Author Topic: Rosewill label removal  (Read 2724 times)
Offline keymaster
  • Topre Revolution Theorist
« on: Tue, 12 November 2013, 16:41:57 »
Has anyone had experience removing this label from a Rosewill keyboard? I did a small search on the forum but couldn't find a successful method.
Re: Rosewill label removal
« Reply #1 on: Tue, 12 November 2013, 16:44:16 »
SmallFry told me that a pencil eraser would work. I tried that, and only ended up scratching up the top, although it did remove the printing. :)
How about this?
« Reply #2 on: Tue, 12 November 2013, 17:07:03 »
Ive also thought about removing mine.. But I kind of like it, it is cursive and looks nice. I saw one guy paint his white.
Offline jalaj
« Reply #3 on: Tue, 12 November 2013, 17:35:50 »
found this this post from [H]:
http://hardforum.com/showpost.php?p=1038495762&postcount=28
Sounds suspect, but doesn't seem like it'll hurt to try.
All you need is sugar and a vacuum.
This website probably inspired his methodology.
http://www.instructables.com/id/How-to-remove-Logos-from-your-PDA--cell-phone-wit/
« Last Edit: Tue, 12 November 2013, 17:38:09 by jalaj »
Offline keymaster
« Reply #4 on: Tue, 12 November 2013, 18:17:00 »
Thanks for this. I'll give it a try.
« Reply #5 on: Tue, 12 November 2013, 18:18:23 »
whoa.. interesting..  Someone try it!
