Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 2127700 times)
Offline numiru
Is the 87% pcb compatible with Filco cases?
Hello numiru!   ;)
Filco cases are usually Not compatible with the A.87 PCB.
Ok, thanks
KUL ES-87
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
Round 1  :  Shipping  on going   (~ 37 persons left to ship)
- Doing diode soldering before shipping.
- Sending a Personal message before each shipping
- Finish the Shipping : by August 8th (11th)
- So Sorry for the Delay !!   I'm a sinner.  :(
Round 2  :  Start Invoicing   75% Done!  -
(Proxy Shipping will be prepared)
-  PCB   :  60%  hit the MOQ (all SMD presoldered) -  Start Invoicing.
-  PCB   :  75% (20pcs needed for the MOQ),     87% (20pcs needed for the MOQ),     110%(40pcs needed for the MOQ)
* IF the MOQ fails, The main controller Parts will be presoldered, then You may need to solder the diodes, LED resistors (It's very time consuming but Not that difficult and some fun)
-  Metal Plates,  Metal Cases  :  Far below the MOQ,  Failed.
-  Acrylic Plates, Cases  :  hit the MOQ,  Start Invoicing.
-  The other Parts  :  hit the MOQ,  Start Invoicing.
The Proxy shipping to Save cost will be prepared for the PCB and small Parts
Start  Production :  from  July 21th ~
Start Inspection & Packiing  :  From August 11th ~ (with all parts, springs etc)
Start Shipping : From August 15th ~
Finish Shipping :  by Sep. 13th
« Last Edit: Fri, 18 July 2014, 21:56:25 by sprit »
Offline infiniti
  • I <3 KB
  • Bob was here
Looks like it's time to get my Round 2 order in!
Offline Melanic
Is August 8 for all round 1 orders? Some people mentioned a delay in 4mm metal plates due to low interest. Is that still the case?
Offline sprit
Hi!  Melanic!   ;)
Yes!  and the 4mm metal plates are under 15 pcs at this moment, suffering machining errors.  I am doing pm on that to each people.
« Last Edit: Tue, 15 July 2014, 09:48:02 by sprit »
Offline swill
  • builder & enabler
    • swillkb.com
Haha, I was thinking the same thing.  :)
Offline swill
  • builder & enabler
    • swillkb.com
Round 2  Status  (Start Invoicing)
-  PCB   :  60%  hit the MOQ (all SMD presoldered),
-  PCB   :  75%, 87%, 110%  under MOQ  (The main controller Parts will be soldered, You may need to solder the diodes, LED resistors, it's will be said in the invoice)
Sprit, you may want to specify how close the 75%, 87% and 110% are to hitting MOQ where everything could be factory pre-soldered.  I have seen in other GBs that if that information is available the community rallies around those numbers to push them up to the MOQ.  Might be worth it to update that status every couple weeks.
Offline sprit
Oh!  I see!  I will do that!  Thanks for the Advise!   ;)
« Last Edit: Tue, 15 July 2014, 14:07:39 by sprit »
Offline sprit
- So Sorry for the Delay !!  I'm a sinner :(
Round 2  :  Start Invoicing   (Proxy Shipping will be prepared)
Updated !   ;)
« Last Edit: Wed, 16 July 2014, 15:36:45 by sprit »
Offline kakakowie
  • Make Love not War
Re: < SPRiT - Model 1 & 2 > PCB/Case/Parts - Round 2 (Invoicing)
« Reply #2459 on: Wed, 16 July 2014, 09:52:16 »
If I ordered a 60% and a 75%, will i get separate invoices or will i get it all together once 75% starts invoicing?
Offline sprit
« Reply #2460 on: Wed, 16 July 2014, 10:40:57 »
I will do all together in One Invoice !  ;)
Offline b7ad
  • ゆめうつつ
    • mechblog
« Reply #2461 on: Wed, 16 July 2014, 12:51:06 »
Sprit - Orders for round 2 60% boards should expect invoice over the next few days if I read the update right?
There were a few changes we discussed but as you are a super busy guy you may not remember, should I submit a new order or wait and see if the invoice is correct then can inform of any changes if needed?
Thanks
Offline sprit
« Reply #2462 on: Wed, 16 July 2014, 13:18:35 »
Thanks
All the Orders are kept well and backuped.
