Author Topic: PBT 104/105 set ROUND 3 (COMPLETED)  (Read 710330 times)
Offline zippox
Re: PBT 104/105 set ROUND 3 (SHIPPING!)
« Reply #2250 on: Thu, 30 April 2015, 09:33:52 »
People in the states getting their keys - are these coming via USPS? My apartment has all sorts of wacky rituals that need to be conducted before I can pick up packages and different shipping companies require different rites to be conducted.
Maybe you should pick up a sacrificial lamb on the way home.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2251 on: Thu, 30 April 2015, 12:30:44 »
In regard to the color... yes they are a bit grey, as they had to be so dyesub would still show up. Whether you want to call it very dark grey, or light black... I don't know. Can't use true black key for printing as it would have been totally invisible. I do also have a set of the dark Cherry profile KBC/Vortex that I got on the massdrop. Those are a shade lighter than these to my eye. The color temperature is also different. These are more 'blue' hued, while I feel the Vortex ones are more 'brown' hued. Can't take a photo that shows the difference with my crappy low res phone camera.
Offline spookymikal
« Reply #2252 on: Thu, 30 April 2015, 13:49:50 »
I just got my keys and started slapping em onto my KUL ES-87. It's a pretty common board, so if anyone else is in my shoes let me know:
Basically, my space bar is sticking with this new one. I put on the old one and it works just fine but when I press the spacebar with the new guy on there it's not springing back up correctly, it's like he just wants to be there bottomed out. Any tips?
P.S. they look sexy as hell Ivan is Awesome!
edit- if i just *barely* press it onto the switch then it's working just fine now. it sits a few mm higher than the other keys though. Think it just needs to be "worn in"
Edit 2: Potato pic. I use a black cable @ home, white was all I had onhand at the office.
98965-0
« Last Edit: Thu, 30 April 2015, 15:35:22 by spookymikal »
Offline badboybry9000
« Reply #2253 on: Thu, 30 April 2015, 16:20:19 »
I had a similar problem with my spacebar but on a much different keyboard so I don't know if this will help you in any way. My keyboard is a modded filco with a universal TKL plate and cherry stabilizers. My problem ended up being caused by the stabilizer bar. It was probably 1mm too wide so it was binding against the inside of the stabilizer assembly. I had to shave off some metal with a dremel.
Offline Flyersfan1
  • Hi!
« Reply #2254 on: Thu, 30 April 2015, 16:22:13 »
If anyone has a printed set they're looking to part with, please contact me!  ;D
Quote from: Photekq
Offline pr0ximity
« Reply #2255 on: Thu, 30 April 2015, 17:15:57 »
+1 most likely your stabilizer is rubbing
Offline Latin00032
« Reply #2256 on: Thu, 30 April 2015, 20:46:36 »
+2. Stabilizer is rubbing. You need to sand or "shave" the inside of the spacebar to give the stabilizer an extra .25mm of room on the insides of both sides.
Offline zippox
« Reply #2257 on: Fri, 01 May 2015, 09:14:29 »
Could you post a picture of what the spacebar looks like after that? And what tool did you use?
« Reply #2258 on: Fri, 01 May 2015, 11:55:39 »
Yes, on the 6.25 due to how many different spots there are for the stabilizer mount I can see how that may cause some rubbing issues, especially with Cherry stabs. Clipping the walls off the stabilizer slider guide may also be another way to solve it.
Offline cannonking
« Reply #2259 on: Fri, 01 May 2015, 16:47:40 »
I thought Costar stabs were the problematic ones?
Offline Unknown01011010
  • Formerly known as ABTmRw
« Reply #2260 on: Fri, 01 May 2015, 18:54:24 »
Can somebody please link me a Cherry profile row layout?  I have standard OEM keycaps, and I want to make sure I put on my black blanks correctly.
« Reply #2261 on: Fri, 01 May 2015, 20:46:29 »
These don't have markings for which row, so just start with the bigger keys and it becomes apparent where everything belongs. Cherry has the same basic shape as OEM as well, they are all just shorter.
Offline Sed8op8
  • Keyboard Padawan
« Reply #2262 on: Fri, 01 May 2015, 21:41:38 »
These are looking awesome I can't wait to see them on my board !
« Reply #2263 on: Fri, 01 May 2015, 21:49:26 »
Thanks Ivan for the help and the sweet keycaps!  I think I got it.   ^-^
For anyone else who needs help installing Cherry profile blanks, here's an album.  Included are two pics of a Poker II (blues) with the official black aluminum case and these keycaps.  The third pic shows the Cherry profile rows, and the fourth pic shows where those rows go.  Album: http://imgur.com/a/e6ql0
Looks like I have 8 keys left over (four 1.5 R1, two normal R1, one R2 weird shift, one big spacebar).  Is that normal?
