Author Topic: Max Universal Cherry MX Translucent Clear Black Key Caps  (Read 2884 times)
Offline Danule
« on: Thu, 14 November 2013, 07:16:18 »
Anyone have any experience with these? Are they good quality?
http://www.maxkeyboard.com/max-universal-black-translucent-mechanical-keyboard-keycap-set.html
thanks!
45g Brown Brown Blue
Offline esoomenona
  • Gnillort?
Re: Max Universal Cherry MX Translucent Clear Black Key Caps
« Reply #1 on: Thu, 14 November 2013, 08:53:36 »
They look like your average plastic caps.
The size of the legend printed on the front means you most likely won't even be able to see what it is when the backlighting is turned on.
Offline Danule
« Reply #2 on: Thu, 14 November 2013, 09:25:13 »
could be,  they do look rather cool, its like a tinted clear keycap.
Offline klikkyklik
    • Klikky Klik
« Reply #3 on: Fri, 15 November 2013, 17:41:21 »
I'd ordered their little sampler kit for testing on my Corsair K70.  This is what they look like.  They have an identical sound to the other K70 keycaps.  The sampler didn't have lettering on them.
44240-0
44242-1
Offline Jrwestcoast
« Reply #4 on: Fri, 15 November 2013, 18:28:28 »
I have them with some blue LEDS and esoomenona is correct they feel like your average plastic caps and you will not be able to see the legend that is printed on the front.
