Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 2223994 times)
Offline cookiesowns
Re: SPRIT Model 1 : Poker 60% 75% 87%1 10% ANSI+ISO (Full LED+HW Macro) <Production>
« Reply #1000 on: Fri, 13 December 2013, 06:33:02 »
Notice !
The Invoices for the Orders from Nov.17-20  Will sent Tomorrow!
Thanks For Your Patience!!   :)
Sent you a PM sprit! =)
Also, do people recommend plate mounted switch or PCB mounted? I have plates of course.
Offline bazh
« Reply #1001 on: Fri, 13 December 2013, 06:56:22 »
yay, hope I'm on the list :D
HHKB Pro2 white
Newbie again
Offline bakteria
« Reply #1002 on: Fri, 13 December 2013, 06:59:13 »
You have PM Spirit!
SS 7G black - Pure red - poker blue (MKC Tray)
Offline Jinryuixi
« Reply #1003 on: Fri, 13 December 2013, 08:16:55 »
Invoice nº 1309 paid! I want to know if you recieved it correctly! :thumb:
It has to be this one:
The "frosty" color it's a light blue, right? :P
Offline AlexJP
« Reply #1004 on: Fri, 13 December 2013, 09:25:13 »
Hello Sprit...
Could you check my order? its a 60% pcb black, a lime green (3 parts) polyacryl case, 110 clears switches, and some 80gr springs, green leds and 20 multicolours leds. almost  forgot... a 5mm plate too
Really  anxious for this : )
 :thumb:
btw: again.. amazing work, amazing GB and amazing you!
« Last Edit: Fri, 13 December 2013, 10:18:11 by AlexJP »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #1005 on: Fri, 13 December 2013, 09:50:51 »
Notice !
I would recommend getting PCB mounted switches because they are more versatile.  If you want to do PCB mounted, you have the option.  If you want to do plate mounted, you just clipping off the plastic bits on the bottom of the switch and they are now plate mounted switches.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #1006 on: Fri, 13 December 2013, 10:54:41 »
This might be a stupid question, but do these PCBs support USB?
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #1007 on: Fri, 13 December 2013, 10:58:11 »
THey are mini USB if im not mistaken! :)
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #1008 on: Fri, 13 December 2013, 11:16:30 »
I found the answer.  I remembered that I had seen ps2avr, but it was actually ps2avrU.  Here is a link to the firmware: http://winkeyless.kr/entry/ps2avrU-firmware-%EB%B0%8F-utility (use google translate).
It says: "ps2avrU - PS / 2 and USB interface supports both the new firmware."
Offline gimpster
« Reply #1009 on: Fri, 13 December 2013, 12:15:13 »
Order placed for pcb and plates.
Pre-check placed for metal case (Sure hope this comes through).
-Ryan
Offline AKmalamute
  • HHKB Scrub
« Reply #1010 on: Fri, 13 December 2013, 12:58:50 »
I'd love to get 10lbs of aluminum case ... but I can't until at least March ... and it might not work out even then. But I'd love to see them made / shipped so I can buy a spare in the classifieds if it turns out I have the dough at that time.
I have a request, regarding the ALPS boards. Since I suspect a fair number of us wanting that series already have, and are satisfied with, our own switch supply ... Spirit, can you consider making the boards available sans newly minted korean switches?
I really appreciate that you're making this GB a one-stop-shop for do it yourselfer's needs. But it's okay too, to provide just the PCBs and say "This is all I have. Get the rest elsewhere."
I bet if you did, you could still move 50 Alps boards easily enough ... one wave down, the third wave for pcb+switch kits.
HHKB-lite2, Dvorak user
Offline Zeal
    • Zeal Generation Inc.
« Reply #1011 on: Fri, 13 December 2013, 13:11:41 »
I've always wondered, why can't you use PCB mounted switches in a plate mounted design without clipping the two tabs? Doesn't this PCB support both types of switches? So, since there are already two extra holes, wouldn't keeping the two tabs on the switch increase the rigidity of the switch when plate mounting? Or am I blatantly ignorant/blind? Haha
Anyone care to enlighten me? :p
« Last Edit: Fri, 13 December 2013, 13:13:12 by Zeal »
Offline AKmalamute
  • HHKB Scrub
« Reply #1012 on: Fri, 13 December 2013, 13:13:58 »
I'd ways wondered, why can't you use PCB mounted switches in a plate mounted design
Having never done it, I'm pretty sure the holes for PCB-mount are the issue. So you could, so far as I know, use PCB (/NW) switches inside a plate. Making everything line up might be more work but that would be about the only issue.
