Author Topic: TKL with DIP switch  (Read 2198 times)
Offline DrinkTea
TKL with DIP switch
« on: Sun, 17 November 2013, 17:02:55 »
Other than topre boards, what TKL keyboards have DIP switches that will, at the very least, allow me to switch caps and control? Ideally it would just be a simple case and PCB. I see WASD has it but I think I'll get the switches myself. I'd like to take a stab at building my own keyboard.
Offline Dreamre
    • kbdlife
Re: TKL with DIP switch
« Reply #1 on: Sun, 17 November 2013, 18:13:57 »
Ducky has one.
Offline DrinkTea
« Reply #2 on: Sun, 17 November 2013, 18:17:57 »
Ducky has one.
Cool. How's the build quality?
Offline terran5992
  • One With The Cup Rubber
« Reply #3 on: Sun, 17 November 2013, 19:20:25 »
Offline Dreamre
    • kbdlife
« Reply #4 on: Sun, 17 November 2013, 20:22:25 »
Ducky has one.
Ducky is pretty good quality
Pretty good quality for amount of features you get too!
Offline Belfong
« Reply #5 on: Sun, 17 November 2013, 21:28:47 »
Ducky has a board only without key switches and keycaps?
I'm also looking for a TKL but with key switches, DIP and without keycaps as I have many keycaps set now. The only vendor I know that does this is WASD but it's in the US and shipping is gonna kill me.
Offline WhiteFireDragon
    • youtube
« Reply #6 on: Sun, 17 November 2013, 22:11:44 »
Ducky has one.
Ducky has gone a long ways in the past couple of years. Currently, they're either on par or better than Filco. It'll come down to whether you have a preference of cherry stabilizers or not.
« Reply #7 on: Mon, 18 November 2013, 02:51:20 »
I'm not aware of anyone who sells a conventional (i.e. not custom) keyboard without switches or keycaps.
Your best bet (apart from buying components and building it yourself) is to buy a cheap keyboard with horrible legends, and simply replace the keycaps.
QFR is cheap and good quality, but many people don't like the keycaps and that is the first thing they swap out.
Offline mapple
« Reply #8 on: Mon, 18 November 2013, 03:20:46 »
to answer your topic of post : ducky shine 3 TKL it is TKL and it has DIP switches based how they work on g2pro they are very well made boards.
In God We Trust
Offline Moosecraft
  • HHKB Pro
« Reply #9 on: Mon, 18 November 2013, 15:10:29 »
I really like my Ducky G2pro, even though it hasn't really gone through heavy daily wear as I rotate it looks like new :)
« Reply #10 on: Mon, 18 November 2013, 20:59:28 »
WASD does sell "barebones" keyboards without caps. Not sure what the DIP switches support though.
Since they're cheap nowadays, just get a custom PCB and go to town.
