Author Topic: funny banner from 4chan  (Read 2237 times)
Offline fateswarm
« on: Tue, 19 November 2013, 13:30:07 »
Re: funny banner from 4chan
« Reply #1 on: Tue, 19 November 2013, 13:32:08 »
it'sbeenpostedbefore
Offline baldgye
  • Will Smith Disciple
« Reply #2 on: Tue, 19 November 2013, 13:33:37 »
whats 4chan?
  • Live long and prosper
« Reply #3 on: Tue, 19 November 2013, 13:38:11 »
Feeling some dejavu...
tp thread is tp thread
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #4 on: Tue, 19 November 2013, 13:49:23 »
Original from the film is better!
It's from 'Wanted' if you don't know it. It's an OK movie.
Offline ITzNybble
  • Formerly curro123083
  • Nibble or Nybble either way it sounds delicious!
« Reply #5 on: Tue, 19 November 2013, 13:51:10 »
saw 4chan.....took me 10 minutes to build courage to open at work :P
WASD V1 Custom - MX Blue
Custom Miami QFR - MX Green
Handwired Redox-Manuform - Box Pink/Box Navy
KBD67 MKII PolyCarbonate - Gateron CJ
Offline paicrai
  • mindblank
« Reply #6 on: Tue, 19 November 2013, 14:14:06 »
It's from 'Wanted' if you don't know it. It's an OK punching and shooting simulation.
Fits better.
THE FEMINIST ILLUMINATI
Offline osi
« Reply #7 on: Tue, 19 November 2013, 14:14:43 »
4chan.... Use with caution :D
Offline ITzNybble
« Reply #8 on: Tue, 19 November 2013, 15:12:35 »
unless you want porn...then its okay