Offline archer
« Reply #1013 on: Fri, 13 December 2013, 13:40:35 »
Hey Sprit,
Just sent you payment for the following invoice:
#1232 - 87% Acryl case: Clear/Frosty/Clear
Could you please verify that this is for a Filco compatible case (it should be!). The colors are correct.
Thanks again for organizing all of this!
Offline exitface
« Reply #1014 on: Fri, 13 December 2013, 14:42:57 »
Paid invoices #1274 and #1261, thanks Sprit!
Offline gimpster
« Reply #1015 on: Fri, 13 December 2013, 15:39:24 »
I've done this on two keyboards. So long as the PCB has the holes drilled for the stabilizer pins, then you can leave them on. In fact, I prefer to do this because it makes for an even more stable switch with the plate. I can feel the difference on a standard "sheet" plate, but it's really not noticeable on a thick plate, like the MX Mini or like the 4/5mm plates being offered here. Still, it's one less task to do when you're assembling things, so I would leave them on. :)
-Ryan
Offline cultofjosh
« Reply #1016 on: Sat, 14 December 2013, 00:04:30 »
Invoice #1303 paid!
I hope you do more buys in the future so I can get some of your cases :D
Offline cookiesowns
« Reply #1017 on: Sat, 14 December 2013, 01:28:05 »
Heyo,
Anyone know if it's Micro USB or Mini-USB?
http://winkeyless.kr/49
Looks to me like USB Mini?
« Last Edit: Sat, 14 December 2013, 01:36:51 by cookiesowns »
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #1018 on: Sat, 14 December 2013, 06:47:01 »
Sorry for Late Answer to the PM (Personal Message) :  I got Family Meet Ups on this Weekend!
mini USB !
« Last Edit: Sat, 14 December 2013, 06:54:59 by sprit »
Offline longweight
  • philanthropist
« Reply #1019 on: Sat, 14 December 2013, 12:28:38 »
I still have not received an invoice?
Offline IMHB
« Reply #1020 on: Sat, 14 December 2013, 12:30:44 »
Same here...only received 1 60% case invoice and payed....still have pcb+plate and another 80% case invoices which I didn't get....
Offline AlexJP
Me neither
Offline sprit
« Reply #1022 on: Sat, 14 December 2013, 20:23:32 »
I am sending Invoices By Today!
Payment become so Slow for this 1st Round.
It tooK too much Time to make HongKong Paypal Guys to understand What is GB.
If you need, PM me plz!
Thank You Guys!      :)
« Last Edit: Sat, 14 December 2013, 20:32:14 by sprit »
Offline AlexJP
« Reply #1023 on: Sat, 14 December 2013, 20:51:14 »
First invoice paid!  :thumb: :thumb: :thumb: :thumb:
(pcb, switches, plate, springs and leds)
now just need the case (limegreen, limegreen, limegreen)
 :p
Thanks Sprit
Offline sprit
« Reply #1024 on: Sat, 14 December 2013, 20:57:51 »
 :p
Thanks Sprit
Green Limes Sent!   :)
« Last Edit: Sat, 14 December 2013, 21:03:21 by sprit »
Offline AlexJP
« Reply #1025 on: Sat, 14 December 2013, 21:09:45 »
Thank you Mr Sprit.    :D
both invoices 1317 and 1318 paid.
I hope this GB continues on much more time so I can purchase the other keyboards.
ps: sorry for causing trouble with the first orders.
 :thumb:
Offline Latin00032
I thought we would have reached moq for metal cases by now. :(
Offline sprit
Hello!  Mr. Latin00032 !
Not well answered,  But  I will Show The Metal Proto in This Week!    :)
Offline sprit
« Reply #1028 on: Sat, 14 December 2013, 21:51:59 »
 :thumb:
Great Thanks Guys!  for Your Patience  for my Paypal resetup issues!     :)     It Took too Long!
Have a Nice Weekend All!!
« Last Edit: Sat, 14 December 2013, 22:10:10 by sprit »
Offline tjweir
« Reply #1029 on: Sun, 15 December 2013, 09:11:09 »
Me either.  Just adding my comment so I don't miss out on this.
Thanks Sprit!
