Author Topic: Razer Naga  (Read 4001 times)
Offline IBI
Razer Naga
« on: Sun, 10 November 2013, 13:15:07 »
My current mouse is on the brink of collapse so I'm looking for a new one but I'm tired of mice that die after just five years. This time round I'm hoping to buy something that'll outlast USB, or at least make it to 2025.
Usage-wise, the following applies:
  • Low Sensitivity, I typically use my current 200-2000dpi mouse at 400dpi on a 1920x1200 display
  • Microsoft Mice seem to suit my hand shape. I loved the Intellimouse Explorer 1.1 (the 3.0 not so much) and my current Sidewinder is nice too
  • I do have an un-removable wrist rest on my desk, so anything designed to be gripped low down won't work
  • I have a nova master mousepad, the white feet on my current Sidewinder seem to work the best for that, although I'm not sure what they're made of.
  • Must be wired, batteries are evil.
  • I am a gamer, but I haven't found most of the 'gamer' features to be worth much. A clicky (or otherwise precise) scroll wheel is about all that's required
  • Thumb buttons would be good, but only if they're actually under the thumb. I used them on the Intellimouse 1.1 but haven't on subsequent mice where they've been placed out of the way
But frankly I could adapt to high sensitivity, noisy movement (or a new mousepad)
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline vun
  • Just one more thing
Re: Razer Naga
« Reply #1 on: Sun, 10 November 2013, 13:36:59 »
I'm confused; is this thread called Razer Naga because that's the mouse you currently have or because you're considering it?
Offline tbc
Re: Razer Naga
« Reply #2 on: Sun, 10 November 2013, 20:19:55 »
you want your mouse to last more than five years?
you get a long lasting mouse or a good mouse.  pick one.
Offline MsYutai
Re: Razer Naga
« Reply #3 on: Tue, 12 November 2013, 12:01:12 »
I've been using a Logitech Performance MX mouse for the past 4 years, working just fine still!
CM Storm Quickfire XT - MX Reds
Roccat Kone Pure Optical|Kana v2|Zowie FK|Logitech g500s|Mionix Naos 7000|CM Spawn|Logitech Performance MX
Offline Oobly
Re: Razer Naga
« Reply #4 on: Wed, 13 November 2013, 05:49:05 »
Hmm. I don't know. Sounds like you could use almost any mouse made nowadays. I'd steer clear of Razer in general, their quality control hasn't been great in the past.
I'd go for an optical sensor since they tend to be lower DPI (more settings at the lower end) and more accurate than laser.
Maybe try a Logitech M500? It's wired, seems to have the thumb buttons in a sensible place and looks like it may fit the hand something like the original Intellimouse.
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Candyflip
Re: Razer Naga
« Reply #5 on: Wed, 13 November 2013, 06:28:43 »
not sure if serious, if yes then no new mouse will last you that long with excessive gaming
Offline davkol
  •  Post Editing Timeout
Re: Razer Naga
« Reply #6 on: Wed, 13 November 2013, 12:31:57 »
And it has an ~1000dpi laser sensor IIRC.
Offline Calcifar
Re: Razer Naga
« Reply #7 on: Wed, 13 November 2013, 15:55:51 »
I would recommend the logitech 900 or a steelseries xai.
Offline Oobly
Re: Razer Naga
« Reply #8 on: Thu, 14 November 2013, 04:17:20 »
Another possible option? The Zowie EC eVo CL:
http://www.zowiegear.com/index.php?i=news&p=52
