Author Topic: Ducky Shine 3 TKL  (Read 2682 times)
Offline Abn
Ducky Shine 3 TKL
« on: Sat, 09 November 2013, 19:35:34 »
So I just got my ducky shine 3 TKL in the mail and I love it so far. Only problem is there is a squeaky sound coming from the spacebar and its quite annoying. I heard you just lube the cherry type modifiers and it usually goes away. Does anyone have a clear cut answer? And if so, can you please link me the product I need.
Thanks in advance everyone!
Noppoo Choc Mini Reds | Ducky Shine 3 TKL Browns | Topre Realforce 87U 45gram
Offline Linkbane
Re: Ducky Shine 3 TKL
« Reply #1 on: Sat, 09 November 2013, 20:46:20 »
If you go to the classifieds section and check out the Geekhack store, they sell lube which you can use, and I think you can get an applicator also. I would think that any oil would be okay, but I could be wrong in that, don't follow that advice.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline WhiteFireDragon
    • youtube
« Reply #2 on: Sat, 09 November 2013, 21:12:04 »
It'll be much easier if you're lubing the stabilizers before they were installed, but since that's not an option anymore try maneuvering around to all exposed parts that are moving.
Oil is not ideal because it won't stay in once place over time. You'd want grease, or a mixture of grease/oil. It also needs to be plastic and metal safe.
Offline Linkbane
« Reply #3 on: Sat, 09 November 2013, 21:40:30 »
Coolio, thanks for that! Now I'll know how to lube my blues if I ever feel like doing so.
Offline mapple
« Reply #4 on: Sun, 10 November 2013, 09:00:07 »
two questions.
I know that's irrelevant but what kinds of switch u have?
Anyone else got their shine tkl and got same problems? mine is coming so rather to be prepared ....
In God We Trust
Offline Abn
« Reply #5 on: Tue, 12 November 2013, 18:17:01 »
two questions.
I have brown switches :D
Oh for the squeaky problem, I managed to fix the problem with some mechlube 2. On http://elitekeyboards.com/products.php?sub=access,misc&pid=mechlube_2 they have a picture of exactly where you need to lube, but do remember in the picture the stablizer bar runs under the key board and is flipped so it runs to the keys not to you when typing. You will see when you lube it compared to the picture. The problem completely fixed and it feels much better ! =)
