Author Topic: Looking for a good gaming keyboard  (Read 1533 times)
Offline Wowdude10023
« on: Fri, 08 November 2013, 21:40:13 »
I've been looking for a new keyboard for a while and i'm not sure what keyboards are actually good  or not so good.
Re: Looking for a good gaming keyboard
« Reply #1 on: Fri, 08 November 2013, 21:43:24 »
What kind of games do you play?
If you mostly play FPS games, I'd recommend anything with MX reds or blacks.
RTS? Browns or blues.
Still not sure? Browns.
Offline ithinkimkorean
« Reply #2 on: Fri, 08 November 2013, 22:19:52 »
It would be easier to recommend something if you have a few things you are looking in the board.
Offline osi
« Reply #3 on: Fri, 08 November 2013, 22:24:43 »
Will take a stab and say his hand of choice is world of Warcraft - due to his name
« Reply #4 on: Fri, 08 November 2013, 23:30:16 »
Generically QFR if you don't want backlighting, Ducky Shine if you do.
TKL Ducky Shine if you don't need the number (QFR is TKL anyway).
MX red or, if you have strong fingers, MX black switches.
« Reply #5 on: Sat, 09 November 2013, 11:11:09 »
Honestly, almost any keyboard and any switch can be used for gaming effectively.  The kinds of games you play and the keys you need access to is helpful for determining what some good options for you would be.  I do most of my gaming on a 60% or tenkeyless board since I like to have my keyboard and mouse closer together for comfort.
Switch type really comes down to what you prefer the most.  I wouldn't recommend Blues for FPS, but some people do well with them.
