Author Topic: G710 Logitech Question  (Read 5596 times)
Offline giltyler
« on: Sun, 10 November 2013, 15:13:16 »
I have acquired a new G710 keyboard and I pulled a key to look at the Cherry MX Brown and noticed a small thin black o ring and want to know if that is the same thing as an o ring mod?
Key Cap also seems flimsy
http://
« Last Edit: Sun, 10 November 2013, 15:15:14 by giltyler »
Re: G710 Logitech Question
« Reply #1 on: Sun, 10 November 2013, 15:14:54 »
It is. G710 comes with them out of the box.
Offline tbc
« Reply #2 on: Sun, 10 November 2013, 16:49:47 »
anything you can buy off the shelf will have flimsy keycaps
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #3 on: Sun, 10 November 2013, 19:14:32 »
Except higher end boards (not that the G710+ isn't high end) such as the nighthawk, Shine 3, Keycool. And such. But yes that is the same thing as the o-ring mod.
« Last Edit: Sun, 10 November 2013, 19:26:19 by HUNTERANGEL121 »
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Sun, 10 November 2013, 19:15:08 »
Yup its the same :)
Offline kaotikb
« Reply #5 on: Sun, 10 November 2013, 19:28:30 »
I had a 710 keyboard and didn't like it. I ended up returning it. The key caps seem to look the same as the gigabyte osmium ones, minus the o ring.  I ended up changing the key caps on the osmium since i didn't like them either.
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #6 on: Mon, 11 November 2013, 16:58:48 »
I had a G710+ for review and the G5 keycap came in broken (in order: G710, Tt Meka G-Unit, Metadot Das Keyboard (Costar), Corsair K70 and CM Storm Trigger.
I was quite dissapointed, but in the end I gave it a 7/10 grade, it's average, but it surely ain't a high-end keyboard, starting by the low-quality keycaps. Same can be said for the Tt Meka G-Unit (5/10) and Corsair K70 (8/10).
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline catnipz0098
« Reply #7 on: Mon, 11 November 2013, 17:00:52 »
Aren't most backlit keys that quality?
Offline tbc
« Reply #8 on: Mon, 11 November 2013, 17:50:45 »
those aren't off the shelf. ;P can't say I've ver seen them at bestbuy or a non-mech shop.
are the shine 3 keycaps better than the zero shine series?  cause the 2108s aren't anything special.
Offline wetto
« Reply #9 on: Mon, 11 November 2013, 17:59:36 »
Nope, even though they're from the same place, the K70's are a bit better (not too much) and the CM Storm Trigger and Ducky Shine III keycaps are far better in terms of material and width.
My collection:
Offline C5Allroad
« Reply #10 on: Mon, 11 November 2013, 18:27:59 »
The best buy in Aventura here in Miami has mechanical boards... Granted they are Razer, Logitech, and Corsair.
I haven't used the zero shine, but I think they are the same. But looking at the price point of it, it might be different. If you want I can post pictures of my caps.
Offline wetto
« Reply #11 on: Mon, 11 November 2013, 18:34:55 »
Easiest way is to check if there's a mark left by the molding or not behind the keycaps of the Ducky Shine III and Shine Zero:
The Shine II had those because they're keycaps made by a Taiwanese vendor, his keycap tooling leaves that mark.
My collection:
Offline C5Allroad
« Reply #12 on: Mon, 11 November 2013, 18:41:03 »
Shine 3 has that.
Offline tbc
« Reply #13 on: Mon, 11 November 2013, 19:19:34 »
thanks, but I'm actually getting my shine 3 in about 3 weeks, so I'll do a RL feel test for myself.
Offline C5Allroad
« Reply #14 on: Mon, 11 November 2013, 19:50:58 »
Congrats! Amazing board!
Offline giltyler
« Reply #15 on: Wed, 13 November 2013, 15:42:57 »
Thanks for the input on the Caps, For something that retails at $149.99 (I only paid $109.06 out the door) I would have expected better key caps and a puller with some alternate keys
The Brown MX switches seem very nice though and the o rings make it quicker for me to use
Offline C5Allroad
« Reply #16 on: Wed, 13 November 2013, 16:08:33 »
Yes! Browns and o-rings are amazing!
Offline 1391406
« Reply #17 on: Wed, 20 November 2013, 15:41:07 »
Anyone know what size the o-rings are on the G710? WASD sells 0.2mm and 0.4mm. I'm guessing they're probably 0.2mm.
Offline tbc
« Reply #18 on: Wed, 20 November 2013, 16:01:47 »
backlit keycaps are all kinda crappy (although deck has some pretty nice ones according to the vendors).
you're paying most of the money for the brand name and the customer support.
Offline Grendel
« Reply #19 on: Wed, 20 November 2013, 18:48:26 »
AFAICR they are the same as these, that would be 0.4mm reduction.
- I'm game !