You can send a New one to modify some details since May 14th.   ;)
The PCB soldering have been killing me harder than Smoking in the R1.   :-\
I would love to do that anytime, But been Too Much so far.   >:D :'( :'(
« Last Edit: Wed, 16 July 2014, 16:12:10 by sprit »
Offline aldrinballado
« Reply #2463 on: Wed, 16 July 2014, 17:00:08 »
Hi, just wondering when the deadline for invoicing is.
Offline sprit
« Reply #2464 on: Wed, 16 July 2014, 17:07:13 »
Hi!  ;)
Oh!  by July 20th.   Working on.
Re: < SPRiT - Model 1 & 2 > PCB/Case/Parts - R1 (Shipping) - R2 (Invoicing)
« Reply #2465 on: Thu, 17 July 2014, 02:54:08 »
Can those feet be detached from the case?
Offline sprit
« Reply #2466 on: Thu, 17 July 2014, 03:12:40 »
Sure!  All Cases have connecting Bolts, and CNC machined Bolting holes.   ;)
3~4 colors of Feet are basically included.   http://geekhack.org/index.php?topic=50580.msg1266826#msg1266826
71149-0   71151-1
« Last Edit: Thu, 17 July 2014, 10:26:06 by sprit »
Offline jorgenslee
« Reply #2467 on: Thu, 17 July 2014, 05:00:58 »
Sure!  It has connecting Bolts, and CNC machined Bolting holes.   ;)
(Attachment Link)     (Attachment Link)
wow... that case looks wicked... is the ordering still open?
Offline sprit
« Reply #2468 on: Thu, 17 July 2014, 08:18:45 »
Hi!   Jorge!   ;)
Your 60% is well?   ;)
« Last Edit: Thu, 17 July 2014, 08:31:15 by sprit »
Offline sprit
« Reply #2469 on: Thu, 17 July 2014, 08:24:57 »
New Cases   (Updated   July 16th)
-  Model  2  Slim        (Top 5mm Plate & 2-Layerd  :  21mm  Medium Height : Not too skinny)
Model  3  Super Slim   (Top 5mm Plate & 2-Layerd  :  same as Model 2 :  18mm  Low Height, but higher than Poker II )
-   Laser & CNC machined as Model 1 Standard
-   Shares Bottom Platform Layer and Basic Structures with Model 1
-   Top 5mm Plate &  2-Layered  8T Solid Structure
-   Keycaps and Switch Tops are exposed.
-   60%  Model 2, 3  supports   :   Face U, W,  GH60, Poker I, and most 60% Custom PCBs  (*Poker II  users need a commnet)
-   75%  Model 2, 3  supports   :   MX-mini U, W PCBs.
-   87%  Model 2, 3  supports   :   A.87 PCBs,   Phantom 87%,  and  Most 87% Custom PCBs.
-  110% Model 2, 3  supports   :  110% A.87 Ext. PCBs,  most 110% Custom PCBs.
(Attachment Link)   75%  (Attachment Link)     (Attachment Link)     (Attachment Link)   87%    (Attachment Link)   (Attachment Link)   60%  (Attachment Link)   (Attachment Link)   (Attachment Link)     (Attachment Link)     (Attachment Link) 110%
Model 2, 3 Cases -  Updated !
« Last Edit: Fri, 18 July 2014, 00:30:09 by sprit »
Offline kakakowie
  • Make Love not War
« Reply #2470 on: Thu, 17 July 2014, 08:49:20 »
Sorry if this has been mentioned before, I'm assuming that switch tops cannot be removed with the 5mm acrylic plate?
Offline sprit
« Reply #2471 on: Thu, 17 July 2014, 08:55:52 »
Hi!  ;)
Always  Removable in My Plate Designs.   :thumb:
71208-0   71210-1   71212-2
« Last Edit: Thu, 17 July 2014, 10:49:29 by sprit »
Offline jorgenslee
Re: < SPRiT Model 1 & 2 > PCB/Case/Parts - R1 (Shipping) - R2 (Invoicing)
« Reply #2472 on: Thu, 17 July 2014, 10:07:29 »
Hi!   Jorge!   ;)
Yeah, It's doing well. The quality of the pcb is superb, I was able to tinker as much as I want and there is still no damage in the pcb given the fact Im noob in soldering... :)
Unfortunately, it is sitting in my desk right now as it is still waiting for keycaps.
Offline nuclearsandwich
« Reply #2473 on: Thu, 17 July 2014, 14:33:29 »
Hi!   Jorge!   ;)
What layout do you need for your keycaps. Maybe I can hook you up?