« Last Edit: Fri, 01 May 2015, 21:54:59 by ABTmRw »
Offline imsto
    • imsto.cn
« Reply #2264 on: Sat, 02 May 2015, 03:42:05 »
 :D
99186-0
99188-1
99190-2
99192-3
imsto.cn
imsto's AiKB Taobao Shop
IBM Model M*3, IBM M13,M5, IBM with balls.Cherry   3000  3494 3700 4100*6 700*2 11900 8113 DAS4 TG3 KBC PokerDucky09Ducky1087 apple pink alps Ducky bull,tiger,rabbit,dragon version No:0000002
Offline Flyersfan1
  • Hi!
Quote from: Photekq
Offline duzeyao
« Reply #2266 on: Sat, 02 May 2015, 04:09:57 »
:D
Holy ****, my god handsome.
Your dyesub skill has become gorgeous after these years' work!
你绝版的婊子妈坟
Offline imsto
    • imsto.cn
imsto.cn
Offline noons
« Reply #2268 on: Sat, 02 May 2015, 09:31:36 »
I received my order, thank you! I have yet to try them out, I think I might order myself a new white KUL board to go along with these.. Just curious anyone notice a difference in typing feel VS typical oem height?
Tofu65 Turquoise Tealios | Drop ALT LP Alpacas | 2X Leopold FC750R MX Brown | KUL MX Brown w/Cherry Stab MOD | Leopold FC660C BLANK | REALFORCE 87U 45G | HHKB PRO2 | Leopold TKL MX RED | Filco Majestouch 2 TKL MX BLUE
Offline Sed8op8
  • Keyboard Padawan
« Reply #2269 on: Sat, 02 May 2015, 09:39:49 »
:D
You picked the PERFECT board to showcase this set my god ! What model cherry is this IMSTO? Looks gorgeous.
Offline Flyersfan1
  • Hi!
« Reply #2270 on: Sat, 02 May 2015, 09:41:27 »
:D
That's a g80-3000.
Quote from: Photekq
Offline Sed8op8
  • Keyboard Padawan
« Reply #2271 on: Sat, 02 May 2015, 09:47:06 »
:D
That's a g80-3000.
is this rare I'm going to try and hunt one down hehe
Edit: found one for $80 and i just noticed its a full size  :(
« Last Edit: Sat, 02 May 2015, 09:49:05 by Sed8op8 »
Offline Flyersfan1
  • Hi!
« Reply #2272 on: Sat, 02 May 2015, 09:48:38 »
:D
That's a g80-3000.
Nope, you can find them all over the place.  They don't have the best build quality though.
Quote from: Photekq
Offline Sed8op8
  • Keyboard Padawan
« Reply #2273 on: Sat, 02 May 2015, 09:50:07 »
:D
That's a g80-3000.
Nope, you can find them all over the place.  They are flimsy as hell though.
thanks flyers I just went from  :eek: to   :) to  :(
Edit: it does showcase the set nicely though
Offline Flyersfan1
  • Hi!
« Reply #2274 on: Sat, 02 May 2015, 10:04:22 »
:D
That's a g80-3000.
I think they compliment a Filco case very well, that's what I would put a set on if I ever find one!
Quote from: Photekq
Offline Latin00032
Offline Yslen
« Reply #2276 on: Sat, 02 May 2015, 10:53:54 »
That's the stock POM spacebar
Offline HPE1000
  • Keycap Paparazzo
« Reply #2277 on: Sat, 02 May 2015, 13:10:32 »
Perhaps the most potato picture I have posted but I think this should be left here. They showed up today and they look fantastic. Almost an exact match to the realforce.
Offline jalthi
« Reply #2278 on: Sat, 02 May 2015, 14:17:49 »
Crappy image quality thanks to my ancient phone, but this is them on a Filco with/without flash.
99237-0
Offline lolkey
« Reply #2279 on: Sat, 02 May 2015, 15:50:14 »
Did you have any issues with the stabilizers rubbing?
filco ninja mj2 tkl · mx brown · black case · blank black pbt
varmilo va87mr tkl · gateron red · black case · dye sub pbt ❤
vortex pok3r rgb · mx silent · white case · blank xda pbt
Offline wlhlm
« Reply #2280 on: Sat, 02 May 2015, 18:37:52 »
Filco has wire stabs so it should work fine.
« Reply #2281 on: Sat, 02 May 2015, 19:01:57 »
I put a set on my Noppoo Lolita, it's the only board I have with Costar style stabs... I didn't encounter any issues not even with the enter which is the usual problem with Cherry profile and Costar.
Offline strict
  • TKL Zealot
« Reply #2282 on: Sat, 02 May 2015, 19:20:53 »
Both my Phantom and Filco boards have costar stabs and I have zero issues on either one.
