Author Topic: Lightest clicky switch?  (Read 7354 times)
Offline simingma
« on: Fri, 08 November 2013, 18:03:29 »
Hi guys,
Have a quick question. What in your opinion is the lightest switch that is also clicky? For me I think "lightest" is around 30-35 grams. Is there a switch or board in production like that?
Cheers
Re: Lightest clicky switch?
« Reply #1 on: Fri, 08 November 2013, 18:05:22 »
Find your favorite clicky switch (MX Blue, White, Green, Alps, etc) and just swap in lighter springs. Easiest mod would be MX Blue with a 45g Korean spring I think. There's not a stock 30-35g clicky switch. There is a 30g Topre switch but it feels linear, according to people who have tried it.
Offline Photoelectric
« Reply #2 on: Fri, 08 November 2013, 18:08:51 »
I'm guessing he means actuation force, in which case swapping in 45g springs into MX Blues would probably give approximately that.
http://www.originativeco.com/collections/kbd-accessories-1/products/springs
Offline simingma
« Reply #3 on: Fri, 08 November 2013, 18:44:18 »
Thank you. Are these Korean spring also compatible with ALPS?
Offline HPE1000
  • Keycap Paparazzo
« Reply #4 on: Fri, 08 November 2013, 18:50:14 »
It might be because I have ghetto greens as well as blues, but blues are so light, why would you want something lighter?
« Reply #5 on: Fri, 08 November 2013, 18:52:53 »
Don't actually know. I would venture a guess that it wouldn't be but it's just a guess.
Offline elton5354
« Reply #6 on: Fri, 08 November 2013, 18:56:18 »
Would a lighter spring make it more clicky?
Offline terran5992
  • One With The Cup Rubber
« Reply #7 on: Fri, 08 November 2013, 19:05:41 »
I would say cherry mx Blue
« Reply #8 on: Fri, 08 November 2013, 19:13:02 »
Green ALPS.
Just measured mine @ 40g.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #9 on: Mon, 11 November 2013, 05:52:06 »
The general consensus is a lighter spring makes the tactile feedback stronger in that the "bump" feels more pronounced but makes the click lighter/quieter if only a bit but slightly noticeable.
Offline Linkbane
« Reply #10 on: Mon, 11 November 2013, 10:42:39 »
I've asked around quite a bit, it would do the opposite. Apparently with lighter springs, Blues start to feel rather linear, but I haven't seen anyone going as far as the 45g bottom-out Korean springs. In reference, I'm pretty sure that bottom-out on stock Blues/Reds/Browns is 60g.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #11 on: Mon, 11 November 2013, 11:53:29 »
The 45g springs aren't truly 45g anyway.  Still lighter than the 60g springs though, which also appear to be more like 63g, according to this review (but have to account for some variation + experimental errors).
« Reply #12 on: Mon, 11 November 2013, 11:59:43 »
The lightest I can think of are some magnetic reed switches, and they usually aren't very clicky (so they don't really count).
Non production of course, there's this
I believe alps springs are shorter and narrower than cherry. You can get a good idea by reading alaricljs's mod of his matias switches.
Offline lazerpointer
  • ya gotta stay phresh
« Reply #13 on: Mon, 11 November 2013, 17:23:30 »
MK had Ducky 1087 with Green XM ALPs. Those take the win for lightest switches, I challenge someone to find lighter switches.
Fair warning though this keyboard is a pile of stinking crap (besides the awesome feel of the crunchy, hollow, clickity goodness) it's usually warped, switches have varying required force, and the key caps fall apart if you try to remove / replace them.
MK sells the switches sometimes.
i type, therefore i geekhack
