Author Topic: Buying my first mechanical keyboard, help !  (Read 7813 times)
Offline JusticeBreaker
« on: Mon, 11 November 2013, 11:28:07 »
Hello everyone  ;D,
so I've been playing video games for quite a long time on a rubber dome keyboard and then a friend of mine told me about mechs, I tested his keyboard (Corsair K60 i believe, I also tested blackwidow) and i fell in love with it  :D
Now I want to purchase a mechanical keyboard, a red switch one and I found 4 keyboards but I don't know which one to choose (I tried to compare them but I really can't choose  :()
Those 4 keyboards are:
- CM Storm Quickfire TK
- CM Storm Quickfire Rapid
- CM Storm Quickfire Stealth
- Steelseries 6GV2 red version
I searched but I can't find any difference between these keyboards (except maybe the number pad which i don't really need), even though i have a small preference for the 6gv2 (it looks really solid and simple)
So yeah... I'd be happy if you could help me choose one of them, thanks in advance  ;D
  • Live long and prosper
Re: Buying my first mechanical keyboard, help !
« Reply #1 on: Mon, 11 November 2013, 11:34:10 »
The QuickFire Rapid is probably your best bet, their quality is comparable to that of Filco boards.  I've had mine for over a year and it's still my favorite board.  I would imagine the Stealth is essentially identical to the QFR, minus the side-printed caps.
tp thread is tp thread
Offline stancato9
« Reply #2 on: Mon, 11 November 2013, 11:37:13 »
Definitely the Quickfire Rapid. You said you don't really need the numpad so you will like the layout a lot. It makes the experience a whole lot better being able to move between mouse and keyboard with ease.
The build quality is also up there. They are often compared to filcos which are regarded as one of the best keyboard manufacturers.
If you care about changing the keycaps and the customization aspect of it, the QFR will also be great. It has one of the most common layouts and you can find a ton of keycap sets for it. The other ones will be harder to find caps for as they aren't as common; the 6GV2 even has an ISO layout.
Also, go with the stealth if you like the aesthetic of the blank keys. Not only do you not have to worry about the legends fading over time, but it will actually force you to better your typing skills.
Poker 2 - MX Red
« Reply #3 on: Mon, 11 November 2013, 13:50:32 »
Thank you very much for your answers guys  :)
I'll buy the QFR  :D
Offline eth0s
  • Peace & Love
« Reply #4 on: Mon, 11 November 2013, 13:52:24 »
QFR has been the nub's favorite starter keyboard for like 2 years now.
« Reply #5 on: Mon, 11 November 2013, 15:22:39 »
Welcome to Geekhack!
Another vote for QFR - standard layout, good quality, good support, horrible legends (easily remedied), highly customisable.
Or, if you want backlighting, what about Ducky?
Offline Neal
  • Skype: iNewbcake
« Reply #6 on: Mon, 11 November 2013, 16:30:59 »
  • CM Storm Quickfire TK
Non standard layout and bottom row, oddsize spacebar and has some odd bug that might've been fixed on some models.
  • CM Storm Quickfire Rapid
Standard layout/spacing, comparable to Filco quality. Perfect starter board.
  • CM Storm Quickfire Stealth
Same as above, but IMO a better look. I find the font to be unpleasant to look at, this hides it a bit.
  • Steelseries 6GV2 red version
Non standard layout and bottom row, korean style enter and a short right shift. This board is IMO the worst board anyone can buy, sure its cheap as ****. But the layout is SO weird, and the left windows key is a fn key instead that enables media keys. its non rebind-able and just completely ****s up the keyboard IMO. I use windows a lot, I need a windows key for shortucts. Would've been a lot better if they'd put that one on the right side.
All in all, I'd go for the CM Storm Quickfire Stealth.
You're on GeekHack after all, you're probably going to buy some after market keyset someday. And you'll need a somewhat standard layout/spacing for that.
« Last Edit: Mon, 11 November 2013, 16:34:37 by Neal »
« Reply #7 on: Tue, 12 November 2013, 09:11:31 »
So the QFR and the QFStealth are "equal" in terms of quality, uh ? So it's only about look preference ?
