Author Topic: SPRIT Model 1 Case : Poker 60% 75% 87% 110% + Ducky, Filco, Leopold  (Read 91943 times)
Offline stoic-lemon
Re: [Order] SPRIT Model 1 Cases : Poker 60% 75% 87% 110% + Ducky, Filco, Leopold
« Reply #150 on: Mon, 18 November 2013, 22:08:36 »
Assuming you get a case, pcb, switches, LED's (optional) and a plate (optional), you need to solder them in. You also need caps to put on the switches.
Offline vecrios
« Reply #151 on: Mon, 18 November 2013, 22:47:48 »
I have experience soldering, I have a Raspberry Pi to play with from time to time. So, that shouldn't be a problem. I guess what's really worrying me is that I don't know what is compatible with what, like if I do my own combination of parts.
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #152 on: Mon, 18 November 2013, 23:08:24 »
Sample Order Form  for  Kang-nam  Street
44837-0
« Last Edit: Tue, 19 November 2013, 09:48:56 by sprit »
Offline taylordcraig
« Reply #153 on: Mon, 18 November 2013, 23:16:14 »
Just want to make sure you mark me down as interested in a metal 75% case.
Offline sprit
« Reply #154 on: Tue, 19 November 2013, 04:06:19 »
Welcome to Color Spamming Division !!
44877-0
« Last Edit: Tue, 19 November 2013, 04:11:03 by sprit »
Offline sprit
« Reply #155 on: Tue, 19 November 2013, 13:04:10 »
Guys!  Can You Imagine What is 3-Layered Case?   I think It is Nice for LED effects !  and good Looking.
« Last Edit: Tue, 19 November 2013, 13:48:15 by sprit »
Re: [Order] SPRIT Model 1 Case : Poker 60% 75% 87% 110% + Ducky, Filco, Leopold
« Reply #156 on: Tue, 19 November 2013, 13:28:25 »
My understanding is the phantom was built to be filco compatible. So if his case is filco compatible, by extension the phantom should work fine.
False logic.
Example:
If it rains, the street is wet.
But was there neccessarily rain, if the street is wet? ;)
Yes, the Phantom was designed to fit into a Filco. But, for example, Vortex' alu case doesn't fit (without mods) the Phantom. It has no stand offs, the case relies on the Filco plate.
Allow me to introduce you to Abductive logic.
See, the above is a great example of faulty deductive or inductive reasoning, but a potentially correct abductive logical process.
For example:
I know that when it rains at night, the grass is wet in the morning (for the purposes of this example, we will assume such knowledge was arrived at by deduction and is therefore infallible).
So, I get up in the morning and the grass is wet. I can abduce that it has rained at night.
Like inductive reasoning (science is big on this) it can be false, but new information is gained.
Of course the "best" logical process is deduction, where it can't be wrong, but no new information is gained.
Such is the problem with Logic and Epistemology.
now: more on topic
It's hard to know for sure, but there are a few things I can say.
#1 cherry switches use T1 size LEDs. 2*3*4 will also fit. The LEDs available in this GB will fit in any MX switch.
#3 If you know how to solder, you should be able to put this together. Soldering through hole switches and LEDs is all you need.
#4 Plate is optional, but if you go without a plate, PCB mount switches are a must. While not strictly necessary, a LED will help stabilize the switch if you go without a plate and is recommended even if you don't plan to use backlighting.
#5 The NKRO diodes and LED resistors are surface mount and already soldered.
#6 The controller is also soldered and should be updated with firmware to get you started quickly.
Now, if you want to use your own parts
#1: Any T1 LED will fit, and the PCB should be able to drive diodes with Vfs as low as 1.6V, which covers all common LEDs and colours. 1.5Vf should probably work too.
#2: The PCB should fit in other cases, though which ones it's hard to say. If you post a picture I can probably size up the mounting holes and check.
#3: Depending on which PCB, it should support switches in many layouts, and also be compatible with your own plate. I will probably be using a rosewill plate I have for the 100%
#4: All cherry MX switches should fit. Get PCB mount if you are not using a plate.
Did I leave anything out? please ask specifics.
Did I get anything wrong? I hope not, but please PM me or post if I did and I'll correct / update it.
Offline YongJK
« Reply #157 on: Tue, 19 November 2013, 18:23:58 »
Dear anyone,
any idea that this 87 pcb will fit in a kmac2 ?
I am plannnig to desolder everything and use the original plate from kmac2 and move to this new pcb.
« Last Edit: Tue, 19 November 2013, 18:28:27 by YongJK »
Keyboard: PLU ML87 Mx Blue
Offline sprit
« Reply #158 on: Tue, 19 November 2013, 19:16:35 »
Dear anyone,
44979-0 A  87%  (Old version)
KMAC2    http://www.kbdmod.co.kr/product/detail.html?product_no=10&cate_no=4&display_group=1
« Last Edit: Tue, 19 November 2013, 19:35:48 by sprit »
Offline Vintage
« Reply #159 on: Tue, 19 November 2013, 19:26:42 »
Any pics showing the difference between the lime green and dark green acrylic?
