Author Topic: I Found (The Best) Rainbow Keycaps  (Read 21400 times)
Offline MsYutai
« on: Sun, 17 November 2013, 18:28:30 »
There are many a rainbow keycap out there, but these, in my opinion, are the coolest!!!
Found here on Taobao
I ordered them using TaoBaoFocus, and although it was a bit expensive, it was completely worth it! I got the 108 side printed set.
I really like typing on them as they are PBT and seem to be OEM profile.
Only problem is that my spacebar is not holding onto the stabilizers well, as in it's too loose. Any tips to fix that much appreciated.
You can read about my QFR case painting experience here
Album for the rainbow keys here
In the sun:
On my desk:
Height comparison:
Left to right: Rainbow PBT, Imsto Thick PBT, SP Nyan Cat, Stock QFR
Thickness comparison:
« Last Edit: Sun, 17 November 2013, 18:38:47 by MsYutai »
CM Storm Quickfire XT - MX Reds
Roccat Kone Pure Optical|Kana v2|Zowie FK|Logitech g500s|Mionix Naos 7000|CM Spawn|Logitech Performance MX
Offline Latin00032
Re: I Found (The Best) Rainbow Keycaps
« Reply #1 on: Sun, 17 November 2013, 18:53:36 »
Use sandwich bag plastic in the cross of the point where the stabilizers enter the key cap.
Offline Beca
  • what am i doing with my life
« Reply #2 on: Sun, 17 November 2013, 19:19:21 »
How much did it cost total through the proxy? They look great.
Offline terran5992
  • One With The Cup Rubber
« Reply #3 on: Sun, 17 November 2013, 19:22:24 »
Not as thick as id liked it to be
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Sun, 17 November 2013, 19:37:57 »
I would go for Cherry KC104R
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
« Reply #5 on: Sun, 17 November 2013, 19:39:09 »
such beauty
many color
branded cherry
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« Reply #6 on: Sun, 17 November 2013, 19:55:00 »
this also beautiful rainbow :thumb:
Offline cruk
  • :> keys
« Reply #7 on: Sun, 17 November 2013, 22:43:21 »
I didn't think I would give rainbow keycaps a thought until you posted this beauty  :eek:
« Reply #8 on: Mon, 18 November 2013, 03:08:11 »
Most keycap sets look better when they are actually on your own keyboard.  Of course then you care so much for them that you don't want to touch them in case you get them dirty or make them shine.
Offline iri
« Reply #9 on: Mon, 18 November 2013, 08:43:36 »
i don't like printed keycaps, so i use these. they are from geekfeng's ebay shop.
-Ray Bradbury
Offline midnight2903
« Reply #10 on: Sun, 24 November 2013, 06:23:38 »
I want to get one set as well, which one did you order?
Offline Human
« Reply #11 on: Sun, 24 November 2013, 10:16:57 »
Yup, that is called KBC POM. So far that is the most great looking and backlit compatible rainbow keys set out there.
But sadly it is EOLed and also the stem are extremely tight, so you will face great risk when you try to remove it off switches.
Offline acidtrip69
« Reply #12 on: Sun, 24 November 2013, 12:17:56 »
i want to oder somethings from there too. Can you tell me how to how the proxy works ? how do i order using the the proxy ?
« Last Edit: Sun, 24 November 2013, 12:27:33 by acidtrip69 »
« Reply #13 on: Sun, 24 November 2013, 13:38:26 »
So those are not PBT?
The site say PBT  :'(
Offline berserkfan
« Reply #14 on: Sun, 24 November 2013, 16:25:13 »
Couldn't you have gotten them from geekfeng? I get the impression he sells at very fair prices and gives geekhackers a discount too.
as long as prices are reasonable, we gotta support our own forummers, man! Geekfeng does stuff for the community like organize group buys; you should really check him out first.
In the sun:
On my desk:
Height comparison:
Offline n0rdlad
« Reply #15 on: Mon, 25 November 2013, 06:51:17 »
- Filco MJ2 104 MX Brown -
Offline Human
« Reply #16 on: Mon, 25 November 2013, 08:36:27 »
I mean this one, this is KBC POM.
Offline iri
« Reply #17 on: Mon, 25 November 2013, 09:26:50 »
imo, the OP's caps look better than mine. and PBT feels better than POM.
and the stem gets less tight once a keycap spends some time on a stem.
-Ray Bradbury
