Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 2127757 times)
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
Hi Sprit, I sent you a second form to order stabs but got no invoice for it.
Is it normal or not?
Hello ! Mr. JPG !   :)
I have been watching the MOQ and QTY for Stabilizers.  And I ordered Last week.    :)
And I will send The Shipping Invoice with the newly added orders and parts (LEDs, Springs, Stabs..)   :)
I have started sending The Shipping Invoices!   Really Appreciate For Your Support and Patience!!  ;)
« Last Edit: Mon, 13 January 2014, 10:17:47 by sprit »
Offline winged mantis
Do the plates allow for switch disassembly?
Offline HPE1000
  • Keycap Paparazzo
Thanks again sprit :D
 :thumb:
Offline TheSoulhunter
  • ~ BOOO ~
Paid!
A Ghost From The Past
Offline sprit
Hello!  winged mantis! :)
Yes! The plates allow for switch to disassembe!
Offline lilky
Will the keyboard come fully assembled or will we be putting it together ourselves? I saw Sprit say they do come fully assembled, but some of the others are saying this is not true. Which is it?
Also, if you order a TKL, will the top cover be all acrylic/metal, or will it be black plastic like in this picture: http://geekhack.org/index.php?action=dlattach;topic=50580.0;attach=47055;image
Offline lotus1109
Hi Sprit, please check your pm ya  :)
Offline HPE1000
  • Keycap Paparazzo
The first round is just going to be complete PCBs, by that I mean its going to have all the SMD soldering done for you so all you need to do is add the switches and put it in a case. Sprit is going to offer a service for the 2nd round where you can have people assemble it for you, from what I understand.
Offline lilky
By "add the switches" do you mean soldering the switches to the PCB?
Offline HPE1000
  • Keycap Paparazzo
Yes
And by "put in a case" I mean that I will type on the flat PCB over cardboard.
Offline sprit
Top cover will be Provided!  The Pic shows  Commercial PCBs into my Case, Sorry for confusion!
Round 1 GB is basically Self-assemble,  Round 2 is You can Choose Parts, All assembled (SWs, Diodes, LEDs, etc)    :)
« Last Edit: Mon, 13 January 2014, 22:21:26 by sprit »
Offline witbliz
Sprit, can I hold my 1st round order so that your team can assemble it ? Or should I cancel and wait for your second round to happen ?
Offline lilky
If we participate in round 2, can we choose the spring weight AND switch type?
Offline kennyk64
I've already ordered but I'm still waiting for the metal case...
Poker II  Shine II  Realforce 87u
Offline sprit
This is pasph's Idea for the AT/XT style Layout !   :)
What is Your Idea?   ;)
50863-0
« Last Edit: Tue, 14 January 2014, 07:01:02 by sprit »
Offline WinterIsle
It's too long, I will rather get a full size keyboard instead of this.
Offline distel
Jip, its too long for my taste.
80% of the desk full with one keyboard.
Offline sprit
What about  Left Num Pad?   :)
Offline WinterIsle
Left numpad i bet more than half of ppl will not utilize it, unless as macro keys setup.
Just cut out that left side f-keys will be looking much better.
Offline distel
I would be in if the numpad is on the left instead of the right side and the right side is cut away.  I like it much more when left and right hand are closer together.  But thats only me.
Offline pmh1410
Sprit, your Red Aluminium housing case is nice. I want order it :)
Offline AKmalamute
  • HHKB Scrub
I'd just like to throw my $.02 in, and say that proposed XT layout, apparently suggested by Pasph but presented by spirit, looks fine. It would be better than a conventional layout in a few ways, and certainly unique enough to justify paying for a custom keyboard.
As much as I dearly want to order an aluminum case, I probably can't afford it for any size; too many other things making claims on my income.
 Also, while I'm very appreciative of the assembly services being offered, I've already gotten the switches for the particular PCB I'll be getting -- namely the ALPS board, so I won't need any extra assembly,  but might pick up extra stabilizers and possibly MX compatible springs for other projects I'm in the middle of.
HHKB-lite2, Dvorak user
Offline pasph
I will retry  :D
Just for fun
Offline HPE1000
  • Keycap Paparazzo
I will retry  :D
Just for fun
I think the third one is the best.  :thumb:
Offline pasph
Maybe the numpad can be put on both sides like this
Offline apotheosis
Would it be possible to use the full-size case to house a das-keyboard (with usb modification) or fullsize Topre Realforce 104UB or would the PCBs not fit? If so I'd buy 2 of full size metals.
Also, you have fields for metal cases in two of the forms links. Would we need to submit both?
