Author Topic: Search for Thread Starter???  (Read 5241 times)
Offline korrelate
  • iubeo stultum esse libenter
« on: Wed, 20 November 2013, 14:45:13 »
The only way to search for threads started by a particular user seems to be a manual search trough the list of all threads posted by a user. Is this the best way to perform this search? Am I missing something?
I would love to see "thread started by" box appear on the search page. It doesn't have to return all of the child posts under the thread started by that user... just the initial post. From there, one could easily traverse to the last post associated with that particular thread.
Cheers,
K
Topre REALFORCE
Re: Search for Thread Starter???
« Reply #1 on: Wed, 20 November 2013, 14:57:32 »
If your looking for posts/topics by someone specific go to their profile and you can click on the left to get to those.
45145-0
Offline korrelate
« Reply #2 on: Wed, 20 November 2013, 20:24:35 »
Spamray,
Thanks. I was chuckling to myself about the relevance of your example. I'm familiar with the 'Show All Posts' functionality and I've used it with much gratitude several times (by clicking through the profile or through the Home/Watched/Unread/.../Logout menu bar.
I think I'm looking for a very specific filter, though, and here's why:
A) I'm lazy.
B) If I want to find a particular user's WTT/WTS or WTB thread I can assume one thing with reasonable safety: the user I'm interested in didn't reply to some other post... rather he started that WTT/WTS or WTB thread. But if that user posted that WTT/WTS or WTB thread say two weeks ago, and in the meantime has posted a number of responses (and some users are very prolific) then there are a ton of posts that I have to hunt through if I go the UserName>Profile>ShowAllPosts route that I've used and that you've reminded me about. And that's because there are two types of posts appearing in set of all posts: replies to threads posted by other users and posts that started threads.
C) Refer to A) above.
My justification: when I think about the data that's floating around in the background, I'm thinking that there would be (in addition to many others) two objects of import here:
1. A post object.
2. A thread object.
What ever a post is, a thread would be a collection of them, probably ordered, and one of its attributes would be the first post, and I'm just using my imagination here, but another of its attributes could be the user responsible for creating the first post (the thread "owner").
So all that said, I guess my questions are:
1. Have I explained myself well enough? I.e. I don't want this idea to be dismissed because I failed to explain its use case or because I sound like some below-average tech user.
2. Kind of a follow up to 1.) directly above, but this would give me just the threads that that user started... which would be subset of all of the posts that a user has created (and the threads that a user has created are sometimes different in nature than the threads that the user is replying to: WTT/S/B threads in particular).
3. Do the attributes of the objects that the  UI is built upon support the kind of search I'm suggesting?
4. Is there some other search criteria that can approximate this "thread owner" functionality that I am unaware of? I consider myself an advanced user of all kinds of boolean search protocols, etc. and I've looked through all of the search functionality available to me but nothing is jumping off the page.
Cheers & Thanks for the Reply,
K
« Last Edit: Wed, 20 November 2013, 20:29:16 by korrelate »
Topre REALFORCE
« Reply #3 on: Wed, 20 November 2013, 20:40:46 »
You can also click to only show the topics they have started....That's what I was trying to say earlier! And most of us don't start that many topics.
Offline korrelate
« Reply #4 on: Wed, 20 November 2013, 20:53:51 »
I just tried this out on your profile!! So this is doing what I wanted!!! I think, right... if I click on "Show Topics' for Spamray all of the results are going to be the threads you started, right? I didn't go through all of your results... but the first couple gave me exactly what I was looking for..
Topre REALFORCE
Offline korrelate
« Reply #5 on: Wed, 20 November 2013, 21:04:29 »
Just finished checking out Spamray's suggestion and this IS exactly what I was looking for.
userid > Profile Info > Show Posts... > Topics
That gives you the threads that were started by that particular user id.
Thanks Again Spamray!!!
Topre REALFORCE
« Reply #6 on: Wed, 20 November 2013, 21:08:10 »
^^ Glad I could help!
Offline korrelate
« Reply #7 on: Wed, 20 November 2013, 21:10:52 »
Your avatar matches the sentiment in "Glad I could help," PERFECTLY. I can't tell you how far away I was from noticing this... I didn't realize that there was so much imbedded functionality under the ellipsis in that "Show Posts..." choice.
Topre REALFORCE
