Author Topic: [SPRiT] R1 R2 (Shipping 92% Completed)  (Read 2073396 times)
Offline bianco
Re: <SPRiT Model 1, 2, 3> - R1(73% Shipped) - R2 (Order Open)
« Reply #2550 on: Thu, 24 July 2014, 04:58:41 »
I am going to ship to Sweden, UK, USA  tomorrow !
Thanks for Your Patience!!!
what about singapore?
Offline distel
« Reply #2551 on: Thu, 24 July 2014, 08:38:32 »
And germany?
Offline keymaster
  • Topre Revolution Theorist
« Reply #2552 on: Thu, 24 July 2014, 10:14:04 »
USA! USA! USA!
My body is ready.
Offline bakteria
Re: &lt;SPRiT Model 1, 2, 3&gt; - R1(73% Shipped) - R2 (Order Open)
« Reply #2553 on: Thu, 24 July 2014, 12:32:32 »
Are there any instructions to soldering? Since its a universal pcb it would be nice. Don't want to screw it up.
SS 7G black - Pure red - poker blue (MKC Tray)
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #2554 on: Thu, 24 July 2014, 12:34:14 »
Here are some soldering instructions (or as good as your going to get anyway).  :)
http://geekhack.org/index.php?topic=58969.msg1349714#msg1349714
Offline bdtbinh
  • In Geek I trust
« Reply #2555 on: Thu, 24 July 2014, 13:19:54 »
i sent an email to ur gmail acc about adding more item, pls check, thank Sprit.
Offline bdtbinh
  • In Geek I trust
« Reply #2556 on: Thu, 24 July 2014, 13:23:57 »
Offline Biased opinion
« Reply #2557 on: Thu, 24 July 2014, 22:01:22 »
No news on Australia shipping. Come on SPRITE my mind is ready.
Offline sprit
  •  Post Editing Timeout
  • Location: The Geek Symphosion :::::: Mechanical Engineering ::: Alta Magna Uniforma :::::: 哀吾生之須臾羨長江之無窮 ::
« Reply #2558 on: Thu, 24 July 2014, 22:14:30 »
The R1  shipping Schedule   =  by 11th August.
http://geekhack.org/index.php?topic=50580.msg1406921#msg1406921
I will do that, AT ALL  !! :thumb:   >:D
« Last Edit: Thu, 24 July 2014, 22:25:55 by sprit »
Offline bakteria
Re: <SPRiT Model 1,2,3> - R1(73% Shipped) - R2 (Order Open)
« Reply #2559 on: Fri, 25 July 2014, 04:58:46 »
Are there any led indicators? Lets say for caps lock. (60 %)
I want all white leds but multicolored for indicators (if there are any)
« Last Edit: Fri, 25 July 2014, 05:05:01 by bakteria »
Offline sprit
« Reply #2560 on: Fri, 25 July 2014, 05:01:34 »
Are You doing Soldering LEDs for You 87% W ?
LED  Indicators :  Caps Lock,  Scroll Lock,  Num Lock (= Pause for 87%)    ;)
Offline bakteria
« Reply #2561 on: Fri, 25 July 2014, 05:05:26 »
Sorry just added that its a 60% board.
Offline sprit
« Reply #2562 on: Fri, 25 July 2014, 05:11:09 »
60%  =  Caps Lock , ESC  need  Indicators   :thumb:
Offline bakteria
« Reply #2563 on: Fri, 25 July 2014, 05:17:06 »
Where exactly are the holes for the leds? Or do they go through the switch like the others?
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #2564 on: Fri, 25 July 2014, 05:26:42 »
The Caps Lock indicator LED is in-switch.  Mine is red in the picture below:
Offline bakteria
« Reply #2565 on: Fri, 25 July 2014, 05:31:01 »
Thank you sir :)
Offline swill
  • builder & enabler
    • swillkb.com
Re: &lt;SPRiT Model 1,2,3&gt; = R1(73% Shipped) = R2 (Order OPEN)
« Reply #2566 on: Fri, 25 July 2014, 06:37:37 »
On my 60% I think I only have two indicator. Capslock and numlock. N/L is on the backspace switch. If there are other indicators, I have not found them yet. :)
Offline sprit
« Reply #2567 on: Fri, 25 July 2014, 06:41:51 »
I just Recommend Multi Color LEDs  for Caps, and Esc  for 60%,
I sent some pcs of MultiColor  for MR. Bakteria.
Yes!  Num Lock is at Backspace Position,  SIR!    :thumb:
« Last Edit: Sun, 27 July 2014, 08:13:26 by sprit »
Offline dragonken
Re: <SPRiT Model 1,2,3> = R1(73% Shipped) = R2 (Order OPEN)
« Reply #2568 on: Sat, 26 July 2014, 00:53:46 »
order placed.