Offline Sed8op8
  • Keyboard Padawan
« Reply #2283 on: Sat, 02 May 2015, 19:47:07 »
Hey Ivan will you post when all orders have been shipped so I don't have to bug you unless absolutely needed  :)) really excited about these and now GMK Miami Nights ......gods work sir gods work !
« Reply #2284 on: Sat, 02 May 2015, 19:48:07 »
Yes of course. I got a bit behind, but expect to finish them up pretty soon.
Offline dannyp
« Reply #2285 on: Sat, 02 May 2015, 20:16:18 »
99295-0
Album here: https://imgur.com/a/11rg6
Thanks Ivan, you're the man. I love these! they are replacing the Filco Blank set I got several years back: http://www.diatec.co.jp/en/det.php?prod_c=611 which I found to be too glossy. These feel so nice. Thanks for being patient with all the people complaining.
I hope others continue to post pictures of their setup!
Offline Lu_e
« Reply #2286 on: Sat, 02 May 2015, 21:30:42 »
So why are they scoops and lines? You told me I was seeing things Ivan!
Just say NO to ABS keycaps
Offline Matias
  • * Commercial Vendor
    • http://matias.ca
« Reply #2287 on: Sat, 02 May 2015, 21:36:00 »
Can someone comment on how scratch prone these are?
I've found that PBT is easily scratched with a fingernail.  Needless to say, if you're going to try scratching one, do it on a spare keycap, or an edge/side that's not visible.
Offline dannyp
« Reply #2288 on: Sat, 02 May 2015, 21:36:20 »
Lu_e, I noticed mine came with 2 scoops for home and 1 non-scoop for the keypad. All three are lines though, and since I bought two sets I can either do scoops or non-scoops! :D
Offline Arizone
« Reply #2289 on: Sat, 02 May 2015, 23:26:34 »
Realized after I took these photos that the K key was the wrong profile. Doh.
Offline dannyp
« Reply #2290 on: Sat, 02 May 2015, 23:56:34 »
I noticed your space bar stabilizer bar is visible, I think something might not be aligned perfectly on yours right now because mine is completely hidden. I can't see the metal at all.
I like the red LED change, the blue is really bright. Got any tips on doing that? Is it just a matter of a little solder?
Offline Arizone
« Reply #2291 on: Sun, 03 May 2015, 02:16:53 »
It's aligned fine and on as far as it will go, I don't know why it seems to sit just a tad higher. I know it is warped just slightly upward on the ends but even then.
It came with a red LED. It's a Majestouch II Ninja with red switches, which might be why. Shouldn't be hard to change though.
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #2292 on: Sun, 03 May 2015, 05:45:30 »
Got my sets today.  A couple of keys were missing that I'm hoping imsto will help fix me up with, but otherwise I really love the look and feel of these.
Offline wlhlm
« Reply #2293 on: Sun, 03 May 2015, 07:31:41 »
Interest check for POM keys in case someone missed it.
Offline Lu_e
« Reply #2294 on: Sun, 03 May 2015, 17:00:18 »
I only bought 1 set... a no scoops option/extra row2 keys or whatever would have been really nice. I'm kinda one for uniformity, and this is a big surprise. (no I haven't tried scoops, nor did I plan on buying any) But hey with the way this group buy is going anything is possible.
Offline pr0ximity
« Reply #2295 on: Sun, 03 May 2015, 17:13:25 »
These arrived yesterday, they look great! Awesome work Ivan, thanks for sticking through this and all the work you put in.
It's been a pleasure serving with you gentlemen.
Offline Flyersfan1
  • Hi!
« Reply #2296 on: Sun, 03 May 2015, 22:06:39 »
Awesome pictures as always Naasfu! I really want to see someone post the Cyrillic version!
Quote from: Photekq
Offline Latin00032
« Reply #2297 on: Sun, 03 May 2015, 22:16:01 »
If keys are missing, do we talk to imsto or Ivan?
« Reply #2298 on: Mon, 04 May 2015, 08:15:35 »
If you have any issues with missing/duplicate keys or defective... you can contact imsto directly if you want 'immediate' resolution... otherwise you can send PM me with a clear and precise description of the problem. I will collect all issues and deal with them at the same time after everyone that has a set shipped has had time to report in.
« Last Edit: Mon, 04 May 2015, 08:17:09 by IvanIvanovich »
Offline rainb1ood
  • so pretty so plastic
« Reply #2299 on: Mon, 04 May 2015, 15:03:40 »
Just received mine (was in our old house, forgot to ask Ivan to change shipping address). Gonna check if everythings okay.
Heres some comparison between this and from the Vortex Mass Drop blank PBT
Left: Ivan GB
Right: Vortex Massdrop GB
The vortex key has label/stamp which profile is the key
