Author Topic: What are White O ring switch dampeners like?  (Read 4548 times)
Offline berserkfan
Offline terran5992
  • One With The Cup Rubber
Re: What are White O ring switch dampeners like?
« Reply #1 on: Thu, 14 November 2013, 02:28:12 »
Reduces the key travel distance and makes the switch feel squishy
Offline berserkfan
« Reply #2 on: Thu, 14 November 2013, 06:21:32 »
Don't the red o rings do that also?
I'm trying to understand the difference between red, blue, black and white o rings.
Offline Oobly
« Reply #3 on: Thu, 14 November 2013, 07:09:02 »
Different materials and different thicknesses. Thicker reduces travel more, softer feels squishier. Those whites are thick and soft, so they reduce the travel more than others and feel squishy... I much prefer reds, although I have moved on to a better mod (trampoline mod): http://geekhack.org/index.php?topic=50632.0
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #4 on: Thu, 14 November 2013, 08:12:25 »
Ordered some of these from the same seller...still waiting for them in the mail.
I got them primarily because they are clear/translucent and would play better with my Shine II.
When I get them, I can compare them to the black o-rings that I already have.
« Reply #5 on: Thu, 14 November 2013, 08:19:02 »
I have some of those, never even opened the package...
Offline berserkfan
« Reply #6 on: Thu, 14 November 2013, 09:20:29 »
You spam too much and don't do enough work  ;D
Open that package now, mount the rings and write a review, good sir!  :thumb:
« Reply #7 on: Thu, 14 November 2013, 09:27:34 »
Sadly is true, but all my spamming is done while at work and all my stuff is at home, where I only spend ~3-4 hours other than when I sleep :P
Offline berserkfan
« Reply #8 on: Thu, 14 November 2013, 21:41:44 »
In other words, you talk a lot about keyboards, but most of the time you use your employer's rubber domes?
Offline catnipz0098
« Reply #9 on: Thu, 14 November 2013, 21:58:26 »
What do the colors do in terms of size and feel?
Offline Oobly
« Reply #10 on: Fri, 15 November 2013, 05:01:58 »
'Ello, 'ello, 'ello! What 'ave we 'ere? Would sir care to leave racism out of this, please, not to mention the unmentionables alluded to in sir's innuendous comment. Sir. Please. Sir.
Depends where they're from. Some use different colours to indicate the material used.
« Reply #11 on: Fri, 15 November 2013, 06:47:22 »
Sadly is true, but all my spamming is done while at work and all my stuff is at home, where I only spend ~3-4 hours other than when I sleep :p
NEVER!
 I use a ducky shine II with stock clears and originative dolch with a smooth operators spacebar and esc key.  :thumb:
Offline berserkfan
« Reply #12 on: Fri, 15 November 2013, 07:12:27 »
Ducky Shine has clears?
Also, what is an operators' spacebar?
And how do you find your clears at work? Any complaints from co workers? (Answer only if you don't have your own office. A cubicle doesn't count as an office with walls and door you can close when you are typing.)
NEVER!
« Reply #13 on: Fri, 15 November 2013, 07:24:27 »
NEVER!
Yes the Shine II had clears.
Smooth operators are flocked key's by Krogenar
http://geekhack.org/index.php?topic=47194.0
I do have an office, but I find them fairly quiet and no one has said anything, I don't pound too much and try not to bottom out, but when I first tried blues, my boss complained a lot, his office is next to mine.
