Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 2128124 times)
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
Re: <Full Assemble GB Open!> SPRIT Model 1 : PCB + Case + Parts ..
« Reply #1550 on: Sun, 19 January 2014, 08:24:16 »
any pics of the TLK front plate yet? ??? ? >.<
Hello! balddye!  :)
TLK front plate is same as Normal.
I added New connection methodes with Plate/PCB.
I will Post it !
Offline jorgenslee
« Reply #1551 on: Sun, 19 January 2014, 08:39:58 »
Hi sprit, what's the difference between the pcb mount and plate mount stabilizer? Is there a way change in feel of the switch? What's the advantage and disadvantage? Sorry, I try to search for an answer but I can't find a reliable one.
Thanks, also pm sent.
Offline tjweir
« Reply #1552 on: Sun, 19 January 2014, 08:44:26 »
Paid for my shipping, less than expected!  Hooray.
Offline pasph
« Reply #1553 on: Sun, 19 January 2014, 08:51:32 »
Sprit i've sent you a PM with a modified stabilizer order, can you please check it?
Thanks.
Offline sprit
« Reply #1554 on: Sun, 19 January 2014, 08:51:51 »
There have been a lot of discussions on Stabilizer Type among Korean Users.
To Summarize :
- PCB mount Type   :  Soft landing to PCB.   Sometimes gives a dull, too soft Key Touch to the Keys.  Slider has narrow feet and nails.
- Plate Mount Type :  Hard landing to PCB.  The Slider hits PCB more Clear. Slider has thicker feet and Flat. No nails.
- My Mods     :     Cut the Nails and Feet, mod PCB-mount Sliders as Plate-mount Sliders, giving them more Clear, Solid Landing.
http://www.kbdmania.net/xe/tipandtech/7331383
http://www.kbdmania.net/xe/best_article/5437092
51597-0    51599-1    51601-2
« Last Edit: Sun, 19 January 2014, 09:57:18 by sprit »
Offline BlueBär
« Reply #1555 on: Sun, 19 January 2014, 08:55:31 »
Hey sprit, I sent you a PM.
Offline sprit
« Reply #1556 on: Sun, 19 January 2014, 09:44:07 »
90% of the Shipping Invoices Sent!   :)
Offline Latin00032
« Reply #1557 on: Sun, 19 January 2014, 09:58:20 »
How come there are only two pieces to the metal plate but their are three for the acrylic?
How can I order the case that supports the gh60 in the hhkb layout? I see it in the pictures but I want to make sure I order the right one. Also, where do I put this information in the form?
Offline osxoep
« Reply #1558 on: Sun, 19 January 2014, 11:39:02 »
I'm not sure I can solder SMD components... Anyone got a tutorial?
HHKB Pro JP with hasu's controller (waiting for MX sliders)
Offline bakteria
« Reply #1559 on: Sun, 19 January 2014, 11:47:02 »
I read a lot of posts about people worrying about assembly, has something changed?
No more "pop in the switches and chat with your friends "in OP
SS 7G black - Pure red - poker blue (MKC Tray)
Offline shrapneL
« Reply #1560 on: Sun, 19 January 2014, 12:18:08 »
#1423 paid, Sprit! Thanks again :)
hello.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #1561 on: Sun, 19 January 2014, 14:03:13 »
so the possibly exists to get one one these in alps fully assembled- just like one one of mx boards in sometime in in feb?
orange, salmon, matias, green and cream are the choices?
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #1562 on: Sun, 19 January 2014, 14:06:44 »
i have not read through all 53 pages, but since i am here maybe someone knows
can this be done in a 87 key alps winkeyless?
« Reply #1563 on: Sun, 19 January 2014, 14:40:47 »
No ALPS yet.
but soon.
Offline cookiesowns
« Reply #1564 on: Sun, 19 January 2014, 16:21:40 »
Yes. SMD/Through hole diodes will not be pre-soldered unfortunately. You'll have to do it yourself. However, if you don't mind waiting longer for your boards, you can have sprit do them for you.
This is just for the original Group 1 & 2 preorders.
Offline Melanic
You should be okay as long as you didn't order a 110%.
OK!  I will work on All Doides Pre-soldered By hand, For 60% and 75%  and 87% PCBs for 1st GB.
The Last Problem is the Resistors for LED.
I will ask Everyone on that in the Invoices or PM,  Who need this.  :)
The Estimated Time for the Soldering Resistors on a 60% PCB is  20-25 min for me.  All are Free!
And for the future...
For the 2nd GB Batch,  I am going to Produce Each 100pcs of Factory-Presoldered 60%, 87% PCB. [/font]
75% and 110% PCB are to be Hand-Soldered.
