Author Topic: Topre replacement keycaps - pbt?  (Read 10495 times)
Offline kansas city shuffle
« on: Thu, 14 November 2013, 02:35:26 »
Anyone know if the replacement Topre keycaps on elitekeyboards.com are PBT?
http://elitekeyboards.com/products.php?sub=access,toprekeys&pid=xf0100kt1
Offline terran5992
  • One With The Cup Rubber
Re: Topre replacement keycaps - pbt?
« Reply #1 on: Thu, 14 November 2013, 02:37:39 »
« Reply #2 on: Thu, 14 November 2013, 03:32:22 »
Offline atlas3686
  • HHKB Elite
« Reply #3 on: Thu, 14 November 2013, 03:37:33 »
All Topre spacebars are ABS as far as I know. (except maybe the tiny Japanese spacebars)
Offline terran5992
« Reply #4 on: Thu, 14 November 2013, 03:44:00 »
Yes they are
Including the space bar? Or is that ABS?
Oh yeah that pesky spacebar. They should be in ABS
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #5 on: Thu, 14 November 2013, 04:44:50 »
Yes they are
Hahaha some people just can't get over the tiny spacebar found on the JIS variants. Even though they really don't make much difference to a real touch typist they still get to be labeled as something bad. I honestly can't see how it would be the tiny spacebar would be bad.
Also to the OP, fyi elitekeyboards.com isn't the only place where one can order replacement keycaps for Realfroce, HHKB, etc. there are some sellers on amazon and ebay for instance selling Realforce replacement key caps (though notably Japanese legends, but the spare set I believe caters for both JIS/non-JIS keyboards. The only real difference are that the Realforce replacement key caps cannot be sold individually and they come with Japanese legends.
HHKB Pro JP Type-S | Northgate Omnikey 101 | APC/"Clicker" F-21 (GOG3YL) | Cherry G80-5000 HAMDE
僕の日本語が下手です。我的中文也一樣爛。
« Reply #6 on: Thu, 14 November 2013, 04:55:28 »
Yes they are
Cheers for the input mate, I'll keep an eye out.
Offline tuxsavvy
  • 白HHKBの魔法使い
« Reply #7 on: Thu, 14 November 2013, 05:24:12 »
Yes they are
No worries!
I have a wad of amazon links just to give you a bit of headstart I guess. Note that these replacement key caps all have Japanese legends printed on them as well as the English legends. Of course not for all the keys but the majority are.
SA0100KT-1 (white): http://www.amazon.com/Topre-Japanese-Replacement-Realforce-Sa0100-kt1/dp/B004U8IVMC
SA0100KT-2 (blue): http://www.amazon.com/Topre-Japanese-Replacement-Realforce-Sa0100-kt2/dp/B004U8IVPE
SA0100KT-3 (red): http://www.amazon.com/Topre-Japanese-Replacement-Realforce-SA0100-KT3/dp/B004U8IVVS
SA0100KT-4 (yellow): http://www.amazon.com/Topre-Japanese-Replacement-Realforce-Sa0100-kt4/dp/B004U8IW3A
SA0100KT-5 (orange): http://www.amazon.com/Topre-Japanese-Replacement-Realforce-SA0100-KT5/dp/B004U8IWBM
Of course these were meant to be for a specific Realforce keyboard but you can still more or less mix and swap. I've done it already with my HHKB JP (following what jdcarpe did once).
There is wad of links and information if you are curious:
Offline salvanipour
« Reply #8 on: Fri, 24 February 2017, 13:04:44 »
Sorry to bump an old thread, but I've tried searching and couldn't find an answer. Does any know if EK's non-printed red Topre keycaps are PBT? These are the ones in question:
http://www.elitekeyboards.com/products.php?sub=access,toprekeys&pid=hh_redescn
I emailed twice and they never replied.
« Reply #9 on: Sat, 25 February 2017, 13:17:54 »
Rule of thumb: If it's got a Topre stem and isn't a spacebar, 99% chance it's PBT.
Offline salvanipour
« Reply #10 on: Sat, 25 February 2017, 13:51:23 »
Awesome, thank you for the reply! Their site doesn't seem to want to take an order for any quantity of the blank red keycaps. I guess I'll have to give them a call on Monday.
« Reply #11 on: Sat, 25 February 2017, 15:40:57 »
You might be disappointed. Custom Topre keycaps are nigh impossible to get anymore. If you're doing custom caps it might be worth looking into 3D printing.
« Reply #12 on: Wed, 07 June 2017, 05:52:20 »
Although not that shade of red, and almost certainly not PBT, HKP has a sale on at the moment for Topre keycaps.
https://geekhack.org/index.php?topic=89208.0
These are excellent quality - highly recommended.  And there are some reddish ones there.