Offline pasph
« Reply #2474 on: Thu, 17 July 2014, 18:49:27 »
Model 2, 3 Cases are 2-Layerd so in the order form
"Acryl Case - Color & Finish ? - Top / Middle / Bottom Layer"
we have to choose only 2 colors not 3?
Offline jorgenslee
« Reply #2475 on: Thu, 17 July 2014, 19:28:48 »
Hi!   Jorge!   ;)
YGPM.
Offline sprit
« Reply #2476 on: Fri, 18 July 2014, 00:38:54 »
Model 2,3  =  Top Plate + 2-Layered.
-   Plate color  :  You can  chose it in the Plate option
-   If the comment is  Clear/Blue   for the Model 2, 3  Cases
    I may understood  it means :   middle : Clear  /   Bottom : Blue.
-   I will  recheck thru PM  and Invoice  (* I  usually try to comment Your Color options in the Invoice.)   :thumb:
« Last Edit: Fri, 18 July 2014, 07:16:54 by sprit »
Offline jorgenslee
« Reply #2477 on: Fri, 18 July 2014, 00:56:06 »
Hi Sprit,
Does the Acrylic with matte finish doesn't easily get scratch?
Offline sprit
« Reply #2478 on: Fri, 18 July 2014, 01:05:16 »
Hi Sprit,
Not get easily scratched  by fingers or nails,  IMO.   ;)
Smooth  finish is more Fragile, delicate, more Transparent, so it can be more Beatiful in certain Combos, as We know.   ;)
I have been trying to get Better Acrylic materials, and Better Color and Qualities.   ;)
« Last Edit: Fri, 18 July 2014, 07:17:17 by sprit »
Offline sprit
« Reply #2479 on: Fri, 18 July 2014, 02:19:57 »
60% W PCBs  Left to Solder Diods    :    R1  Shipping   ~37 persons  left
-   The Controller Test done, Latest Firmware and KeyMap loaded!
-   All  Soldered  and  Tested  by  Sprit.
-   The 75% W, 87% W, 110% W PCBs  lefts  are almost same as  60%.
-   Doing shipping with the other Parts to Each Member.
-   PM, emailing before Shipping to Reconfirm  all the Details.
-   Today, to ship to Germany, Sweden, USA
Thanks Guys!   for Your Great Support!
When you visit  Seoul, Korea,  You can call me.  Beer!!!  :p
71368-0
« Last Edit: Sat, 19 July 2014, 05:28:41 by sprit »
Offline fuus
  • All Year Christmas!
Re: < SPRiT Model 1,2,3 > PCB/Case/Parts - R1 (Shipping) - R2 (Invoicing)
« Reply #2480 on: Fri, 18 July 2014, 05:57:08 »
I finally got my PCB and stuff! Thanks Sprit! I've begun assembly. First test and space etc was fine, just gotta test a few more LEDs! :D
Filco - Browns
Past: Ergodox - Reds / IBM SSK / Spirit 87% - Clears / Dell AT101W
Offline Glissant
« Reply #2481 on: Fri, 18 July 2014, 10:14:10 »
I just received an invoice that is incorrect. I read that you wanted us to resubmit the form if we had any changes, so I did that. Please double check the submitted form.
Offline sprit
« Reply #2482 on: Fri, 18 July 2014, 10:50:40 »
Hello!  Dear !   :thumb:
The last one I got is on 13th.
Have You sent another one?  ;)  Maybe Lost,  Mis-Transfered ? >:(
« Last Edit: Fri, 18 July 2014, 12:54:04 by sprit »
Offline cjhard
  • Claudia the Magnificent
« Reply #2483 on: Fri, 18 July 2014, 10:58:40 »
I submitted on the 15th, did mine make it into R2, or did I miss this?
EDIT: Just got invoice, paying this now :)
I'll need to change my address before Shipping begins, I'll be updating all GB's I'm in once I have one
Thanks sprit!
« Last Edit: Fri, 18 July 2014, 11:09:17 by cjhard »
Offline sprit
« Reply #2484 on: Fri, 18 July 2014, 11:40:33 »
R2   Invoicing  :::      ~ 75%   Done!    >:( >:(
« Last Edit: Fri, 18 July 2014, 21:51:43 by sprit »
Offline fuus
« Reply #2485 on: Fri, 18 July 2014, 11:49:03 »
All the LEDs are working on my board except for the darn pause button  :eek:
Filco - Browns
Offline sprit
« Reply #2486 on: Fri, 18 July 2014, 11:50:59 »
All the LEDs are working on my board except for the darn pause button  :o
87% W  PCB?  :p
Because  You are Wicked  ??    :p
It's  Num Lock  LED  Indicator for 87% W PCB !