Offline cookiesowns
« Reply #1030 on: Sun, 15 December 2013, 09:53:21 »
 :thumb:
Hi Sprit,
I sent you PM regarding invoices.
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #1031 on: Sun, 15 December 2013, 10:41:48 »
Do you send all invoice, sprit? I still don't receive your invoice :(
Offline pasph
I want to change my shipping address.
Sent you a PM.
Offline sprit
Sent you a PM.
OK  I Send me PM !   :)
Offline sprit
Re: SPRIT PCBs : 60% 75% 87% 100% : ANSI+ISO (Start 09:00~)
« Reply #1034 on: Sun, 15 December 2013, 18:04:15 »
I am Sending the Last Invoices !  Sorry For late!   :)
Offline bakteria
« Reply #1035 on: Sun, 15 December 2013, 18:38:09 »
Havent recieved a reply from you yet Spirit.
I ordered 90 switches but it said 110 on the receipt. I did however pay because I was afraid of missing out.
So would it be too much of a bother if I got 90 clear switches and 20 black switches?
Also I'd like plate switches.
Offline sprit
« Reply #1036 on: Sun, 15 December 2013, 18:46:07 »
GodMorgon !   1 Sec plz  !
OK!  I can do  90 Clear + 20 Black SW!  :)     Thank You Mr. BakTeria!  Sorry For late Answer!!
48101-0
I changed It to 90 Clear + 20 Black SW !
48103-1
« Last Edit: Sun, 15 December 2013, 19:00:39 by sprit »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #1037 on: Sun, 15 December 2013, 18:50:43 »
My understanding is that if you are using this PCB, then you can use PCB mounted switches even with a plate.  If you are using most on this pcb and the rest on a different pate mounted pcb which does not have the holes, you can always just clip those switches.
Offline bakteria
Tack så mycket Spirit! You are 50 shades of awesome! And since the pcb switches fit on this with plate go for pcb.
Thank you for clearing this up for me.
Offline justnits
« Reply #1039 on: Sun, 15 December 2013, 19:08:07 »
sprit, have u receive my PM?
sorry about sending u PM twice...i thought i didn't send u the first time >.<
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline sprit
« Reply #1040 on: Sun, 15 December 2013, 19:17:35 »
Your Acryl Case is already in Production, So It's not Easy to change at this moment.
And the Refund is not Possible, for this is a GroupBuy, meet MOQ for all the members.
Sorry for that !   :)
« Last Edit: Sun, 15 December 2013, 19:21:08 by sprit »
Offline justnits
« Reply #1041 on: Sun, 15 December 2013, 19:40:56 »
alright, sure :) no problem with that
Offline sprit
« Reply #1042 on: Sun, 15 December 2013, 20:16:56 »
Really Sorry For that,  If It had been 1 week earler!
Offline justnits
« Reply #1043 on: Sun, 15 December 2013, 20:19:25 »
no worries sprit, i'm still very eager to see your metal case :)
Offline bazh
« Reply #1044 on: Sun, 15 December 2013, 20:38:35 »
I still don't get the invoice, I'm really worried about this right now :(
HHKB Pro2 white
Newbie again
Offline cookiesowns
« Reply #1045 on: Sun, 15 December 2013, 21:32:03 »
Sprit, I sent you an PM, not sure if you got them. I need the PayPal invoice e-mail changed, and it seems like there was an error about on the invoice.
Offline keymaster
  • Topre Revolution Theorist
« Reply #1046 on: Sun, 15 December 2013, 22:07:23 »
Paid my invoice and received notice of shipment currently pending.
 :cool: :cool: :cool:
Offline sprit
« Reply #1047 on: Sun, 15 December 2013, 22:17:37 »
OK  I am sending the last Invoices Now, and  I will check Your Invoice Soon!  Sooorrry for any Errors!!   :)
« Last Edit: Sun, 15 December 2013, 22:21:11 by sprit »
Offline jorgenslee
« Reply #1048 on: Sun, 15 December 2013, 22:24:33 »
Hi Sprit, Good day and I hope you have a great weekend with your family. I would like to ask if my order will be included in this batch of invoices you have sent and will send. Thanks
Offline cookiesowns
« Reply #1049 on: Sun, 15 December 2013, 22:48:12 »
Great! Thanks for all the hard work Sprit!
Another question to be sure: It goes from Bottom to top right? So the first option ( bottom ) on the form, is the part where the case touches the table correct?