Offline sprit
Spring Samples  :
Now 50g / 55g / 60g / 62g / 65g / 68g / 70g / 80g / 100g / 120g  under Production
50927-0
« Last Edit: Tue, 14 January 2014, 19:36:46 by sprit »
Offline sprit
Basically It fits, of cause, Need a Mod for Screw Connexion and USB.   :)
Actually My case design started 2 years ago, for my Filco 87% and Full size and The Poker.
I am working on, I will show soon, Sorry for the Delay!
« Last Edit: Tue, 14 January 2014, 18:45:34 by sprit »
Offline sprit
Yes! You are 110% Right!     :)
110% Model are designed for the Both Side Num Pad !
50915-0                50913-1
« Last Edit: Tue, 14 January 2014, 19:31:09 by sprit »
Offline HPE1000
  • Keycap Paparazzo
Spring Samples  :
Sexy! What are the springs on the left side?
Offline sprit
Spring Samples  :
It's Dark Vintage MX Blue Spring from G80-1501 made in 1996.
« Last Edit: Tue, 14 January 2014, 19:27:46 by sprit »
Offline HPE1000
  • Keycap Paparazzo
Spring Samples  :
They look cool :D
I am trying to figure out how many different types of gold springs I want to order now, I know I am going to get two sets of 120g springs, a set of 65g, maybe even 62g  :rolleyes:
Can I still order springs? I've got a bunch of spring mods I've been looking to do.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
I will retry  :D
Just for fun
I would buy this in a heartbeat, I nearly bought the Lightsaver but the missing gap between the numpad and alphas was really off putting.
Offline sprit
I will retry  :D
Just for fun
I Love  1  & 3  for myself.   :)     I'd like to call No.3 : Tenkeyless 75%  ?!?
I always need a Gap between Alphas  and Arrows or Num Pad  !
I respect the Others may want a compact Layout!   :)
« Last Edit: Wed, 15 January 2014, 01:29:43 by sprit »
Offline distel
I think I end up ordering in 2nd round as well as. damn sexy all that stuff.
Offline Sai
Hi spirit, do you have any price estimation for All-Assembled Full-Set from 2nd round gb ? and how long till the end date for 2nd round ?
Offline witbliz
Paid my invoices and can't wait for the metal casing design to be showcased... Sprit will it be possible to show me how the gun metal grey will turn out ?  and how does multicolored LED look like with the orange LED ? confused slightly haha.
Offline sprit
I am sending Shipping Invoices by This Weekend,  Please Wait Guys!   :D
Offline fuus
  • All Year Christmas!
Yey sprit  :cool:
Filco - Browns
Past: Ergodox - Reds / IBM SSK / Spirit 87% - Clears / Dell AT101W
Offline baldgye
  • Will Smith Disciple
Sprit have you posted pics of the TKL cases yet?? :P
Offline cookiesowns
Cool! How long does it take to ship from Korea to California?
Offline meiosis
  • Time
I've gotten some of mine in 4 business days. Normally under 2 weeks for sure though. Most likely looking at around 7 days though it's normally customs that makes it spontaneous
Keyboards:
Aripeko TKL
Offline keymaster
  • Topre Revolution Theorist
When will you send invoices for the separate orders for stabilizers and springs? If I had ordered a PCB and case, could you ship everything together? Thanks, sprit.
Offline swill
  • builder & enabler
    • swillkb.com
Depends on the shipping method.  To Canada from China it has been taking between 7 days and 30 days...
Offline mooswa
Sprit, you have mentioned that 2nd group buy will be open Jan 17th, but there is a link on OP to an OPEN 2nd order.  Do I wait for 17th or order now via that link?
Can anyone summarize what are the pros and cons of not using a plate for a 60%?
Offline sprit
The EMS sent to NY took 4 days.  To California should be the same or less, I guess.    :)
Offline ninjadoc
When are you shipping the first round of PCB's and plates?
Offline sprit
Hi~ moosa !  :)
2nd GB ready, So I opened earlier,  Sorry for Confusion!   :)
This is just my very personal Opinion :
< Using a Metal Plate for a 60%  : Pros  and Cons? >
Pros  : Solid, Rigid, Stable Key Touch and Slider movement, good for 62g +
Cons : Hard, Stiff, Sometimes painful for the Soft Key Touch Users under 60g.
< Using a Acry Plate for a 60%  : Pros  and Cons? >
Pros  : Solid, Rigid, Stable Key Touch and Slider movement, with Overall Softness. and You can Enjoy the PCB Colors and Better LED effects.
Cons :  Thin Acryl may breaks, but Thick Acryl are Solid enough. Weak to the Scratch, Need a Soft brush ro clean.