Offline bakteria
« Reply #1566 on: Sun, 19 January 2014, 17:27:49 »
I got a 60% so I guess I don't have to worry then. I've done quite a bit of soldering before so if it's not too small and I get some instructions I should be ok.
Offline justnits
« Reply #1567 on: Sun, 19 January 2014, 22:12:29 »
Sprit, i sent you a pm :)
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline lotus1109
Re: &lt;Full Assemble GB Open!&gt; SPRIT Model 1 : PCB + Case + Parts ..
« Reply #1568 on: Sun, 19 January 2014, 23:52:53 »
Paid the shipping invoice and check your pm Sprit! :)
Offline BigBrother
« Reply #1569 on: Mon, 20 January 2014, 00:52:54 »
How much is just a cherry PCB?
Offline Zeal
    • Zeal Generation Inc.
« Reply #1570 on: Mon, 20 January 2014, 01:12:38 »
60%, 75%  PCB    :  Fixed Price  50 USD
87%, 110%  PCB  :  Fixed Price  55 USD
+$3 GB fee
+PP fee
+Shipping to you.
Offline sprit
« Reply #1571 on: Mon, 20 January 2014, 01:23:25 »
PCBs Under Soldering :   The Controller and Parts + Diodes + USB Connector
The Firmware and Keymaps  :  Installed and Tested before Shipping.
Soldering Resistors :   For Who ordered LEDs, and Anyone with Your Request PM.
51664-0
« Last Edit: Mon, 20 January 2014, 04:20:11 by sprit »
Offline BigBrother
« Reply #1572 on: Mon, 20 January 2014, 01:31:29 »
+$3 GB fee
+PP fee
+Shipping to you.
50$ for a bare PCB? really?
Offline sprit
« Reply #1573 on: Mon, 20 January 2014, 01:43:52 »
You can read the Order Page.
From This 2nd GB, All Parts are Pre-Soldered.
« Last Edit: Mon, 20 January 2014, 01:46:52 by sprit »
Offline BigBrother
« Reply #1574 on: Mon, 20 January 2014, 02:10:07 »
All the parts as in...? The diodes and bypass caps and such?
Offline justnits
« Reply #1575 on: Mon, 20 January 2014, 02:15:20 »
Soldering Resistors :   For Who ordered LEDs, and with Your Request PM.
sprit, i didn't order led from you because i already have led, do you provide resistors as well?
also, you got pm, in case u didn't see it :P
Offline MrChunky
« Reply #1576 on: Mon, 20 January 2014, 04:04:06 »
So I see that cases are now included together with all the other components in the order form. Does that mean that we need to use that form even if we just want to order the cases? What happened to the MOQ forms for the metal cases?
Thanks for the work Sprit! I cant wait for the PCBs to arrive :thumb:
Offline GeorgeK
« Reply #1577 on: Mon, 20 January 2014, 05:33:51 »
Apologies if this is in the thread somewhere but what are the dimensions of the PCBs on offer?  (Not % but actual dimensions in mm)
Thanks
GK
Offline numiru
« Reply #1578 on: Mon, 20 January 2014, 05:57:42 »
Hi sprit, can you please double check shipping invoice 1478? I had a PCB, acryl plate, and some springs.
KUL ES-87
Offline codyeatworld
« Reply #1579 on: Mon, 20 January 2014, 06:19:35 »
The amount of updates in this thread is awesome. I wish I had more ends for some pcbs and cases.
« Reply #1580 on: Mon, 20 January 2014, 06:35:20 »
Thanks
GK
Hah, I was after the same thing, and ended up pulling the dimensions of the 110% from teh DWG on winkeyless.kr's 'site. It should be similar.
The numbers I got were 428.625mm * 122.7895mm, which should be about right.
I plan on screwing mine to a chunk of metal, and it looks like 0.25*5" round edge stock is about perfect. Getting it cut to 17" is pretty cheap online and should weigh about 1Kg. I'll drill and tap through holes, bolt the PCB on and call it a kb case.
Offline sprit
« Reply #1581 on: Mon, 20 January 2014, 07:09:26 »
Hello!  numiru !   :)
Yes!  I have checked Your Order before sending the Shipping Invoice!   :)
60% PCB 1 White , Acryl Plate 5mm frosty , Spring 110pcs Gold Edition 65g .
Offline sprit
« Reply #1582 on: Mon, 20 January 2014, 07:21:46 »
Thanks
GK
Hello!   GeorgreK  !   :)
60% PCB is    285mm x 92mm
75% PCB is    307mm x 117mm
87% PCB is    348mm x 123mm
110% PCB is  428mm x 123mm
Note!  :  This PCBs are a little bit Smaller in 0.5 mm than the Others!
