Author Topic: SPRIT Model 1 Case : Poker 60% 75% 87% 110% + Ducky, Filco, Leopold  (Read 91941 times)
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
Re: SPRIT Model 1 : Cases for Poker 60% 75% 87% 110% + Ducky, Filco, Leopold
« Reply #100 on: Sat, 16 November 2013, 06:09:28 »
SPRIT  Model 1    Metal Cases   Pics will come in a Week.!
« Last Edit: Sun, 17 November 2013, 03:53:22 by sprit »
Offline bianco
« Reply #101 on: Sat, 16 November 2013, 06:18:17 »
looking forward to it! thank you Sprit
Offline Dubsgalore
« Reply #102 on: Sat, 16 November 2013, 12:29:51 »
Can't wait to see those!
lamborghini keyboard!
Offline AKmalamute
  • HHKB Scrub
« Reply #103 on: Sat, 16 November 2013, 12:31:32 »
When I'm able to buy a 75% case, I'll get a matching PCB. Hoping for metal also but we'll see how it plays out.
So, of the 60% and the 75% I hope to acquire, I guess I'll sell one of them. Hafta buy the parts, first.
HHKB-lite2, Dvorak user
Offline jabar
« Reply #104 on: Sat, 16 November 2013, 12:33:09 »
TKL TOP Cover under Cover Now.   It will show When ths MOQ meets.  Sorry for That!
How much MOQ is required for 94%? the 94% isn't very common... and I'm willing to pay a bit more for a lower MOQ. It's essentially TKL with a few more cut outs.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline taylordcraig
« Reply #105 on: Sat, 16 November 2013, 18:59:59 »
Very excited to see the 75% metal cases.
My Race is in the mail.
Offline tjweir
« Reply #106 on: Sun, 17 November 2013, 03:50:09 »
I am as well.  It's a decision to make some wood cases, or buy this thin-framed metal ones.
My wallet is ready.
Offline catbuster
  • Fusion is Future
« Reply #107 on: Sun, 17 November 2013, 05:06:48 »
Uh 60% metal case  :)
Poker 2 (black) 60% mx red
Offline Latin00032
« Reply #108 on: Sun, 17 November 2013, 07:06:06 »
11:30  yes!
Offline sprit
This GB is some strange and different?
1. Started by me with some Ideas, and some Open source PCB guys.
2. I am in charge of all the project.  Blame me for all.
3. I am doing the Design and Patents Jobs in Korea to Protect my designs from the others.
4. I've been updating the PCBs and Cases, and the YouTube Movies.  I posted them as much as possible. as you seen in my updates.
5. Why am I doing this? :
I want to unite all the private custom practices into a quite open source based standard, as the Porker 60% showed us.
6. The Results? : You can easily get any compatible PCB, change it's SW functions, and put it into any compatible case, as the Poker 60% compatibles showed us.
7. Why No Final Pics yet? :  The PCB have been evolved even since this GB started, the firmwares updated, fixed, more ideas to improve its functionality. PCB Patterns are modified and refined.
8.  Why the MOQ matters?  :  The PCB production under 20 pcs is too expensive as we know. Over 50 pcs, it's quite OK, to put all the Color options and SMDs pre-solderd, and some other options.
9.  When the payment opens, In two weeks, We will get New PCBs and Cases !
10. Again, What is this GroupBuy for?  : For a better Compatibility, more Open Source Based keyboard life.
http://www.youtube.com/watch?v=jhdFe3evXpk
« Last Edit: Sun, 17 November 2013, 10:55:44 by sprit »
Offline sprit
Order Form OPEN !
Offline bianco
Re: [Order] SPRIT Model 1 Cases : Poker 60% 75% 87% 110% +Ducky, Filco, Leopold
« Reply #111 on: Sun, 17 November 2013, 09:17:30 »
why isn't there an option for a clear polycarbonate case for 110%?
Offline sprit
« Reply #112 on: Sun, 17 November 2013, 09:46:41 »
As We know, PolyCarbon is too strong to cut by a Laser cutter, So they do CNC mechnical machining.
