Author Topic: Realforce 87 VS Unicomp Ultra Classic: Which has a lower profile typing height?  (Read 2328 times)
Offline dante
Which one is more comfortable to type on without a wrist rest?
I have neither, but if the Unicomp is the same height as a Model M then I would hazard a guess that the RealForce would have a lower profile at the front.
However you should not be resting your wrists on a wrist rest while actually typing - that is only meant for resting your wrists between typing.  And also you should not be resting your wrists, rather the heels of your palms.
Offline MJ45
  • HHKB Pro
I don't have a Unicomp to compare but my Realforce 87UB is the lowest profile keyboard I have. Compared to my other keyboards QFR, Ducky TKL's and HHKB Pro2 the Realforce has the lowest profile.
Offline AKIMbO
  • HHKBro
I can comment directly on this issue as I've had both boards. The RF if the lowest profile mech kb I've ever used bar none.
| KBD75 (box reds)
Offline daerid
    • Rossipedia
Yup. (Also having owned both).