Also, will there be winkeyless top cover options?
CM QFR w/ MX Reds  | Logitech G900
Offline sprit
« Reply #160 on: Tue, 19 November 2013, 19:33:17 »
I am Witnessing Lime Green Middle Layer is Glorious for almost Every Combo.
Just Green is a Calm Green~
« Last Edit: Tue, 19 November 2013, 19:42:28 by sprit »
Offline sprit
« Reply #161 on: Tue, 19 November 2013, 19:34:39 »
The Way of Epistemological Analysis is enjoyable to Follow. A little bit hard for me,
but  it shall be a Good Soul Food for me  :)
« Last Edit: Tue, 19 November 2013, 21:25:41 by sprit »
Offline sprit
« Reply #162 on: Tue, 19 November 2013, 19:36:49 »
Just Green is a Calm  Green!~~
There is Winkeyless (WKL) Top Cover !  100% Sure~!  I will Fix  the OP
« Last Edit: Tue, 19 November 2013, 19:42:19 by sprit »
Offline Vintage
« Reply #163 on: Tue, 19 November 2013, 19:41:21 »
Sweet.  :D
So hard to pick a color scheme ;)
Offline justnits
« Reply #164 on: Tue, 19 November 2013, 22:23:22 »
hi sprit!
i am still waiting patiently for your metal case pictures to be posted ;D
but i've been wondering how is the case's bottom going to be like?
is it a flat straight like First Blood case (needs feet for elevation)
or is it angled like kmac's case?
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline sprit
« Reply #165 on: Tue, 19 November 2013, 22:32:31 »
hi sprit!
Hello!  Justnits  !  How are You?
" Both!  "    This will be a proper Answer?   We are doing Pre-MOQ check,  I am doing Patents and Design Registrations in the Korean Government.
It will show Soon!    The Major Parts of My Design will be shared in GH, I promise!
« Last Edit: Tue, 19 November 2013, 22:35:54 by sprit »
Offline sprit
« Reply #166 on: Tue, 19 November 2013, 22:39:41 »
I don't want tease You,  just This Case needs every Proper Process to sell in this GB.
« Last Edit: Tue, 19 November 2013, 23:01:55 by sprit »
Offline justnits
« Reply #167 on: Tue, 19 November 2013, 22:50:26 »
 :thumb: love your answer :D but unfortunately, it's getting more exciting now, the urge to pee gets stronger when people feel excited  :-X
hi sprit!
Offline archer
« Reply #168 on: Wed, 20 November 2013, 00:01:16 »
Submitted an order for clear/frosty/clear 87% and another order for a frosty/clear/frosty 75%.
Thanks Sprit xD
Offline Keytrun
« Reply #169 on: Wed, 20 November 2013, 00:02:39 »
I'm confused. Which one of these will a Filco fit into? Are they metal or acrylic? How does it compare to the aluminum vertex case for filco? Does it have feet?
Offline Kit-Bar
« Reply #170 on: Wed, 20 November 2013, 00:49:35 »
will the QFR fit in this? I assume they are similar to the filco
Offline sprit
« Reply #171 on: Wed, 20 November 2013, 04:45:22 »
A Coffee  Break !    Getting Cold here in Seoul
45036-0   45034-1
Offline sprit
« Reply #172 on: Wed, 20 November 2013, 04:47:21 »
The Case drilled for QFR will show if You Really Want iT,  I Promise!
« Last Edit: Wed, 20 November 2013, 04:55:30 by sprit »
Offline sprit
« Reply #173 on: Wed, 20 November 2013, 05:16:46 »
Cyrilic  Orange  of my Friend !     http://www1.kbdmania.net/xe/photo/7663375  by ChemBro45038-0    45040-1
Offline sprit
« Reply #174 on: Wed, 20 November 2013, 05:21:43 »
Cherry 300 Mouse
« Last Edit: Wed, 20 November 2013, 05:25:40 by sprit »
Offline sprit
« Reply #175 on: Wed, 20 November 2013, 07:22:35 »
Orange,  Lime Green        >>  http://www1.kbdmania.net/xe/photo/7677397
45113-0
45115-1
« Last Edit: Wed, 20 November 2013, 10:15:23 by sprit »
Offline Latin00032
« Reply #176 on: Wed, 20 November 2013, 09:36:44 »
Are the aluminum cases going to be layered like the acrylic or is it one whole piece.
Offline Vintage
« Reply #177 on: Wed, 20 November 2013, 10:21:48 »
Any chance of getting more pics showing the acrylic cases form the sides and bottom?
And any pics of the different anodized alu plate colors?
Offline AnalogBlu
« Reply #178 on: Wed, 20 November 2013, 11:04:00 »
I'm interested in this case, but I have a few questions!
1) Is the 87% keyboard universal? Or are you making a different case for Filco and a different case for Leopold?