So the surface has a lot of scratches, etc.  So Hairline, or Mattie finish required.    Result?   Not clear, but Frosty, Mattie.  Alas!
« Last Edit: Sun, 17 November 2013, 09:51:16 by sprit »
Offline bianco
« Reply #113 on: Sun, 17 November 2013, 09:59:45 »
understood and thanks for the explanation, sprit
Offline jabar
« Reply #114 on: Sun, 17 November 2013, 10:32:49 »
so... is 94% not happening? Your reply to my post wasn't clear.
Willing to pay a reasonable premium for 94%.
Phantom 7bit
Offline sprit
« Reply #115 on: Sun, 17 November 2013, 10:52:58 »
94% PCB, Not in this 1st wave of GB.  Shot of MOQ.   I feel bad for it!   I will do it Next month!  Promise!
The 87 and 94% cases are  Compatible!
« Last Edit: Sun, 17 November 2013, 11:29:42 by sprit »
Offline hermith
« Reply #116 on: Sun, 17 November 2013, 11:39:07 »
There, just ordered. But not sure if I did it correctly.
Offline sprit
« Reply #117 on: Sun, 17 November 2013, 13:58:04 »
75% Dark Green 1 set for hermith,   OK?     :)
Offline anhvu
« Reply #118 on: Sun, 17 November 2013, 14:05:36 »
Clear Case Pic.  for Amir !
A Round Cut Version is  Available !
How do I get a clear case like that?
Offline elllit
« Reply #119 on: Sun, 17 November 2013, 15:00:40 »
So, will this case gb going on until the metal cases show up?
I'm not sure if I want acryl or metal, but I also don't want to be stranded without a case at all ;)
Offline hermith
« Reply #120 on: Sun, 17 November 2013, 15:32:41 »
Sounds good!
« Last Edit: Sun, 17 November 2013, 15:38:20 by hermith »
Offline Acanthophis
« Reply #121 on: Sun, 17 November 2013, 15:47:00 »
Interested in a metal 87 for my Phantom. Is it Phantom compatible, though? Didn't find anything in the OP.
Offline pasph
« Reply #122 on: Sun, 17 November 2013, 16:16:15 »
"compatible" but different, i suppose
Offline Permeability
« Reply #123 on: Sun, 17 November 2013, 16:19:10 »
Hi Sprit, can you maybe show some pictures on how acrylic is different from polycarbonate cases? Besides the material used.
Keyboards:
'The Cheat' - lubed 62g Clears
Ducky Shine 3 TKL lubed 45g Reds (Work)
Offline sprit
« Reply #124 on: Sun, 17 November 2013, 18:26:46 »
Thanks!  You Got me! Amico!    :thumb:     " compatible, different, and better "   I am   SERIOSO!
« Last Edit: Sun, 17 November 2013, 19:10:35 by sprit »
Offline Latin00032
« Reply #125 on: Sun, 17 November 2013, 18:57:59 »
What's the difference between polycarb and acrylic?
Aren't they similar?
Offline pasph
« Reply #126 on: Sun, 17 November 2013, 18:58:40 »
The 87% case which type of pcb can fit in addition to the SPRIT  Model 1?
Offline sprit
« Reply #127 on: Sun, 17 November 2013, 19:06:30 »
You can Look  :  What is the Title Of This Topic ?
Offline sprit
« Reply #128 on: Sun, 17 November 2013, 19:08:50 »
Similar !  in Chemistry !     PolyCarbon is harder, harder for Your Fingers    :)
Offline pasph
« Reply #129 on: Sun, 17 November 2013, 19:09:07 »
http://www.coloradoplastics.com/blog-0/bid/42625/
Offline pasph
« Reply #130 on: Sun, 17 November 2013, 19:11:11 »
So they can fit both KMAC and Filco?
Offline sprit
« Reply #131 on: Sun, 17 November 2013, 19:14:06 »
http://geekhack.org/index.php?topic=50037.msg1090018#msg1090018
Amico  !!    Similar !  They are!!   than Metal,  on Your Fingers!       I've study Molecular Chemistry and Work... bla  bla  bla...
But,  This is Our Subject : ' What is Better  For Your Fingers ?