I will Post on that soon.   :thumb:
« Last Edit: Fri, 18 July 2014, 12:08:48 by sprit »
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #2487 on: Fri, 18 July 2014, 12:47:08 »
It is probably dedicated to the Num Lock?  Check under the PCB and see if it has N/L under that switch...
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #2488 on: Fri, 18 July 2014, 13:05:33 »
Invoice is paid for R2. Thank you Sprit!
Offline abtrout
« Reply #2489 on: Fri, 18 July 2014, 13:57:25 »
Just paid my invoice. Thanks, Sprit!
Offline sprit
« Reply #2490 on: Fri, 18 July 2014, 15:56:30 »
For  Lilki    ;)
71480-0
*So Sorry dark here early in the morning, a Bad Pic.
« Last Edit: Fri, 18 July 2014, 18:47:01 by sprit »
Offline sprit
« Reply #2491 on: Fri, 18 July 2014, 18:46:29 »
* Model  1 , 2,  3  are   Basically  Compatible!!   :   Mix n Match!
-  Model  2  Slim                  (Top  &  2-Layerd  :  21mm  Medium Height  :  Not too skinny)      $58~$75
Model  3  Super Slim   (Top  & 2-Layerd  :  18mm  Low Height,   but higher than Poker II )      $55~$70
-   Top Plate &  2-Layered  Solid 8T Structure
-   60%  Model 2, 3  supports   :   Face U, W,  GH60, Poker I,  most 60% Custom PCBs  (* Poker II  users need a commnet)
71494-0    71496-1    71498-2     71502-3    71532-4    71583-5   https://www.youtube.com/watch?v=J4eA1TqGN8w        https://www.youtube.com/watch?v=o2oAjCjCaUE   https://www.youtube.com/watch?v=fBxEuQsdf7I
« Last Edit: Tue, 18 November 2014, 01:07:39 by sprit »
Offline awong
« Reply #2492 on: Fri, 18 July 2014, 18:48:30 »
Is there case with thin bezel?
Offline sprit
« Reply #2493 on: Fri, 18 July 2014, 19:01:31 »
You mean  lower,  or  narrower?    ;)
Thin,  narrow cases  have  problems  like  Poker II stock case,  as  we see  around.
Model 2, 3   Cases have 8mm thick Bottom  Layer,  as Strong  as  some  Alu cases , IMO.  (* Dont  believe me, Please!)
« Last Edit: Fri, 18 July 2014, 19:47:36 by sprit »
Offline twiddle
    • Portfolio
« Reply #2494 on: Fri, 18 July 2014, 19:32:51 »
R2 invoice paid!
must..stop...thinking..of..extra things to order...
Offline fatchoi
Model 2,  3  Slim   :  60%  Case    :::    * Model  1 , 2,  3  are   Basically  Compatible!!
Model  3  Super Slim   (Top 5mm Plate & 2-Layerd  same as Model 2 Slim :  18mm  Low Height,  but higher than Poker II )
-   Top 5mm Plate &  2-Layered  Solid 8T Structure
This combination of blue bottom and clear layer looks so good... I shouldn't have ordered an all clear case :(
Offline Zeal
    • Zeal Generation Inc.
« Reply #2496 on: Fri, 18 July 2014, 20:00:30 »
Those transparent cases are so beautiful! Great job!  :thumb:
Offline sprit
All  Clear is  Standard,  for everycolor combos, imo. :thumb:
Model 1 (3-Layered)  Case can be slim down to  Model 2, 3  (2-Layered).
You can take the Top layer off,  and  make it 2-Layerd with small mod.
You can order any Color  layer separately,  Sir!    ;)
As mentioned from R1  Interest check....
Mix  n  Match !!
71534-0
« Last Edit: Sat, 19 July 2014, 09:37:49 by sprit »
Offline swill
  • builder & enabler
    • swillkb.com
Agreed. The same combo with purple would also be awesome.
Offline strict
  • TKL Zealot
« Reply #2499 on: Fri, 18 July 2014, 20:55:11 »
Wow! Those are gorgeous! I would love one of the Model 3 Super Slims for my Phantom. Any estimates on pricing? Is black a color option? If so, I would have to decide between two color options, either all black or clear bottom with a black top.
Edit - found the answers to all my questions on the order form. Now I just need to figure out what colors I want  :thumb:
« Last Edit: Sat, 19 July 2014, 00:33:55 by strict »
