Author Topic: Tenkeyless blank set - EU or dirt cheap  (Read 4127 times)
Offline SOROBORU88
« on: Thu, 07 November 2013, 08:20:23 »
Hello everyone,
is it possible to get a blank set of 87 (tenkeyless) keycaps here in EU or cheapo (tax free) in China? Or at least where to get PBT blanks.
I just want to know, if there is another source than ebay, wasd and KD.
Thank you very much :)
Offline BakerMan1971
Re: Tenkeyless blank set - EU or dirt cheap
« Reply #1 on: Thu, 07 November 2013, 09:01:29 »
have you checked the geekhack vendor list? generally they are outside the EU.  http://geekhack.org/index.php?topic=45672.0
or (dare I say it?) the banggood site http://geekhack.org/index.php?topic=48643.0
there is of course ebay too.
Offline SOROBORU88
« Reply #2 on: Thu, 07 November 2013, 12:21:55 »
I looked through almost all of it and the only thing I like are wasdds sets on ebay. I would buy them fosho, but only if I knew, that I can get theme there tax free. Stupid EU.
I would even buy an used set from someone within EU.
Offline SOROBORU88
« Reply #3 on: Fri, 08 November 2013, 01:07:54 »
Hello, I found the ways to solve my problem:
1. Buy 87 set of blanks from wasdkeyboards, but no PBT
2. Two sets of DSA mounted base and modifier keycaps from keycaps direct - PBT?
What's your opinion?
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Fri, 08 November 2013, 01:18:32 »
You should get the pbt blanks from feng
Offline SOROBORU88
« Reply #5 on: Fri, 08 November 2013, 02:11:16 »
Looks good, but it's from the US, so I will definitely have to pay the tax :(
Offline Sai
« Reply #6 on: Fri, 08 November 2013, 02:58:01 »
you can ask feng to declare low value to avoid tax.  ;)
Offline mm87
« Reply #7 on: Fri, 08 November 2013, 03:12:37 »
I have 2 used Imsto blank PBT sets that I have no use for - blue and dark grey. Could let them go cheap.
You could pick one or both or get mixed set like in this pic (not mine) for example:
No tax troubles with customs obviously, check my location :]
« Last Edit: Fri, 08 November 2013, 03:22:18 by mm87 »
« Reply #8 on: Fri, 08 November 2013, 03:14:21 »
actually I thought Feng was trading out of China or at least the far east?
Offline SOROBORU88
« Reply #9 on: Fri, 08 November 2013, 03:21:42 »
Well, the location of the item I would want from him is Missouri... :/
Offline SOROBORU88
« Reply #10 on: Fri, 08 November 2013, 03:26:39 »
Do they have those little "_" on keys "f" and "j"? Thank you :)
Offline mm87
« Reply #11 on: Fri, 08 November 2013, 03:49:24 »
Yes, all Imsto PBT sets do.
Offline Linkbane
« Reply #12 on: Sun, 10 November 2013, 13:14:15 »
Hello everyone,
Get the 87-key set from banggood. Blank, medium-thick PBT at under $18, free shipping worldwide or about $2 for tracked, comes in black or white.
http://www.banggood.com/PBT-87-Blank-White-Key-Caps-For-Cherry-MX-Keyboard-p-84084.html
Personally loving mine, but not a fan of the caps lock. This also comes with a 6.25x spacebar which I couldn't test, as it doesn't fit my board.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