« Last Edit: Sun, 17 November 2013, 19:38:24 by sprit »
Offline ithinkimkorean
« Reply #132 on: Sun, 17 November 2013, 19:36:43 »
Submitted an order form. Hope clear with white in the middle looks good.
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
« Reply #133 on: Sun, 17 November 2013, 19:39:16 »
I'm a bit confused on the form, sprit. Most of it makes sense, but I'm curious about the "2nd address for emergency" and "Acry case : Color Options (3 Layers) : Which Color You like ?" fields. Is the Acry case field supposed to just be the colors we are choosing in the layer color options?
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
« Reply #134 on: Sun, 17 November 2013, 19:40:27 »
I was confused too. I just put "none" for second address and left the "Which colors" field black since it wasn't required.
Offline sprit
« Reply #135 on: Sun, 17 November 2013, 19:43:15 »
You can put a Dot  .   You have 3 Color choices for Your 3 Layered Case.
44549-0 44557-1  44559-2  44561-3  44563-4  44555-5
« Last Edit: Mon, 18 November 2013, 01:36:05 by sprit »
Offline funkymeeba
  • CRUMPULAR
« Reply #136 on: Sun, 17 November 2013, 19:46:29 »
Thanks, guys! Order in shortly! :D
Offline Kit-Bar
« Reply #137 on: Sun, 17 November 2013, 20:13:01 »
So does the polycarb come in different colors? Are they similar to the acrylic color, just different feel?
Also are there any pictures of the polycarb versus acrylic?
« Last Edit: Sun, 17 November 2013, 20:16:25 by Kit-Bar »
Offline sprit
« Last Edit: Sun, 17 November 2013, 21:18:16 by sprit »
Offline Latin00032
« Reply #139 on: Sun, 17 November 2013, 21:38:39 »
Am I the only one confused on how I'm supposed to fill out the form?
Offline swill
  • builder & enabler
    • swillkb.com
Offline sprit
Offline sprit
« Reply #142 on: Mon, 18 November 2013, 01:38:36 »
That gonna be Superb !!  One Of My Favorite!    You Got a White PCB ?  and a Clear Plate?
44721-0
« Last Edit: Mon, 18 November 2013, 02:52:58 by sprit »
« Reply #143 on: Mon, 18 November 2013, 02:57:21 »
Convinced me to order those too.  :thumb:
Can I pay extra for you to solder the switches on?  ;)
Offline sprit
« Reply #144 on: Mon, 18 November 2013, 09:08:15 »
Thx!   Some members asking Soldering and assembling Service for me, But Extra Time and delivery care will be troublesome for me.
SO for now I 'd like to recommend  those Services in America.
Offline Acanthophis
Re: [Order] SPRIT Model 1 Cases : Poker 60% 75% 87% 110% + Ducky, Filco, Leopold
« Reply #145 on: Mon, 18 November 2013, 13:24:21 »
Well?
Offline AKmalamute
  • HHKB Scrub
« Reply #146 on: Mon, 18 November 2013, 14:48:05 »
My understanding is the phantom was built to be filco compatible. So if his case is filco compatible, by extension the phantom should work fine.
Offline PepperPanda
« Reply #147 on: Mon, 18 November 2013, 15:20:44 »
Just a little confused. So after the first week the order for wave 1 is closed. Then do the people who ordered wave 1 choose the other options such as thin/thick. Or are those options only available for wave 2 and beyond.
Offline Acanthophis
« Reply #148 on: Mon, 18 November 2013, 16:50:17 »
False logic.
Example:
If it rains, the street is wet.
But was there neccessarily rain, if the street is wet? ;)
Yes, the Phantom was designed to fit into a Filco. But, for example, Vortex' alu case doesn't fit (without mods) the Phantom. It has no stand offs, the case relies on the Filco plate.
Offline vecrios
« Reply #149 on: Mon, 18 November 2013, 18:37:38 »
I'm a newbie in this field and trying to build my own custom keyboard, so excuse my dumb questions  :D
First of all, if I join this GB, would the parts I get be assembled? If not, would I need anything other than the things you are offering?
