Author Topic: Sanctuary key set w/Led backlighting underneath  (Read 2103 times)
Offline Rebz
« on: Tue, 19 November 2013, 23:42:55 »
Hello I was wondering if anyone knew what the Sanctuary key set looks like with LED's underneath. On another thread http://geekhack.org/index.php?topic=35864.msg1115811#msg1115811 user pmh1410 (http://geekhack.org/index.php?action=profile;u=19338) posted the attached pictures.
Completed my Duck Poker + 38GT assembed with Clear 58g, full Red led with Sanctuary keyset
You can see the red led illumination in between the keys, but it is hard to tell whether or not they keys look any different. For example whether or not the keys themselves look lit up. If any of you have pictures of what I am trying to look for that would be awesome! If not letting me know whether it works or not is just as good.
Thanks for any help.
Offline Photoelectric
Re: Sanctuary key set w/Led backlighting underneath
« Reply #1 on: Wed, 20 November 2013, 00:08:27 »
I believe that dark gray won't let any light through and will be opaque.  You'll just see the glow around the plate and some reflected off the keycap sides.
Offline terran5992
  • One With The Cup Rubber
« Reply #2 on: Wed, 20 November 2013, 04:34:49 »
Yep this ^^
