Author Topic: Special programming on Poker II?  (Read 1484 times)
Offline minho
  • i'm kind of back
« on: Wed, 13 November 2013, 17:48:21 »
UIs there any way to set my right control key or Pn key on the Poker II as a permanent toggle for Fn? (for example, I could just press the hypothetical Fn toggle key once and then all the keys would just behave as if Fn was pressed down.)
Additionally, is there a way to arrange so that the spacebar led or the left window would turn on whenever this hypothetical Fn toggle is on?
Offline lcs
  • Lover of Grape Drank
  • はやく
Re: Special programming on Poker II?
« Reply #1 on: Wed, 13 November 2013, 17:53:22 »
Don't take my word on this, I may be totally wrong.
I don't think you can remap any other key to fn because the fn is all hardware, so you wouldn't be able to set it via autohotkey or something similar.
Again, I don't have a poker and I may be (and probably am) totally wrong.
Offline JayG30
« Reply #2 on: Wed, 13 November 2013, 21:02:40 »
I don't believe you can set the right Ctrl to be Fn. You can however use the left Fn+space bar to lock the Fn layer until you press Fn+space bar again to unlock.
« Reply #3 on: Wed, 13 November 2013, 21:16:52 »
with DIY anything is possible.
You could get an MX lock switch and make a simple controller to control just that one LED. It would run from USB power, fit in the case and I don't think it'd affect the normal controller (unless the impedance is really low, which is doubtful)
