Author Topic: New Ducky - Squeaky Spacebar  (Read 3124 times)
Offline BucklingSpring
« on: Mon, 11 November 2013, 18:38:43 »
Hi Guys,
43524-0
How do you lube this thing?
I just tried to inject some Jig-A-Loo under the stabilizer stems near the wire. The squeaking is gone for now.
« Last Edit: Mon, 11 November 2013, 18:43:24 by BucklingSpring »
Boards I own, click ->
Offline terran5992
  • One With The Cup Rubber
Re: New Ducky - Squeaky Spacebar
« Reply #1 on: Mon, 11 November 2013, 19:08:38 »
Gonna be hard to lube this
« Reply #2 on: Mon, 11 November 2013, 19:13:40 »
Yeah, When I saw that under PCB stabilizer bar... I thought hum, how am I going to get there without tearing the whole thing apart?
Offline terran5992
« Reply #3 on: Mon, 11 November 2013, 20:13:36 »
I dont think its possible. You have to remove the pcb to lube it
Offline laffindude
« Reply #4 on: Mon, 11 November 2013, 20:16:36 »
Uh no. You can drop a bit of lube where the stabilizer clips into the stabilizer body. That is visible from the top.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #5 on: Tue, 12 November 2013, 08:43:57 »
That's a plate mounted cherry stabilizer.
Desolder the switch and remove it.  You will then be able to remove the stabilizer through the slot. :thumb:
Pardon the quality.
« Reply #6 on: Wed, 13 November 2013, 11:38:43 »
Euh... Thanks but no :-)
I can clearly see from your pic that the bar is hold at the extremities. Gentle spray there from the top will deliver enough lubricant to resolve the problem. Which I did and so far so good.
But thanks for the detailed brain surgery protocol :-)
Pardon the quality.
