Author Topic: GMK Dolch and Cherry mix  (Read 2126 times)
Offline TaNaKa$_
« on: Sat, 09 November 2013, 05:57:12 »
Hi Guys,
apologies for my ignorance, I am mecha newbie here. But the mechanical keyboard virus has infected me  :D.
To my question. I plan to replace the keycaps from my Filco to a set of double shots.
I have a Filco Majestouch 2 fullsize with german layout. The alphaset I rip it from an old cherry G80-3000HAD. For the remaining key, like modifier, shift, capslock und so on, I would order the GMK Dolch set from  Originative  (http://www.originativeco.com/collections/keysets-1/products/dolch).
So that the base keys are from the old cherry and the rest from the dolch set.
But I am not sure whether the keys have the same height. Standard OEM-Profile keys are higher than cherry profile keys.
Can somebody help me? Or does somebody own the dolch set?
I would be very grateful for answers.
Offline iAmAhab
  • Established member
Re: GMK Dolch and Cherry mix
« Reply #1 on: Sat, 09 November 2013, 06:00:23 »
They will be the exact same hight. The keys you already have where produced in the very same machinery that made the dolch set.
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #2 on: Sat, 09 November 2013, 11:53:59 »
i have both sets, orginal and the new gmk ones, totally fine to mix and match sir
Offline TaNaKa$_
« Reply #3 on: Sun, 10 November 2013, 02:53:55 »
Yeah! Thanks for your response.  :thumb:
« Last Edit: Sun, 10 November 2013, 03:02:11 by TaNaKa$_ »
