Author Topic: Cherry G80-XXXX  (Read 1463 times)
Offline C5Allroad
  • Formerly HUNTERANGEL121
Cherry G80-XXXX
« on: Tue, 05 November 2013, 20:38:19 »
Are they all PCB mounted boards? Looks like a great project board. :D
Offline inlikeflynn
  • file not found
Re: Cherry G80-XXXX
« Reply #1 on: Tue, 05 November 2013, 20:54:27 »
for like 99.5% of the g80-xxxx boards the answer will be yes they are PCB mounted switches
Shameless plug that I have a cap less g80-8113 for sale over here: http://geekhack.org/index.php?topic=50017
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline C5Allroad
Re: Cherry G80-XXXX
« Reply #2 on: Tue, 05 November 2013, 21:03:24 »
Oh ok thank you!
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Cherry G80-XXXX
« Reply #3 on: Tue, 05 November 2013, 23:32:09 »
Yes all but some rarer earlier models and the newest 3850 are PCB mount. You can pick up several common models for real cheap a lot of the time and they certainly are easy to work on for doing mods to.
