Author Topic: Can anyone tell me if these keycaps have the plastic for costar stabilizers?  (Read 2271 times)
Offline Prankk
I have a das keyboard and need to know if these have the plastic for costar stabilizers. Thanks for any help. If they do not have the plastic can anyone recommend a nice set of PBT caps for a Das?
http://www.ebay.com/itm/291001815528?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D291001815528%26_rdc%3D1
The plastic pieces are removable. You can simple use the ones that came with your das, or order more from wasdkeyboards.com
That set will work fine with your das!
Offline phoenix1234
Yes, Filco has these stabilizers.
Anyway, I'm quite sure that you can find a lot of stab inserts here:
http://www.wasdkeyboards.com/index.php/cherry-mx-keycap-stabilizer-insert.html
clips:
http://www.wasdkeyboards.com/index.php/cherry-mx-plate-mounted-stabilizer-clips-2pcs.html
stabs:
http://www.wasdkeyboards.com/index.php/cherry-mx-stabilizer-spring-for-keycaps.html
So don't worry too much.
I like linear switches
Offline Prankk
Wow, I never noticed that you can just pull them out. thanks guys
