Author Topic: Cherry MX switches tester board  (Read 14857 times)
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« on: Mon, 11 November 2013, 07:39:20 »
Hi all
I'd love to have my finger on all available Cherry MX switches on the market. This post is dedicated to be the place for all Cherry MX switches tester on the market. s
One round of Google, give me results:
* CMStorm Tester (http://www.cmstore-usa.com/mechanical-key-switch-demo-board/)
* QWER Switch Testing Kits (http://www.qwerkeys.co.uk/shop/index.php?route=product/category&path=75)
* Max Mechanical Keyboard Cherry MX Brown Black Blue Red Switch Sample Tester Kit
* Ultimate Switch Tester (http://geekhack.org/index.php?topic=44880.0)
* WASD Sampler Kit (http://www.wasdkeyboards.com/index.php/wasd-sampler-kit.html)
* CaptainBadAss Custom Switch tester (http://geekhack.org/index.php?topic=44312.msg989199#msg989199)
any more?
I created this poll on Massdrop (https://www.massdrop.com/vote/cherry-mx-sampler-kit) and let's hope we have enough ppl reigster so we could buy this sampler kit cheap!
« Last Edit: Mon, 18 November 2013, 19:19:32 by joneslee85 »
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline BlueBär
Re: Cherry MX switches tester board
« Reply #1 on: Mon, 11 November 2013, 08:00:21 »
WASD keyboards has one too.
Offline Moosecraft
  • HHKB Pro
« Reply #2 on: Mon, 11 November 2013, 09:32:23 »
There has also been several community switch testers going around.
Offline kolonelkadat
  • Location: the vicinity of an area adjacent to a location
    • Force Project X
« Reply #3 on: Mon, 11 November 2013, 12:25:29 »
Its not for sale, so i dont think you can call it on the market, but this is the one you want.
"Obviously, windows are central to Windows. But what is a window?"
« Reply #4 on: Mon, 11 November 2013, 12:33:11 »
Offline osi
« Reply #5 on: Mon, 11 November 2013, 12:44:19 »
WASD has a sampler kit which I bought. The downside is that the switches don't come mounted to anything. They are just "loose" switches with keycaps. They definitely get the job done though. I made a pseudo-case for them out of cardboard.
http://www.wasdkeyboards.com/index.php/products/sampler-kit-1.html
Cooler master just released a sampler kit but are in very limited quantities right now.  From their last post here, they should have some more before Dec 1st so you'll have to keep an eye out.
Can't speak on the one you mentioned though.
« Reply #6 on: Mon, 11 November 2013, 14:20:46 »
I ordered the QWER Switch Testing Kit cant wait to get it!
I have an idea or has it been done?
Can anyone make a Topre testing kit? The different weights and then maybe some dental bands on them for silenced options?
Offline BlueBär
« Reply #7 on: Mon, 11 November 2013, 16:20:17 »
To make it short, Topre switches are not modular, so it's hard to do a switch tester. For doing one the easiest way would probably be cutting down a Topre board.
« Reply #8 on: Mon, 11 November 2013, 16:21:15 »
There was a topre tester at deskthority, that's the only one I've seen.
« Reply #9 on: Mon, 11 November 2013, 17:09:05 »
Interesting, thanks!
« Reply #10 on: Mon, 11 November 2013, 17:52:26 »
I'm putting together a tester with all the common switches, all the common springs you can buy, and will also be including some less common switches like a linear grey and white(s).  I'm just waiting for some more stuff to come in for it and waiting to see if I'll have to buy some switches and springs for it.  Once it's together, I plan on touring it.
Offline Arbalest
« Reply #11 on: Wed, 20 November 2013, 15:30:35 »
It's nice that the Cooler Master tester ($15) purchase gives you a $15 credit towards one of their boards.  Too bad that it doesn't come with the o-rings as does the WASD keys set.
Question 1 - I have a bunch of plumbing o-rings (all sizes). Is it likely that the right size will be as functional as "official" damping o-rings?
Question 2 - does ANYBODY sell a numeric keypad that is also a key tester?  That way I (or anyone else) can go with a TKL board and have their tester usable for something else after their key choice has been made.
« Last Edit: Wed, 20 November 2013, 15:43:29 by Arbalest »
Offline tbc
« Reply #12 on: Wed, 20 November 2013, 16:11:59 »
how the hell is the qwerkey tester winning in the pools....?
I would have thought the linus video would have pushed the cm storm tester into the stratosphere.
« Last Edit: Wed, 20 November 2013, 16:39:49 by tbc »
« Reply #13 on: Wed, 20 November 2013, 16:15:46 »
hell yea love my qwer tester, would love one or one hundred more ;p
