Author Topic: Looking for my first mechanical keyboard again.  (Read 2188 times)
Offline smalltock
  • You can wop wop wop ksch
« on: Wed, 06 November 2013, 12:18:49 »
I dropped my original requirements/specifications because I realized that they weren't really necessary and I no longer desire to have those features.  I'm in the market for a keyboard with blue switches and the ISO layout.  I haven't ever been an ISO user, as I live in the United States, but I make frequent use of the backslash and rather like the new location of it on ISO boards.  The layout just appears more appealing, considering my typing tendencies.  Are there any good ISO boards with blue, green, or brown switches that can be purchased in the United States?  I haven't done a whole lot of searching yet, myself, but I figured it can't hurt to get suggestions from those more knowledgeable.  If it can be helped, I'd like minimal staggering on the keys, as well.  Ergonomic options are definitely welcome :)  Preferably around the same price as the CMStorm QFR or the Rosewill RK-9000.  With or without a number pad.  I use it but also wouldn't mind going tenkeyless.
Thank you guys in advance for your input!  Much appreciated!  :D
-SmallTock
« Last Edit: Wed, 06 November 2013, 12:24:33 by smalltock »
Normally, when you see a guy who's a walrus, you're like... "Hey, that guy's a walrus."
Offline 1pq
  • Hipster Doofus
Re: Looking for my first mechanical keyboard again.
« Reply #1 on: Wed, 06 November 2013, 12:58:00 »
Hmm, I wonder why I guy named SmallTock would need to use pipes a lot... :P
I'm not sure, but you may be able to find a cherry G80-3000 on ebay with an iso layout. I've never used one, but it was used for the DAS II and is supposed to be built very well.
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline smalltock
« Reply #2 on: Wed, 06 November 2013, 13:06:50 »
Teehee ;D
It's not a huge concern.  It's just something I think may be beneficial in the long run.  If I can't find anything, I'm either going to buy the ISO WASD v2 or the ANSI Rosewill RK-9000, depending on my budget at that point.  Thank you for the suggestion.  It's very much appreciated :)
Offline smalltock
« Reply #3 on: Sun, 10 November 2013, 15:10:10 »
Are there any other suggestions?  I may be able to afford the WASD v2, but I'd like a cheaper option if there is any.  I'm sure there are cheaper options, the problem is that most of them won't ship ISO models to the United States, correct?  I thank all that have helped me on this forum so far and all that will help me with this topic :)
Offline Linkbane
« Reply #4 on: Mon, 11 November 2013, 00:42:15 »
Are you looking for TKL or fullsize?
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline genkidama
« Reply #5 on: Mon, 11 November 2013, 02:51:07 »
He is looking for either.
Unfortunately I can't help you, but wish you good luck in finding something cheaper! :)
My finger training is over 9000!!!!
Offline Linkbane
« Reply #6 on: Mon, 11 November 2013, 10:39:07 »
Oops, didn't see that. The classifieds are a good place to find a European QFR/etc. for decent prices. The discount should offset the shipping.
However, if you do want a new board, WASD seems to be the best bet. As a note, one of the Steelseries keyboards has a large L-enter, but they all use MX Black so you would never want it anyways.  ;)