Btw I can't find any Ducky keyboard for  <100$ in france  :(
Offline Tony
« Reply #8 on: Tue, 12 November 2013, 09:17:13 »
CM QFR is recommended. It has standard layout, and cheaper price. I don't know about QFR stealth though.
Offline lonedruid
  • Red switch fan
« Reply #9 on: Tue, 12 November 2013, 13:19:38 »
I have a red 6gv2 and I love it  ;D quite good to play dota 2 with it. Dont get STEALTH for god sake. U will regret it.Imagine you playing dota, in the heat of battle, u nneed to talk to teammatte or use number key set as some hotkeys. U wont be able to find it!!!! No matter ur typing skills are!!!! Bcuz your hands wont be in normal typing position during gaming cuz ur right hand will alwayys be on ur mouse and u will nid to keep looking down when u nid to press those keys at the right side. And in the heat of battle I am scrambling on my 6gv2 for that full stop hotkey. Without printed keycapd? Please  u will play better on a 10 dollars dell keyboard. Tats why filco dont have ninja series for its multicam gaming keyboard and most of the gaming mech companies dont have stealth versions.in fact cm is the only one I know!!!
U can also consider filco. I planning to get filco multicam blues   :p
Steelseries 6gv2 red switch
Ducky shine 3 TKL blue switch http://i.imgur.com/5LcUxh.jpg
HHKB Professional 2 no-blank http://i.imgur.com/JSIa1.pngk
Offline lonedruid
  • Red switch fan
« Reply #10 on: Tue, 12 November 2013, 13:34:25 »
 :cool:I forgot to mention. No need get ducky for gaming..imho ducky is for people who want their keyboard to be lit up like some ITmall whose cocorridor is littered with shops that sell neon lightings. And it ooze that chinese feeling with chinese zodiac spacebar and lighting styles that is reminiscent of some sleazy hong kong restaurant.  Of cuz if u r after chinese-fashion kb. Nothing can beat the duck. ;D
Offline stancato9
« Reply #11 on: Tue, 12 November 2013, 22:29:13 »
While this is true, this will happen maybe for a week. After that you will know where every key on the keyboard is :) If you aren't an experienced touch typer now, you will be after buying a keyboard with stealth caps.
Also, Filco do make a stealth board. It is called the Ninja.
Poker 2 - MX Red
Offline PointyFox
« Reply #12 on: Tue, 12 November 2013, 22:31:18 »
The Stealth is just the QFR with side printed keys.  The printing wears off pretty fast on the QFR keys.
« Reply #13 on: Tue, 12 November 2013, 22:35:03 »
Most people swap their QFR keycaps out pretty quickly anyway.
Offline lonedruid
  • Red switch fan
« Reply #14 on: Wed, 13 November 2013, 01:49:25 »
Stancato. I check at filco homepage. They dont have ninja for their gaming series
Offline Candyflip
« Reply #15 on: Wed, 13 November 2013, 06:57:16 »
Indeed, I know a couple of guys (including myself) who ordered the QFR + pbt caps to replace the CM ones on start
Offline Emospence
« Reply #16 on: Wed, 13 November 2013, 10:59:03 »
Stealth or Rapid, depending on where you want your legends
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
Offline neha_aks
« Reply #17 on: Sun, 01 December 2013, 21:04:58 »
I am leaning towards QFR/Stealth (haven't decided on the keypad style yet) and this is my first mechanical keyboard as well. So probably this question might sound stupid but is QFR compatible with Mac? Would I be able to remap the keys to switch the positions of Cmd and Alt?
I ask because the same product on mechanicalkeyboards.com mentions Mac compatibility:
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=73
but on Amazon it doesn't :
http://www.amazon.com/CM-Storm-QuickFire-Rapid-Mechanical/dp/B007VDLVD4/ref=cm_cd_al_qh_dp_t
Offline gh_pp
« Reply #18 on: Sun, 01 December 2013, 22:17:34 »
There are not many keyboards that comes with DIP switch for hardware swap of cmd & alt, but OSX has build-in preference for changing that, so you don't have to worry about it.
Any USB PC compatible will work under osx. However if you want the Fn (brightness, volume) keys, you'll need to get keyboards just for Mac.
