Hi. If your site is intended to appeal to paying customers, it's very poor. Here's why:
1. The stripes are awful and likely to scare away any potential customers.
2. The About page. Customers are not going to be interested in your 'rig' or your love of gaming. It's not relevant to them.
3. The Contact page makes no sense. You say you will reply within in two days unless you can't! Why not just say you will reply as soon as possible? You then shout at me that you I must NOT attempt to contact you by any other means. Like what exactly - astral projection?
I know you are only fifteen, but if you want to make money, you have to look at things from the customers perspective. Good luck.
Offline zwmalone
« Reply #25 on: Fri, 16 January 2009, 15:39:37 »
I've taken everybody's criticisms and I'm creating an entirely new div container based  in lieu of a table based design that I'm currently using.  The stripes will be gone (but what to replace it with?) and I'm going to go with a more colorful layout (Gray, Orange and ?).  Hopefully it works out a lot better this time.
Offline iMav
« Reply #26 on: Fri, 16 January 2009, 15:42:45 »
Quote from: zwmalone;18432
I actually like the stripes.  :)
Offline D-EJ915
« Reply #27 on: Sat, 17 January 2009, 00:11:16 »
since some people like the stripes and others don't why not make them flash on and off!!
not being serious of course, haha
Offline xsphat
  • Enlightened
« Reply #28 on: Sat, 17 January 2009, 00:13:57 »
How about this: Stripes - goatsie - stripes - goatsie, flashing.
Offline DMuk
« Reply #29 on: Sat, 17 January 2009, 15:23:37 »
Customer: Hi. I'd like a new website please.
zwmalone: Sure thing. What thickness and color do you want the diagonal stripes?
Customer: Erm, any chance of NO stripes?
zwmalone: No stripes? Quit wasting my time! Next.
Sorry. Couldn't resist.
Offline zwmalone
« Reply #30 on: Sat, 17 January 2009, 21:21:26 »
I've taken the stripes to a whole new level just for you DMuk :p
Finished the basics of my new layout:
http://zacherymaloney.exofire.net/WIP/
What do all the web experts think?
It's still very much a work in progress (only have the layout finished) and the CSS isn't done yet for things like links, header tags, etc.
Just a side note, none of the links work yet :p
Offline zwmalone
« Reply #31 on: Sat, 17 January 2009, 21:26:55 »
Quote from: xsphat;18459
I'm trying to run a web design business, not a shock site!
EDIT: This is my first entirely CSS based design.  If I did anything wrong please tell me.
If you missed the link (I posted again and it went to the 3rd page) it's http://zacherymaloney.exofire.net/WIP/
I'm gonna try to get it moved onto my makeshift server tomorrow...
Offline D-EJ915
« Reply #32 on: Sat, 17 January 2009, 21:56:42 »
the subdued stripes look a lot nicer
Offline zwmalone
« Reply #33 on: Sat, 17 January 2009, 22:00:12 »
Thanks.  Did you notice any errors in my CSS?  I'm trying to get all the problems worked out before I finish it.
Edit: For anyone who is interested, the css is here: http://zacherymaloney.exofire.net/WIP/main.css
Offline D-EJ915
« Reply #34 on: Sat, 17 January 2009, 23:41:41 »
I don't have any experience with that so I can't help you with that, sorry!
Offline lowpoly
« Reply #35 on: Sun, 18 January 2009, 07:07:59 »
http://validator.w3.org/
The logo.png is a bit blurry?
Offline zwmalone
« Reply #36 on: Sun, 18 January 2009, 11:25:32 »
It validated in Dreamweaver, I was just wondering if there was a more "correct way" to do things.
As for the logo it has a drop shadow and outer glow.  It's really just filler until I can create a more fitting header image.
Offline zwmalone
« Reply #37 on: Wed, 21 January 2009, 16:14:50 »
I got new hosting :D  Business class!  No more free hosting for me!
Offline cmr
« Reply #38 on: Wed, 21 January 2009, 17:35:14 »
i think this div needs padding: 4px
Offline zwmalone
« Reply #39 on: Wed, 21 January 2009, 17:35:53 »
I'm not using that design anymore.
Offline cmr
« Reply #40 on: Wed, 21 January 2009, 17:40:49 »
ah okay. found the new one, it was on the only page i hadn't checked (oops)
stripes.png doesn't appear to tile properly:
Offline zwmalone
« Reply #41 on: Wed, 21 January 2009, 18:01:00 »
I finally got moved to the new host: http://zwmalone.dabananabunch.com/