« Last Edit: Mon, 20 January 2014, 07:36:34 by sprit »
Offline sprit
« Reply #1583 on: Mon, 20 January 2014, 07:25:05 »
Yes!  You are Right!   :)
110% PCB is  428mm x 123mm   a little bit Slimer in +- 0.5mm range.
Why It's a kb Case?
« Last Edit: Mon, 20 January 2014, 07:28:10 by sprit »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #1584 on: Mon, 20 January 2014, 07:30:32 »
Thanks
GK
It's not in the thread.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #1585 on: Mon, 20 January 2014, 07:33:21 »
Thanks
GK
Thanks sprit. :)
Offline sprit
« Reply #1586 on: Mon, 20 January 2014, 07:33:33 »
Hello!  MrChunky!  :)
Yes! One Order Form    :)    for better and quicker updates and management.
Metal Case MOQ Form is collected and I am reviewing the GeekHackers' Opinions.
The 1st GB started just for PCBs and Cases in the begining .... After All, It become a quite a Bigger one  :(
Trying to Overcome The Obstacles and Delays!!
« Last Edit: Mon, 20 January 2014, 07:52:50 by sprit »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #1587 on: Mon, 20 January 2014, 07:38:00 »
Thanks
GK
You could go one step further and build my case. How are you planning to insulate the electrical components from the metal plate?  Standoffs?
Offline sprit
« Reply #1588 on: Mon, 20 January 2014, 07:46:38 »
Oh!  My!    ..   :D   Mistaking put an answer to a PM... On here !   :o
(Edited)
51688-0
« Last Edit: Mon, 20 January 2014, 08:10:02 by sprit »
Offline Latin00032
« Reply #1589 on: Mon, 20 January 2014, 10:26:51 »
Sprit,
How do I order the hhkb case?
Do I add a description in the order form?
Can I order it in metal?
Offline mooswa
« Reply #1590 on: Mon, 20 January 2014, 11:43:55 »
Sprit, you have pm from me, can you check? Thanks!  ;)
Offline numiru
« Reply #1591 on: Mon, 20 January 2014, 13:12:27 »
Hello!  numiru !   :)
Thank you so much, paid!
KUL ES-87
Offline fuus
  • All Year Christmas!
« Reply #1592 on: Mon, 20 January 2014, 13:42:47 »
Hey sprit, just wondering how long back this hand soldering will push deliveries?
Thanks, Fuus
Filco - Browns
Past: Ergodox - Reds / IBM SSK / Spirit 87% - Clears / Dell AT101W
Offline MrChunky
« Reply #1593 on: Mon, 20 January 2014, 15:36:09 »
Hello!  MrChunky!  :)
Thanks for the explanation sprit. Do you know when the metal cases would be ready for shipping?
Offline Loligagger
« Reply #1594 on: Mon, 20 January 2014, 20:27:30 »
Invoice paid, though I assume in the end shipping for two packs of springs will be cheaper?
Also, how's the progress on the AT/XT style PCBs?
« Reply #1595 on: Tue, 21 January 2014, 00:15:20 »
Thanks
GK
sheet of plastic voltage protection material as well as some foam I get at the art store. I have a Pure that uses this style of case that I have used for a year I guess with no issues. As far as "your" case goes, I'd do it without the rubber feet (not necessary). I might go with a hard rubber pad instead of the art foam. We'll see.
Offline justnits
« Reply #1596 on: Tue, 21 January 2014, 00:18:52 »
Thanks
GK
just mount the pcb on top of the piece of alu?
so the sides are exposed, am i right?
Offline cookiesowns
« Reply #1597 on: Tue, 21 January 2014, 01:56:06 »
Sprit, I know you're very busy, but I sent you a PM.
Can you check it out? :)
Offline ripospfeigrp
« Reply #1598 on: Tue, 21 January 2014, 18:00:40 »
are springs and LEDs required? i thought all MX switches come with springs in them. also do these use any GH60 PCB or a custom one?
Offline Zeal
« Reply #1599 on: Tue, 21 January 2014, 18:49:23 »
Yes, all MX switches come with pre-installed springs. People here like to mod their switches by swapping out the stock springs (and apply lube/grease on sliders+springs)  to create a different switch feel so that's why there's such a wide variety of aftermarket springs :p
LEDs are not required. It's a personal preference.
The PCB uses a Korean custom one similar to ps2avr. It should still fit in the majority of cases.
« Last Edit: Tue, 21 January 2014, 18:51:32 by Zeal »