QFR $70 + thick doubleshot or PBT keycaps $100
That's all you need until you're ready to spend more than > $300
« Last Edit: Sun, 01 December 2013, 22:20:19 by gh_pp »
QFR brown x2, Realforce 45G, Type-S, Keycool 22 blue
Previous keyboards: 55G, IBM Model M, Dell AT101W, Fujitsu FKB4725, G80-3000 clear, QFS green, QFS blue
[WTB] Custom keyboard build
Offline terran5992
  • One With The Cup Rubber
« Reply #19 on: Sun, 01 December 2013, 22:38:06 »
If you have the budget . Get the HHKB or realforce
« Reply #20 on: Mon, 02 December 2013, 03:24:57 »
I have used QFR and QFS no a Mac - no worries.  Just use System Preferences to swap Alt and Win.  Everything else works well, including Expose.
Offline PointyFox
« Reply #21 on: Mon, 02 December 2013, 06:22:59 »
Wouldn't it be if he doesn't have a budget? :P
Offline phoenix1234
« Reply #22 on: Mon, 02 December 2013, 06:28:55 »
Hello everyone  ;D,
If you are in the US, you should consider this one :
www.bestbuy.com/site/cooler-master-cm-storm-quickfire-stealth-mechanical-gaming-keyboard-and-spawn-optical-mouse/1501444.p?id=1219052965240&skuId=1501444
I like linear switches
Offline neha_aks
« Reply #23 on: Mon, 02 December 2013, 19:02:16 »
Thank you all ! I tried the blue and brown switches today and I think I like the brown.  :thumb:
I was worried about the noise factor but I think the brown is not that noisy and I can get the WASD O-rings if the noise really annoys me. For keycaps  I might go with the stealth.
And I looked at HHKB - I dont think I'd survive its layout - I dont like the number and function key overlap in HHKB.
Offline 1pq
  • Hipster Doofus
« Reply #24 on: Mon, 02 December 2013, 19:36:03 »
Don't start that, seriously...
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #25 on: Mon, 02 December 2013, 19:38:19 »
HHKB is a 60% board with a completely different switch. If you want a full sized/TKL board with more or less the same switch and probably also a more sane price. There are Realforce keyboards/Leopold FC660C/Type Heaven to look at.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
Offline lilky
« Reply #26 on: Mon, 02 December 2013, 20:23:56 »
Whatever you buy, you won't regret it. Welcome to the mechanical keyboard world :D
Offline Pacifist
  • on hiatus
« Reply #27 on: Mon, 02 December 2013, 21:00:13 »
Get the QFR
« Reply #28 on: Tue, 03 December 2013, 04:19:37 »
Did you try typing on the HHKB?
Just to get the feel of the Topre switches?
Although really you have to use Topre for a couple of days to really get the feel for it.  And after a maximum of two weeks it is said that you will find it difficult to switch back to MX.
I am too happy with all my keyboards, including BS :))
Offline 1pq
  • Hipster Doofus
« Reply #29 on: Thu, 26 December 2013, 12:09:59 »
I don't think I actually fully appreciated topre until after a month or two of using it, honestly.
It's odd though, I prefer Topre for typing English words, but when I have to write anything in fast spurts, I prefer MX (e.g. coding, keymashing (gaming)).
Offline BlindxLegacy
  • In my feelios
« Reply #30 on: Thu, 26 December 2013, 15:29:37 »
I really like the keycool 84. Small body, tenkeyless, PRETTY LIGHTS!, standard design, solid, relatively cheap at $115
« Reply #31 on: Thu, 26 December 2013, 19:17:22 »
That is the case for a lot of people - Topre is kinda meh, but after using it for a while and then switching back to MX you start really missing Topre.  At that point some people simply sell all their MX keyboards, invest in another Topre board or two, a few keycaps sets, and they are set for life.
Offline PointyFox
« Reply #32 on: Thu, 26 December 2013, 19:48:08 »
I just got a Topre after trying every MX switch and Topre is what rubber dome should be, and what MX wants to be.
« Reply #33 on: Thu, 26 December 2013, 19:50:21 »
So does that mean you like it?
« Reply #34 on: Thu, 26 December 2013, 20:00:09 »
Interesting way to put it :)