Offline dragonken
« Reply #2569 on: Sat, 26 July 2014, 10:21:04 »
paid! Thanks Sprit.
Offline sprit
« Reply #2570 on: Sun, 27 July 2014, 08:51:38 »
Offline sprit
« Reply #2571 on: Sun, 27 July 2014, 08:56:58 »
Assembled  60% W   ::   by  Pichu23
http://geekhack.org/index.php?topic=35864.msg1414830#msg1414830
http://www.youtube.com/watch?v=nxphnlAZk2Y
http://imgur.com/a/b9CAu
72552-0    72554-1    72556-2    72560-3
Thanks  Pichu23 !
« Last Edit: Sun, 27 July 2014, 19:10:59 by sprit »
Offline sprit
« Reply #2572 on: Sun, 27 July 2014, 10:41:52 »
Assembled  60% W   ::   by  Nubbinator
   http://geekhack.org/index.php?topic=33130.msg1415024#msg1415024
72571-0     72573-1
Thanks nubbinator!
« Last Edit: Sun, 27 July 2014, 19:10:49 by sprit »
Offline sprit
« Reply #2573 on: Sun, 27 July 2014, 18:31:32 »
Model 1,2,3  Plate   ::   for  60%
72592-0
« Last Edit: Sun, 27 July 2014, 19:11:14 by sprit »
Offline sprit
« Reply #2574 on: Sun, 27 July 2014, 19:01:49 »
Assemble  60% W   ::   by  SPRIT
72707-0   72701-1
« Last Edit: Mon, 28 July 2014, 17:44:43 by sprit »
Offline sprit
« Reply #2575 on: Mon, 28 July 2014, 17:36:59 »
Stabilizers  are getting ready for R2    ::   incl.  Metal Wires      https://www.youtube.com/watch?v=KtqV27vtTAM
                        72703-0
« Last Edit: Mon, 28 July 2014, 18:08:49 by sprit »
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #2576 on: Mon, 28 July 2014, 23:34:44 »
OMG the background music and camera movement in that video...MUST WATCH!!! :thumb: :thumb: :thumb:
P.S. That's a lot of stabs...
Offline Heliosphere
« Reply #2577 on: Tue, 29 July 2014, 00:33:38 »
Hi! I have a few questions:
1. Is the smokey gray-blue color an option for the acrylic? I see a sample picture on page 1, but it's not an option on the order form.
2. Does the 75% require special keycaps? It seems that it uses the large Iso enter key and other non-ANSI sized keys.
3. Do I need to use PCB mount switches? I have a set of plate-mount clear switches waiting to be used, so it would be nice if I could use plate mounting.
4. Do I choose three layer of acrylic case colors for model 3?
5. Where do I specify if I want model 1, 2, or 3?
Thank you, and I hope I'm not too late to order!
Offline Zeal
    • Zeal Generation Inc.
« Reply #2578 on: Tue, 29 July 2014, 00:57:15 »
Yes, it's available. Mention "Charcoal Gray" in the textbox.
Nope. Sprit's 75% board supports both ANSI & ISO. That's why the plate has both the cut outs. :). You'll just need to source a couple extra 1u keys to fill the right side. (Some people use numpad keys).
PCB and Plate mounted switches both work on Sprit's Face W PCB! Just be sure to have a plate of some sort if you use plate mounted switches! Stabs are PCB mount by default.
Model 3 is a two layered case.
http://puu.sh/avzvi/e4779f5342.png
Answered in bold. Feel free to ask any other questions if you're confused with anything else!
Offline Heliosphere
« Reply #2579 on: Tue, 29 July 2014, 01:19:47 »
Thank you, Zeal! Will each order include those wire stabilizers?
Offline Zeal
« Reply #2580 on: Tue, 29 July 2014, 01:26:16 »
Stab orders ($8 USD) come with the necessary wires & plastic inserts. Each set contains 4x 2unit stabs (enter, shifts, backspace) and 1x 6.25unit spacebar stab. If you want a 7unit stab wire, it'll be $1 extra.
Offline Heliosphere
« Reply #2581 on: Tue, 29 July 2014, 01:42:03 »
Would you recommend getting extra sets? It seems like some people broke theirs in the process of assembly.
Do we also get SIP and stickers with this buy, or is that from different group buys?
Offline Zeal
« Reply #2582 on: Tue, 29 July 2014, 02:06:14 »
It's not necessary as long as you know which way the wire goes. If you'd like some extra just for re-assurance, then I don't see why not. :)
I'll actually be providing SIP sockets soonTM, and stickers can be arranged with Sprit, depending on demand.