2) Are you making a keyboard with a metal top plate and acrylic sides? If so...  :eek:
Offline sprit
« Reply #179 on: Wed, 20 November 2013, 11:08:27 »
2) Are you making a keyboard with a metal top plate and acrylic sides? If so...  :o
You can Read this Topic and Order Form.  I guess You Will find a Solution For You!!
Offline sprit
« Reply #180 on: Wed, 20 November 2013, 11:10:01 »
Hush!  My Friend!    :o    ;)
« Last Edit: Wed, 20 November 2013, 18:39:28 by sprit »
Offline AnalogBlu
« Reply #181 on: Wed, 20 November 2013, 11:39:12 »
I've read through many of the threads, but it's still not clear if the case will fit BOTH Filco AND Leopold (since I'm using a Leopold and may switch the case over to a Phantom PCB). If I understand, the Vortex case couldn't fit both (with the stock plates), so this concerns me. Second, I'm wondering if aluminum can be mixed with acrylic, or if the aluminum case is a completely different option
« Last Edit: Wed, 20 November 2013, 11:42:51 by AnalogBlu »
Offline sprit
« Reply #182 on: Wed, 20 November 2013, 12:00:07 »
45132-0
The Way Fit into the Case Tested already,  IF more than the MOQ= 15,  I can do this For You Guys!
Order Form updated for Filco, Leopold, Ducky, CM 87%  and 110%
« Last Edit: Wed, 20 November 2013, 17:37:21 by sprit »
Offline archer
Re: SPRIT Model 1 Case : Poker 60% 75% 87% 110% + Ducky, Filco, Leopold
« Reply #183 on: Wed, 20 November 2013, 15:04:51 »
Your order form says "you can change your order at any time".. how do I do this? I need to update my 87% case order to reflect that I need it fit an 87% Ducky/Filco.
Or do I just submit another order?
Offline Vintage
« Reply #184 on: Wed, 20 November 2013, 16:15:19 »
When are the Alu case pics coming? Very excited to see them  :p
Offline sprit
« Reply #185 on: Wed, 20 November 2013, 18:38:04 »
You can Change, or Resend Your Order Form at Anytime before the Payment. !!
« Last Edit: Wed, 20 November 2013, 18:44:07 by sprit »
Offline sprit
« Reply #186 on: Wed, 20 November 2013, 18:43:37 »
Offline bladegesnow
« Reply #187 on: Wed, 20 November 2013, 20:50:23 »
A new order form sent XD
More and more and more...
Offline sprit
« Reply #188 on: Wed, 20 November 2013, 20:56:13 »
Your Order Transmitted!   Got Received!
Offline sprit
« Reply #189 on: Wed, 20 November 2013, 21:24:24 »
A Cofe Break !
45194-0  45196-1
Offline sprit
« Reply #190 on: Thu, 21 November 2013, 09:17:49 »
The Thanks Giving Day in USA ?   :)
« Reply #191 on: Thu, 21 November 2013, 09:23:24 »
Thanksgiving is a week from today Thursday the 28th
Offline sprit
« Reply #192 on: Thu, 21 November 2013, 09:28:53 »
Oh ! Thanks Mr. Beard!
« Last Edit: Thu, 21 November 2013, 10:53:05 by sprit »
Offline kektr0city
« Reply #193 on: Thu, 21 November 2013, 10:51:42 »
pleeeeeeeeeeeease post the aluminum case already!
Offline sprit
« Reply #194 on: Thu, 21 November 2013, 10:56:32 »
OK !  Kektr0city   ;)         The 1st Wave of Order is near  MOQ,  and needs to go into Production.
The 2nd Wave of Order Will open on 25th.   The Alu case will show soon !  Probably on 27th, Wednessday.
« Last Edit: Thu, 21 November 2013, 11:05:46 by sprit »
Offline goobus
  • HHKB Elite
« Reply #195 on: Thu, 21 November 2013, 11:25:30 »
Sprit, what do you have me down for?  I submitted a new order but I'm not sure what I actually signed up for :P
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #196 on: Thu, 21 November 2013, 12:03:43 »
I'm curious as well. I don't know if the earlier spreadsheet was deleted when the form was added.
Offline sprit
« Reply #197 on: Thu, 21 November 2013, 18:19:26 »
Sprit, what do you have me down for?  I submitted a new order but I'm not sure what I actually signed up for :p
HK   87% Case  1 /   Black Clear Red
= for each layer    ;)
« Last Edit: Thu, 21 November 2013, 18:21:21 by sprit »
Offline sprit
« Reply #198 on: Thu, 21 November 2013, 18:28:00 »
' The Previous PCB Order Form I'  -  It was well Saved to the safety Box in a
Vault.
I served as an AirForce Intelligence Officer in the ROKAF, working with the 7th Pacific USAF.
I will send  THE ORDER Confirmation eMail  from Today, before The Payment.
« Last Edit: Fri, 22 November 2013, 05:35:41 by sprit »
Offline sprit
« Reply #199 on: Fri, 22 November 2013, 05:05:07 »
45399-0