Offline Heliosphere
« Reply #2583 on: Tue, 29 July 2014, 02:39:23 »
Thanks again, Zeal. I've put in my order and noted the extra stuff just in case. Feel free to contact me if you guys need to discuss the order.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #2584 on: Tue, 29 July 2014, 10:48:39 »
umm, there's a video by bluebear that shows how to clip the stabs.
he also shows how to insert the stab wires. I've clipped my stabs and so far they're holding up pretty well.
Just be careful.  :D
Offline BlueBär
« Reply #2585 on: Tue, 29 July 2014, 11:46:46 »
Just be careful.  :D
Offline Lubed Up Slug
« Reply #2586 on: Tue, 29 July 2014, 11:48:17 »
Since this multiple question thing seems to work, I'll give it a go.
1. Can I just procure a plate of my own or make one that will fit on this 60% pcb? Are there any special requirements for size or thickness?  I'm guessing just 1.6mm?
2.  So if I use a plate with this I should get cherry plate mounted stabs from that Ivan group buy, not the costar ones from WASD? And those come with the springs and everything I don't need anything else?
Offline BlueBär
« Reply #2587 on: Tue, 29 July 2014, 11:58:04 »
1. Yes, if you have some appropriate CAD files. Thickness should be 1.6mm, correct.
2. You can get PCB mounted Cherry stabs from this GB or Plate mounted Cherry stabs from Ivans GB, but Costars stabs only if you have a plate that can use Costar stabs. Stabs don't have springs, both GBs provide all parts need afaik.
« Reply #2588 on: Tue, 29 July 2014, 12:02:19 »
1.Sweet
2.Cool and yeah idk I feel like the keyboard world makes stuff up last minute just to make this stuff more difficult, and then I end up paranoid.
Offline bakteria
« Reply #2589 on: Tue, 29 July 2014, 12:58:21 »
Just one quick question before I fire this thing up. Does it matter which direction the diodes and resistors face?
I've checked the build logs of others and followed their lead. Just want to make sure.
Here's a picture
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #2590 on: Tue, 29 July 2014, 13:03:40 »
Here's a picture
Resistors.  No, they can go either way.
Diodes.  YES, you must put them on in the correct orientation.  It 'looks' like you have put them on correctly, but you should be following the silk screen on the PCB to be sure...
Offline bakteria
« Reply #2591 on: Tue, 29 July 2014, 13:16:41 »
I've put the arrow towards the black line on the diodes. They are tricky though because a few face a different direction.
Like these little buggers
Offline HPE1000
  • Keycap Paparazzo
« Reply #2592 on: Tue, 29 July 2014, 13:18:52 »
I believe all three of those you posted are upside down, flip them if you can.  :thumb:
Offline bakteria
« Reply #2593 on: Tue, 29 July 2014, 13:25:17 »
Yeah if you look they are already flipped. Just want to make sure. Don't want to break nothing 😜
Offline bakteria
« Reply #2594 on: Tue, 29 July 2014, 14:57:05 »
Just plugged it in to my laptop and I think the computer thinks it's a mouse because when it's plugged in the mouse is not working at all.
A button and space are unresponsive. The rest seen to work. Might be faulty switches?
« Last Edit: Tue, 29 July 2014, 15:02:25 by bakteria »
Offline wackjobz
« Reply #2595 on: Tue, 29 July 2014, 15:06:55 »
Could someone kindly explain the MOQ on the order form. I want to purchase the items to make a complete 60% keyboard w/ case. Is that MOQ for the group buy or individual? Thank You
Offline BlueBär
« Reply #2596 on: Tue, 29 July 2014, 15:09:53 »
Resolder the unresponsive switches - faulty switches are unlikely. Not sure why your mouse doesn't work, try a reboot?
Clearly every person who wants to join the GB needs to purchase at least 100 PCBs :P
Edit: Since you're new here, sorry for joking. At least 100 overall orders for the PCBs for example are needed to get to the MOQ and for you to get a PCB.
« Last Edit: Tue, 29 July 2014, 15:12:50 by BlueBär »
Offline bakteria
« Reply #2597 on: Tue, 29 July 2014, 15:27:13 »
Tried resoldering both switches. no go :/
Will try and change them out and see if that helps.
Mouse works at login screen but stops working once I login.
Offline wackjobz
« Reply #2598 on: Tue, 29 July 2014, 15:31:16 »
I don't mind the joking, no harm done. Thank you for at least responding, even with the witty humour.  :p
Offline bakteria
« Reply #2599 on: Tue, 29 July 2014, 15:44:19 »
Diodes were upside down..
It's been a long couple of days..
